K230 VICAP API Reference
Contents
K230 VICAP API Reference#
The VICAP subsystem is responsible for video image input capture and processing in the K230 SOC. It processes signals output by the sensor in real-time to obtain restored and enhanced digital images that are closer to what the human eye sees in reality. It mainly includes MIPI RxDphy, MIPI CSI, ISP, and DW. MIPI is used to receive high-speed differential signals from the sensor and convert them to the DVP interface for ISP processing; ISP is used for image information processing; DW is used for fisheye correction and multi-channel resize output.
This document mainly describes the application programming interface of the VICAP module, which provides application developers with operational interfaces and configuration parameters for capturing video image data through the VICAP module.
Function Description#
VICAP#
The VICAP module is an abstract description of the entire image acquisition and processing unit.
The VICAP hardware consists of four major modules: Sensor, VI, ISP, and Dewarp (as shown in Figure 1-1). It supports up to 3 sensors simultaneously. The MCM module inside the ISP implements time-division multiplexing management of multiple sensors. The output data of multiple sensors is written to DDR through the Memory Interface’s Write interface of the MCM, and then read and loaded into the ISP Pipeline for processing.
Diagram automatically generated
Figure 1-1 VICAP Hardware Architecture Diagram
The VICAP software architecture is shown in Figure 1-2, from top to bottom: Application Interface Layer, Media Interface Layer, System Framework Layer, Driver Layer, and Hardware Layer.
  • Application Interface Layer: Provides API interfaces in the form of kd_mapi_vicap_xxx and usage instructions. It further encapsulates the functional interfaces provided by each sub-module of the Media Interface Layer to simplify the application development process.
  • Media Interface Layer: This layer consists of various sub-modules of VICAP, each providing its own media interface API encapsulation.
  • Framework Layer: Responsible for the control and management of the entire system software functions and business logic of VICAP. It integrates and unifies the interfaces and functions provided by each sub-module to form a complete VICAP system control logic and process.
  • Driver Layer: A collection of kernel driver functions for various hardware modules of VICAP.
  • Hardware Layer: A collection of specific hardware modules of VICAP, including sensors.
GUI, Text, Application automatically generated
Sensor#
The Sensor module is one of the data sources for VICAP image capture, responsible for configuring the operating parameters and working modes of the image sensor unit.
The K230 platform supports a variety of sensor interface types. We will use the current most commonly used MIPI CSI interface sensor as an example. The hardware connection diagram between the sensor and the main control platform is as follows:
Figure 1-3
The main control sends configuration register control to the sensor through the I2C interface, and the sensor sends image data to the main control SOC through the MIPI CSI interface.
The system architecture of the Sensor module is shown in Figure 1-4:
GUI, Application, Email automatically generated
Figure 1-4 Sensor System Architecture Diagram
From top to bottom: Media Interface Layer, Hardware Driver Layer, and Hardware Layer
  • Media Interface Layer: Provides kd_mpi_sensor_xxx interfaces for external modules to operate and access sensor devices.
  • Driver Layer: This layer mainly includes two parts: sensor_dev and sensor_drv.
    • sensor_dev: Responsible for registering device driver files and providing the implementation process of file operation interfaces. By registering device file nodes /dev/sensorxx, it allows user-space programs to access the kernel driver.
    • sensor_drv: Specific sensor hardware driver, encapsulating operations on the sensor into a unified interface.
  • Hardware Layer: Sensor module hardware, supporting up to three hardware sensors simultaneously in the current system.
API Reference#
VICAP#
kd_mpi_vicap_get_sensor_info#
[Description]
Get sensor configuration information based on the specified sensor configuration type.
[Syntax]
[Parameters]
Parameter Name
Input/Output
sensor_type
Sensor configuration type
Input
sensor_info
Sensor configuration information
Output
[Return Value]
Success.
Non-zero
Failure, refer to error code.
[Chip Differences]
None.
[Requirements]
  • Header file: mpi_vicap_api.h
  • Library file: libvicap.a
[Note]
Application developers need to first call this API to get sensor configuration information based on the sensor configuration type they need to use, and then call subsequent interfaces to initialize other VICAP modules based on the configuration information.
[Example]
None.
[Related Topics]
kd_mpi_vicap_set_dev_attr#
[Description]
Set VICAP device attributes.
[Syntax]
[Parameters]
Parameter Name
Input/Output
dev_num
VICAP device number
Input
dev_attr
Input
[Return Value]
Success.
Non-zero
[Chip Differences]
None.
[Requirements]
[Note]
None.
[Example]
None.
[Related Topics]
kd_mpi_vicap_get_dev_attr#
[Description]
Get VICAP device attributes.
[Syntax]
k_s32 kd_mpi_vicap_get_dev_attr(k_vicap_dev dev_num, k_vicap_dev_attr *dev_attr)
[Parameters]
Parameter Name
Input/Output
dev_num
VICAP device number
Input
dev_attr
Output
[Return Value]
Success.
Non-zero
[Chip Differences]
None.
[Requirements]
[Note]
None.
[Example]
None.
