K230 SDK Release Notes#
! cover
Version Information#
Product
Version
Release Date
K230 SDK
V1.6.0
2024-6-14
Supported Hardware#
The K230 platform supports mainboards like K230 USIP LP3 EVB and CanMV-K230. For specific hardware information, refer to the documentation directory: 00_hardware.
Version Usage Restrictions#
The current SDK’s memory layout on USIP LP3 EVB and CanMV-K230 is as shown below:
! EVB
Figure-1 SDK Memory Layout
You can configure the memory regions for each module by entering make menuconfig under the k230_sdk directory and selecting Memory->Configuration. Currently, configuring the memory for parameter areas and inter-core communication areas is not supported.
Version Feature Statistics#
Multimedia#
ID
Supported Version
Feature Summary
Feature Description
Remarks
K230 SDK V0.5
venc
H264/H265/JPEG encoding
K230 SDK V0.5
vdec
H264/H265/JPEG decoding
3
K230 SDK V0.5
vicap bind venc
vicap input bound to venc output
4
K230 SDK V0.5
vdec bind vo
vdec bound to vo for image output
5
K230 SDK V0.5
venc_2d
OSD overlay after encoding
6
K230 SDK V0.5
nonai_2d
OSD overlay
7
K230 SDK V0.5
i2s audio input
Sampling precision (16/24/32), sampling rate (8k-192k), timestamp (us), dual-channel, configurable samples per frame.