[Related Topics]
kd_mpi_vicap_set_chn_attr#
[Description]
Set VICAP channel attributes.
[Syntax]
[Parameters]
Parameter Name
Input/Output
dev_num
VICAP device number
Input
chn_num
VICAP output channel number
Input
chn_attr
VICAP output channel attributes
Input
[Return Value]
Success.
Non-zero
[Chip Differences]
None.
[Requirements]
[Note]
None.
[Example]
None.
[Related Topics]
kd_mpi_vicap_get_chn_attr#
[Description]
Get VICAP channel attributes.
[Syntax]
[Parameters]
Parameter Name
Input/Output
dev_num
VICAP device number
Input
chn_num
Input
chn_attr
Output
[Return Value]
Success.
Non-zero
[Chip Differences]
None.
[Requirements]
[Note]
None.
[Example]
None.
[Related Topics]
kd_mpi_vicap_init#
[Description]
VICAP device initialization.
[Syntax]
[Parameters]
Parameter Name
Input/Output
dev_num
VICAP device number
Input
[Return Value]
Success.
Non-zero
[Chip Differences]
None.
Requirements:
Notes:
Before using this interface, you need to call kd_mpi_vicap_set_dev_attr to set the device attributes, and then call kd_mpi_vicap_set_chn_attr to set the output channel attributes.
Related Topics:
kd_mpi_vicap_deinit#
Description:
Deinitialize the VICAP device.
Syntax:
Parameters:
Parameter Name
Input/Output
dev_num
VICAP device number
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_vicap_start_stream#
Description:
Start the VICAP device output data stream.
Syntax:
Parameters:
Parameter Name
Input/Output
dev_num
VICAP device number
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_vicap_stop_stream#
Description:
Stop the VICAP device data stream output.
Syntax:
Parameters:
Parameter Name
Input/Output
dev_num
VICAP device number
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_vicap_dump_frame#
Description:
Dump VICAP data based on the specified device and output channel.
Syntax:
k_s32 kd_mpi_vicap_dump_frame(k_vicap_dev dev_num, k_vicap_chn chn_num, k_vicap_dump_format format,
Parameters:
Parameter Name
Input/Output
dev_num
VICAP device number
Input
chn_num
Input
format
Dump data type
Input
vf_info
Dump frame information
Output
milli_sec
Timeout duration
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_vicap_dump_release#
Description:
Release the dumped data frame.
Syntax:
Parameters:
Parameter Name
Input/Output
dev_num
VICAP device number
Input
chn_num
Input
vf_info
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_vicap_set_vi_drop_frame#
Description:
Set hardware frame drop.
Syntax:
Parameters:
Parameter Name
Input/Output
csi
VICAP device number
Input
frame
Structure, see below
m
Drop n frames every m frames
Input
n
Input
HDR mode
Input
enable
Enable or disable
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
kd_mpi_vicap_set_mclk#
Description:
Set MCLK frequency.
Syntax:
Parameters:
Parameter Name
Input/Output
id
MCLK ID
Input
sel
Clock source
Input
mclk_div
Division factor
Input
mclk_en
Enable or disable
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
kd_mpi_vicap_set_dump_reserved#
Description:
Set whether to enable fast dump mode.
Syntax:
Parameters:
Parameter Name
Input/Output
dev_num
VICAP device number
Input
chn_num
Input
reserved
Enable fast dump mode
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
kd_mpi_vicap_set_slave_enable#
Description:
Enable slave mode.
Syntax:
Parameters:
Parameter Name
Input/Output
id
Slave mode ID
Input
enable
Enable or disable slave mode
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
kd_mpi_vicap_set_slave_attr#
Description:
Set slave mode parameters.
Syntax:
Parameters:
Parameter Name
Input/Output
id
Slave mode ID
Input
info
Slave mode parameters
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
kd_mpi_vicap_3d_mode_crtl#
Description:
Enable 3D mode.
Syntax:
Parameters:
Parameter Name
Input/Output
enable
Enable 3D mode
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Sensor#
kd_mpi_sensor_open#
Description:
Open the sensor device based on the sensor device name.
Syntax:
Parameters:
Parameter Name
Input/Output
sensor_name
Sensor device name
Input
Return Value:
Positive value
Success. Returns device descriptor
Negative value
Chip Differences:
None.
Requirements:
  • Header file: mpi_sensor_api.h
  • Library file: libsensor.a
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_close#
Description:
Close the sensor device.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Sensor device file descriptor
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_power_set#
Description:
Set the sensor power state.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
on
Set sensor power state, K_TRUE: power on, K_FALSE: power off
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_id_get#
Description:
Get the sensor ID.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
sensor_id
Acquired sensor ID
Output
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_init#
Description:
Initialize the sensor.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
Initialize sensor configuration registers based on the specified sensor mode
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_reg_read#
Description:
Read the content of the sensor register.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
reg_addr
Sensor register address
Input
reg_val
Content of the read register
Output
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_reg_write#
Description:
Write content to the sensor register.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
reg_addr
Input
reg_val
Content to write to the sensor register
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_mode_get#
Description:
Get the sensor mode configuration.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
Acquired sensor mode configuration parameters
Output
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_mode_set#
Description:
Set the sensor mode configuration.
Syntax:
k_s32 kd_mpi_sensor_mode_set(k_s32 fd, k_sensor_mode mode)
Parameters:
Parameter Name
Input/Output
fd
Input
Sensor mode configuration parameters
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_stream_enable#
Description:
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
enable
Set sensor stream output state, 0: disable output, non-0: enable output
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_again_set#
Description:
Set the sensor analog gain.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
gain
Gain configuration parameters
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_again_get#
Description:
Get the sensor analog gain.
Syntax:
k_s32 kd_mpi_sensor_again_get(k_s32 fd, k_sensor_gain *gain)
Parameters:
Parameter Name
Input/Output
fd
Input
gain
Output
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_dgain_set#
Description:
Set the sensor digital gain.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
gain
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_dgain_get#
Description:
Get the sensor digital gain.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
gain
Output
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_intg_time_set#
Description:
Set the sensor integration time.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
time
Integration time configuration parameters
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_intg_time_get#
Description:
Get the sensor integration time.
Syntax:
Parameters:
Parameter Name
Input/Output
fd
Input
time
Output
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_otpdata_get#
Description:
Get the sensor OTP data.
Syntax:
k_s32 kd_mpi_sensor_otpdata_get(k_s32 fd, void *otp_data)
Parameters:
Parameter Name
Input/Output
fd
Input
otp_data
OTP data
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
kd_mpi_sensor_otpdata_set#
Description:
Set the sensor OTP data.
Syntax:
k_s32 kd_mpi_sensor_otpdata_set(k_s32 fd, void *otp_data)
Parameters:
Parameter Name
Input/Output
fd
Input
otp_data
OTP data
Input
Return Value:
Success.
Non-zero
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
Data Types#
VICAP#
The related data types for this functional module are defined as follows:
k_vicap_sensor_type#
Description: Definition of sensor types supported by the current system.
Definition:
    SENSOR_TYPE_MAX,
} k_vicap_sensor_type;
Members:
Member Name
OV9732 1-lane 10-bit 720P 30fps linear output configuration, external crystal 16M, connected to CSI0
OV9286 2-lane 10-bit 720P 30fps linear output configuration for IR image, external crystal 25M, connected to CSI1
OV9286 2-lane 10-bit 720P 30fps linear output configuration for speckle image, external crystal 25M, connected to CSI1
OV_OV9286_MIPI_1280X720_60FPS_10BIT_LINEAR_IR
OV9286 2-lane 10-bit 720P 60fps linear output configuration for IR image, external crystal 25M, connected to CSI1
OV_OV9286_MIPI_1280X720_60FPS_10BIT_LINEAR_SPECKLE
OV9286 2-lane 10-bit 720P 60fps linear output configuration for speckle image, external crystal 25M, connected to CSI1
IMX335_MIPI_2LANE_RAW12_1920X1080_30FPS_LINEAR
IMX335 12-bit 2-lane 1080P 30fps linear output, external crystal 24M, connected to CSI0
IMX335_MIPI_2LANE_RAW12_2592X1944_30FPS_LINEAR
IMX335 12-bit 2-lane full resolution 30fps linear output, external crystal 24M, connected to CSI0
IMX335_MIPI_4LANE_RAW12_2592X1944_30FPS_LINEAR
IMX335 12-bit 4-lane full resolution 30fps linear output, external crystal 24M, connected to CSI0
IMX335_MIPI_2LANE_RAW12_1920X1080_30FPS_MCLK_7425_LINEAR
IMX335 12-bit 2-lane 1080P 30fps linear output, chip output 74.25M clock, connected to CSI0
IMX335_MIPI_2LANE_RAW12_2592X1944_30FPS_MCLK_7425_LINEAR
IMX335 12-bit 2-lane full resolution 30fps linear output, chip output 74.25M clock, connected to CSI0
IMX335_MIPI_4LANE_RAW12_2592X1944_30FPS_MCLK_7425_LINEAR
IMX335 12-bit 4-lane full resolution 30fps linear output, chip output 74.25M clock, connected to CSI0
IMX335_MIPI_4LANE_RAW10_2XDOL
IMX335 10-bit 4-lane full resolution 15fps 2DOL output, external crystal 24M, connected to CSI0
IMX335_MIPI_4LANE_RAW10_3XDOL
IMX335 10-bit 4-lane full resolution 15fps 3DOL output, external crystal 24M, connected to CSI0
SC_SC035HGS_MIPI_1LANE_RAW10_640X480_120FPS_LINEAR
SC035 10-bit 1-lane 640x480 120fps linear output, external crystal 24M, connected to CSI2
SC_SC035HGS_MIPI_1LANE_RAW10_640X480_60FPS_LINEAR
SC035 10-bit 1-lane 640x480 60fps linear output, external crystal 24M, connected to CSI2
SC_SC035HGS_MIPI_1LANE_RAW10_640X480_30FPS_LINEAR
SC035 10-bit 1-lane 640x480 30fps linear output, external crystal 24M, connected to CSI2
OV_OV9286_MIPI_1280X720_30FPS_10BIT_MCLK_25M_LINEAR_SPECKLE
OV9286 2-lane 10-bit 720P 30fps linear output configuration for speckle image, chip output 25M clock, connected to CSI1
OV_OV9286_MIPI_1280X720_30FPS_10BIT_MCLK_25M_LINEAR_IR
OV9286 2-lane 10-bit 720P 30fps linear output configuration for IR image, chip output 25M clock, connected to CSI1
OV_OV9732_MIPI_1280X720_30FPS_10BIT_MCLK_16M_LINEAR
OV9732 1-lane 10-bit 720P 30fps linear output configuration, chip output 16M clock, connected to CSI0
OV_OV5647_MIPI_1920X1080_30FPS_10BIT_LINEAR
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, external crystal 25M, connected to CSI2
OV_OV5647_MIPI_2592x1944_10FPS_10BIT_LINEAR
OV5647 2-lane 10-bit full resolution 10fps linear output configuration, external crystal 25M, connected to CSI2
OV_OV5647_MIPI_640x480_60FPS_10BIT_LINEAR
OV5647 2-lane 10-bit 640x480 60fps linear output configuration, external crystal 25M, connected to CSI2
OV_OV5647_MIPI_CSI0_1920X1080_30FPS_10BIT_LINEAR
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, chip output 25M clock, connected to CSI0
SC_SC201CS_MIPI_1LANE_RAW10_1600X1200_30FPS_LINEAR
SC201 1-lane 10-bit 1600x1200 30fps linear output, crystal 27M, connected to CSI1
SC_SC201CS_SLAVE_MODE_MIPI_1LANE_RAW10_1600X1200_30FPS_LINEAR
SC201 1-lane 10-bit slave mode 1600x1200 30fps linear output, crystal 27M, connected to CSI1
OV_OV5647_MIPI_CSI1_1920X1080_30FPS_10BIT_LINEAR
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, external crystal 25M, connected to CSI1
OV_OV5647_MIPI_CSI2_1920X1080_30FPS_10BIT_LINEAR
XS9950_MIPI_CSI0_1280X720_30FPS_YUV422
XS9950 2-lane YUV422 720P 25fps linear output, analog camera, connected to CSI0
XS9950_MIPI_CSI1_1280X720_30FPS_YUV422
XS9950 2-lane YUV422 720P 25fps linear output, analog camera, connected to CSI1
OV_OV9286_MIPI_1280X720_30FPS_10BIT_MCLK_25M_LINEAR_SPECKLE_V2
OV_OV9286_MIPI_1280X720_30FPS_10BIT_MCLK_25M_LINEAR_IR_V2
OV_OV9732_MIPI_1280X720_30FPS_10BIT_MCLK_16M_LINEAR_V2
OV9732 1-lane 10-bit 720P 30fps linear output configuration, chip output 16M clock, connected to CSI2
OV_OV5647_MIPI_CSI0_1920X1080_30FPS_10BIT_LINEAR_V2
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, external crystal 25M, connected to CSI0
OV_OV5647_MIPI_CSI1_1920X1080_30FPS_10BIT_LINEAR_V2
OV_OV5647_MIPI_CSI2_1920X1080_30FPS_10BIT_LINEAR_V2
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, chip output 25M clock, connected to CSI2
GC2053_MIPI_CSI0_1920X1080_30FPS_10BIT_LINEAR
GC2053 2-lane 10-bit 1080P 30fps linear output configuration, chip output 16M clock, connected to CSI0
Notes:
  1. This list needs to be maintained by sensor driver developers. Application developers use the sensor types defined here to open specific types of sensor devices.
k_vicap_dev#
Description: Definition of VICAP device IDs.
Definition:
    VICAP_DEV_ID_0 = 0,
    VICAP_DEV_ID_1 = 1,
    VICAP_DEV_ID_2 = 2,
    VICAP_DEV_ID_MAX,
} k_vicap_dev;
Members:
Member Name
VICAP_DEV_ID_0
VICAP Device 0
VICAP_DEV_ID_1
VICAP Device 1
VICAP_DEV_ID_2
VICAP Device 2
k_vicap_chn#
Description: Definition of VICAP output channel numbers.
Definition:
    VICAP_CHN_ID_0 = 0,
    VICAP_CHN_ID_1 = 1,
    VICAP_CHN_ID_2 = 2,
    VICAP_CHN_ID_MAX,
} k_vicap_chn;
Members:
Member Name
VICAP_CHN_ID_0
VICAP output channel 0
VICAP_CHN_ID_1
VICAP output channel 1
VICAP_CHN_ID_2
VICAP output channel 2
k_vicap_csi_num#
Description: Definition of VICAP CSI numbers.
Definition:
    VICAP_CSI0 = 1,
    VICAP_CSI1 = 2,
    VICAP_CSI2 = 3,
} k_vicap_csi_num;
Members:
Member Name
VICAP_CSI0
CSI0
VICAP_CSI1
CSI1
VICAP_CSI2
CSI2
Notes:
The CSI number to which the sensor is connected is determined by the hardware physical connection.
k_vicap_mipi_lanes#
Description: Definition of VICAP MIPI lane numbers.
Definition:
    VICAP_MIPI_1LANE = 0,
    VICAP_MIPI_2LANE = 1,
    VICAP_MIPI_4LANE = 3,
} k_vicap_mipi_lanes;
Members:
Member Name
VICAP_MIPI_1LANE
1 lane
VICAP_MIPI_2LANE
2 lanes
VICAP_MIPI_4LANE
4 lanes
Notes:
The number of MIPI lanes used by the sensor is determined by the hardware physical connection. When using 4 lanes, a maximum of two sensors can be connected.
k_vicap_csi_data_type#
Description: Definition of VICAP MIPI data types.
Definition:
} k_vicap_csi_data_type;
Members:
Member Name
VICAP_CSI_DATA_TYPE_RAW8
RAW8
VICAP_CSI_DATA_TYPE_RAW10
RAW10
VICAP_CSI_DATA_TYPE_RAW12
RAW12
VICAP_CSI_DATA_TYPE_RAW14
RAW14
Notes:
k_vicap_data_source#
Description: Definition of VICAP data sources.
Definition:
    VICAP_SOURCE_CSI0 = 0, /**< VICAP acquire data from the CSI0 */
    VICAP_SOURCE_CSI1 = 1, /**< VICAP acquire data from the CSI1 */
    VICAP_SOURCE_CSI1_FS_TR0 = 2, /**< VICAP acquire data from the CSI1 for flash trigger 0 */
    VICAP_SOURCE_CSI1_FS_TR1 = 3, /**< VICAP acquire data from the CSI1 for flash trigger 1 */
    VICAP_SOURCE_CSI2 = 4, /**< VICAP acquire data from the CSI2 */
} k_vicap_data_source;
Members:
Member Name
VICAP_SOURCE_CSI0
VICAP data source is CSI0
VICAP_SOURCE_CSI1
VICAP data source is CSI1
VICAP data source is CSI1 Flash trigger 0
VICAP data source is CSI1 Flash trigger 1
VICAP_SOURCE_CSI2
VICAP data source is CSI2
Notes:
k_vicap_vi_dvp_port#
Description: Definition of VICAP VI DVP port numbers.
Definition:
    VICAP_VI_DVP_PORT0 = 0,
    VICAP_VI_DVP_PORT1 = 1,
    VICAP_VI_DVP_PORT2 = 2,
    VICAP_VI_DVP_PORT_MAX,
} k_vicap_vi_dvp_port;
Members:
Member Name
VICAP_VI_DVP_PORT0
DVP port 0
VICAP_VI_DVP_PORT1
DVP port 1
VICAP_VI_DVP_PORT2
DVP port 2
Notes:
  1. By default, port 0 corresponds to CSI0, port 1 corresponds to CSI1, and port 2 corresponds to CSI2.
  2. Only port 0 supports HDR sensors. When using HDR mode, it must be bound to DVP port 0.
  3. To change the port mapping relationship, binding operations are required.
k_vicap_vi_flash_mode#
Description: Definition of VICAP flash light control modes.
Definition:
    VICAP_FLASH_NORMAL_PWM = 2,
    VICAP_FLASH_DISABLE = 3, /**< disable flash light */
} k_vicap_vi_flash_mode;
Members:
Member Name
VICAP_FLASH_FOLLOW_STROBE
Controlled by strobe signal
VICAP_FLASH_FOLLOW_STROBE_BASE_PWM
Controlled by strobe signal based on PWM mode
Controlled by PWM signal
VICAP_FLASH_DISABLE
Disabled
Notes:
k_vicap_img_window#
Description: Definition of VICAP image window.
Definition:
    k_u16 h_start;
    k_u16 v_start;
    k_u16 width;
    k_u16 height;
} k_vicap_img_window;
Members:
Member Name
h_start
Horizontal start position
v_start
Vertical start position
Image width
Image height
k_vicap_work_mode#
Description: Definition of VICAP work modes.
Definition:
    VICAP_WORK_ONLINE_MODE,
    VICAP_WORK_OFFLINE_MODE,
    VICAP_WORK_ONLY_MCM_MODE,
} k_vicap_work_mode;
Members:
Member Name
Online mode
Offline mode
Only work in MCM mode
Notes:
When supporting multiple camera inputs, it must be specified as offline mode. When configuring VICAP_WORK_ONLY_MCM_MODE, the dumped image can only use the YUV444 format.
k_vicap_sensor_info#
Description: VICAP sensor configuration information.
Definition:
    const char *sensor_name;
    k_vicap_csi_num csi_num; /**< CSI number that the sensor connects to */
    k_vicap_mipi_lanes mipi_lanes; /**< MIPI lanes that the sensor connects to */
    k_vicap_data_source source_id; /**< Source ID that the sensor uses */
    k_bool is_3d_sensor;
    k_vicap_hdr_mode hdr_mode;
} k_vicap_sensor_info;
Members:
Member Name
sensor_name
Sensor name
csi_num
mipi_lanes
Number of MIPI lanes used by the sensor
source_id
VICAP data source ID used by the sensor
is_3d_sensor
Whether it is a 3D sensor
phy_freq
PHY frequency
data_type
MIPI CSI data type
hdr_mode
HDR mode
flash_mode
Flash light configuration mode
sensor_type
k_vicap_dump_format#
Description: VICAP dump data frame format.
Definition:
    VICAP_DUMP_YUV = 0,
    VICAP_DUMP_RGB = 1,
    VICAP_DUMP_RAW = 2,
    VICAP_DUMP_YUV444 = 3,
} k_vicap_dump_format;
Members:
Member Name
VICAP_DUMP_YUV
Dump YUV data
VICAP_DUMP_RGB
Dump RGB data
VICAP_DUMP_RAW
Dump RAW data
VICAP_DUMP_YUV444
Dump YUV444 data
k_vicap_dev_attr#
Description: VICAP device attributes.
Definition:
    k_vicap_window acq_win;
    k_vicap_work_mode mode;
    k_u32 capture_frame;
    k_bool dw_enable;
    k_u32 buffer_num;
    k_u32 buffer_size;
    k_vicap_mirror mirror;
} k_vicap_dev_attr;
Members:
Member Name
acq_win
Image capture window
VICAP work mode. When supporting multiple camera inputs, it must be specified as offline mode.
pipe_ctrl
ISP pipeline control switch
capture_frame
Number of frames to capture, range [0,1023], 0: continuous capture
sensor_info
dw_enable
Dewarp enable (refer to K230_SDK_Dewarp Usage Guide.md)
buffer_num
Number of buffers for receiving sensor data in offline mode
buffer_size
Buffer size for receiving sensor data in offline mode
mirror
Sensor mirror function
Notes:
For low-memory application scenarios, it is recommended to disable the 3DNR module to reduce memory usage. To disable, set pipe_ctrl.bits.dnr3_enable to 0 when setting device attributes.
k_vicap_chn_attr#
Description: VICAP channel attributes.
Definition:
    k_vicap_window out_win;
    k_vicap_window crop_win;
    k_vicap_window scale_win;
    k_bool crop_enable;
    k_bool scale_enable;
    k_bool chn_enable;
    k_pixel_format pix_format;
    k_u32 buffer_num;
    k_u32 buffer_size;
    k_u8 alignment;
} k_vicap_chn_attr;
Members:
Member Name
out_win
Output window size
crop_win
Crop window size
scale_win
Scale window size
crop_enable
Crop enable
scale_enable
Scale enable
chn_enable
Channel enable
pix_format
Output pixel format
buffer_num
Number of buffers used by the channel
buffer_size
Buffer size
alignment
Buffer alignment method
k_vicap_mirror#
Description: VICAP sensor mirror function.
Definition:
    VICAP_MIRROR_NONE = 0,
    VICAP_MIRROR_HOR = 1,
    VICAP_MIRROR_VER = 2,
    VICAP_MIRROR_BOTH = 3,
} k_vicap_mirror;
Members:
Member Name
VICAP_MIRROR_NONE
No mirror for the sensor
VICAP_MIRROR_HOR
Horizontal mirror for the sensor
VICAP_MIRROR_VER
Vertical mirror for the sensor
VICAP_MIRROR_BOTH
Horizontal and vertical mirror for the sensor
Notes:
Sensor#
The related data type definitions of this functional module are as follows:
k_sensor_bayer_pattern#
Definition: Definition of Bayer pattern output by the sensor.
    BAYER_RGGB = 0,
    BAYER_GRBG = 1,
    BAYER_GBRG = 2,
    BAYER_BGGR = 3,
    BAYER_BUTT
} k_sensor_bayer_pattern;
Members:
Member Name
BAYER_RGGB
RGGB pattern
BAYER_GRBG
GRBG pattern
BAYER_GBRG
GBRG pattern
BAYER_BGGR
BGGR pattern
k_sensor_exp_frame_type#
Description:
Definition:
    SENSOR_EXPO_FRAME_TYPE_MAX
} k_sensor_exp_frame_type;
Members:
Member Name
SENSOR_EXPO_FRAME_TYPE_1FRAME
Linear mode, single-frame exposure
SENSOR_EXPO_FRAME_TYPE_2FRAMES
2-frame HDR exposure mode
SENSOR_EXPO_FRAME_TYPE_3FRAMES
3-frame HDR exposure mode
SENSOR_EXPO_FRAME_TYPE_4FRAMES
4-frame HDR exposure mode
k_sensor_exposure_param#
Description: Definition of sensor exposure parameters.
Definition:
    k_u8 exp_frame_type;
} k_sensor_exposure_param;
Members:
Member Name
exp_frame_type
Exposure type
gain
Exposure gain
exp_time
Exposure time
k_sensor_intg_time#
Description: Definition of sensor exposure time.
Definition:
} k_sensor_intg_time;
Members:
Member Name
exp_frame_type
Exposure type
intg_time
Integration time
k_sensor_gain#
Description: Definition of exposure gain.
Definition:
} k_sensor_gain;
Members:
Member Name
exp_frame_type
Exposure type
gain
Exposure gain
k_sensor_size#
Description: Definition of sensor-supported image sizes.
Definition:
    k_u32 bounds_width;
    k_u32 bounds_height;
    k_u32 top;
    k_u32 left;
    k_u32 width;
    k_u32 height;
} k_sensor_size;
Members:
Member Name
bounds_width
Boundary width
bounds_height
Boundary height
top
Top boundary
left
Left boundary
Width
Height
k_sensor_ae_info#
Description: AE parameter configuration.
Definition:
    k_u16 frame_length;
    k_u16 cur_frame_length;
    float one_line_exp_time;
    k_u32 gain_accuracy;
    float min_gain;
    float max_gain;
    float gain_increment;
    k_u16 max_long_integration_line;
    k_u16 min_long_integration_line;
    k_u16 max_integration_line;
    k_u16 min_integration_line;
    k_u16 max_vs_integration_line;
    k_u16 min_vs_integration_line;
    float max_long_integration_time;
    float min_long_integration_time;
    float max_integration_time;
    float min_integration_time;
    float max_vs_integration_time;
    float min_vs_integration_time;
    float cur_integration_time;
    float cur_long_gain;
    float cur_long_again;
    float cur_long_dgain;
    float cur_gain;
    float cur_again;
    float cur_dgain;
    float cur_vs_gain;
    float cur_vs_again;
    float cur_vs_dgain;
    k_sensor_gain_info long_gain;
    k_sensor_gain_info gain;
    k_sensor_gain_info vs_gain;
    k_sensor_gain_info a_gain;
    k_sensor_gain_info a_vs_gain;
    k_sensor_gain_info d_gain;
    k_sensor_gain_info d_vs_gain;
    k_u32 max_fps;
    k_u32 min_fps;
    k_u32 cur_fps;
    k_sensor_auto_fps afps_info;
    k_u32 hdr_ratio;
} k_sensor_ae_info;
Members:
Member Name
frame_length
Frame length
cur_frame_length
Current frame length
one_line_exp_time
Line exposure time (unit: s)
gain_accuracy
Gain accuracy
min_gain
Minimum gain
max_gain
Maximum gain
integration_time_increment
Integration time increment
gain_increment
Gain increment
Maximum long frame integration line
Minimum long frame integration line
Maximum mid frame integration line
Minimum mid frame integration line
Maximum short frame integration line
Minimum short frame integration line
Maximum long frame integration time
Minimum long frame integration time
Maximum mid frame integration time
Minimum mid frame integration time
Maximum short frame integration time
Minimum short frame integration time
cur_long_integration_time
Current long frame integration time
Current frame integration time
cur_vs_integration_time
Current short frame integration time
cur_long_gain
Current long frame gain
cur_long_again
Current long frame analog gain
cur_long_dgain
Current long frame digital gain
cur_gain
Current frame gain
cur_again
Current frame analog gain
cur_dgain
Current frame digital gain
cur_vs_gain
Current short frame gain
cur_vs_again
Current short frame analog gain
cur_vs_dgain
Current short frame digital gain
long_gain
Long frame gain
gain
Mid frame gain
vs_gain
Short frame gain
a_long_gain
Long frame analog gain
a_gain
Mid frame analog gain
a_vs_gain
Short frame analog gain
d_long_gain
Long frame digital gain
d_gain
Mid frame digital gain
d_vs_gain
Short frame digital gain
max_fps
Maximum frame rate
min_fps
Minimum frame rate
cur_fps
Current frame rate
hdr_ratio
HDR ratio
k_sensor_mode#
Description: Sensor mode parameters.
Definition:
    k_u32 index;
    k_sensor_size size;
    k_u32 fps;
    k_u32 hdr_mode;
    k_u32 stitching_mode;
    k_u32 bit_width;
    k_u32 bayer_pattern;
    k_sensor_mipi_info mipi_info;
    k_sensor_ae_info ae_info;
    k_sensor_reg_list *reg_list;
} k_sensor_mode;
Members:
Member Name
index
Current mode index
sensor_type
size
Sensor size for the current mode
fps
Frame rate
hdr_mode
HDR mode
stitching_mode
HDR stitching mode
bit_width
Output data width
bayer_pattern
Bayer pattern
mipi_info
MIPI parameter information
ae_info
AE parameter information
reg_list
Register configuration list for the current mode
otp_type
OTP type: sensor-specific and user-specific
otp_date
OTP data
k_sensor_otp_date#
Description: Sensor OTP parameters.
Definition:
    k_u8 otp_type;
    k_u8 otp_date[20];
} k_sensor_otp_date;
Members:
Member Name
otp_type
otp_date
OTP data
MAPI#
  • [kd_mapi_vicap_get_sensor_fd]
  • [kd_mapi_vicap_get_sensor_info]
  • [kd_mapi_vicap_set_dev_attr]
  • [kd_mapi_vicap_set_chn_attr]
  • [kd_mapi_vicap_start]
  • [kd_mapi_vicap_stop]
  • [kd_mapi_vicap_dump_frame]
  • [kd_mapi_vicap_release_frame]
  • [kd_mapi_vicap_set_vi_drop_frame]
  • [kd_mapi_vicap_set_mclk]
  • [kd_mapi_vicap_tuning]
  • [kd_mapi_isp_ae_get_roi]
  • [kd_mapi_isp_ae_set_roi]
  • [kd_mapi_sensor_otpdata_get]
API#
kd_mapi_vicap_get_sensor_fd#
Description:
Get the file descriptor for the specified sensor.
Syntax:
Parameters:
Parameter Name
Input/Output
sensor_attr
Sensor attributes
Input & Output
Return Value:
Success
Non-zero
Failure, refer to error code definitions
Chip Differences:
Requirements:
  • Header file: mapi_vicap_api.h
  • Library file: libmapi.a
kd_mapi_vicap_get_sensor_info#
Description:
Get sensor configuration information based on the specified sensor configuration type. Refer to kd_mpi_vicap_get_sensor_info. Put sensor_type into sensor_info.sensor_type, usage is the same.
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_set_dev_attr#
Description:
Set VICAP device attributes. Refer to kd_mpi_vicap_set_dev_attr. Put dev_num into dev_info.vicap_dev, usage is the same.
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_set_chn_attr#
Description:
Set VICAP channel attributes. Refer to kd_mpi_vicap_set_chn_attr. Put dev_num into chn_info.vicap_dev, and chn_num into chn_info.vicap_chn, usage is the same.
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_start#
Description:
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_stop#
Description:
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_dump_frame#
Description:
Dump VICAP data based on the specified device and output channel. Refer to kd_mpi_vicap_dump_frame.
Syntax:
k_s32 kd_mapi_vicap_dump_frame(k_vicap_dev dev_num, k_vicap_chn chn_num, k_vicap_dump_format format, k_video_frame_info *vf_info, k_u32 milli_sec)
Parameters:
Parameter Name
Input/Output
dev_num
VICAP device number
Input
chn_num
Input
format
Dump data type
Input
vf_info
Output
milli_sec
Timeout duration
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_release_frame#
Description:
Release the dumped data frame. Refer to kd_mpi_vicap_dump_release.
Syntax:
Parameters:
Parameter Name
Input/Output
dev_num
VICAP device number
Input
chn_num
Input
vf_info
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_set_vi_drop_frame#
Description:
Set hardware frame dropping. Refer to kd_mpi_vicap_set_vi_drop_frame.
Syntax:
Parameters:
Parameter Name
Input/Output
csi
VICAP device number
Input
frame
m
Input
n
Input
HDR mode
Input
enable
Enable or disable
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_set_mclk#
Description:
Set the MCLK frequency. Refer to kd_mpi_vicap_set_mclk.
Syntax:
Parameters:
Parameter Name
Input/Output
id
MCLK ID
Input
sel
Clock source
Input
mclk_div
Division factor
Input
mclk_en
Enable or disable
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_vicap_tuning#
Description:
Handle commands sent by the tuning client.
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_isp_ae_get_roi#
Description:
Get AE ROI configuration.
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
  • Header file: mapi_isp_api.h
kd_mapi_isp_ae_set_roi#
Description:
Set AE ROI.
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
kd_mapi_sensor_otpdata_get#
Description:
Get sensor OTP data.
Syntax:
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Error Codes#
Table 41 VICAP API Error Codes
Error Code
Macro Definition
0xA0158001
K_ERR_VICAP_INVALID_DEVID
Device ID out of valid range
0xA0158002
K_ERR_VICAP_INVALID_CHNID
Channel ID out of valid range
0xA0158003
K_ERR_VICAP_ILLEGAL_PARAM
Parameter out of valid range
0xA0158004
K_ERR_VICAP_EXIST
Attempt to create an already existing device, channel, or resource
0xA0158005
K_ERR_VICAP_UNEXIST
Attempt to use or destroy a non-existent device, channel, or resource
0xA0158006
K_ERR_VICAP_NULL_PTR
Null pointer in function parameters
0xA0158007
K_ERR_VICAP_NOT_CONFIG
Not configured before use
0xA0158008
K_ERR_VICAP_NOT_SUPPORT
Unsupported parameter or function
0xA0158009
K_ERR_VICAP_NOT_PERM
Operation not allowed, such as trying to modify static configuration parameters
0xA015800C
K_ERR_VICAP_NOMEM
Memory allocation failure, such as insufficient system memory
0xA015800D
K_ERR_VICAP_NOBUF
Buffer allocation failure, such as requesting a data buffer that is too large
0xA015800E
K_ERR_VICAP_BUF_EMPTY
No data in the buffer
0xA015800F
K_ERR_VICAP_BUF_FULL
Data buffer full
0xA0158010
K_ERR_VICAP_NOTREADY
System not initialized or relevant module not loaded
0xA0158011
K_ERR_VICAP_BADADDR
Address out of valid range
0xA0158012
K_ERR_VICAP_BUSY
VICAP system busy
Debug Information#
For VICAP memory management and system binding debug information, refer to the “K230 System Control API Reference”.
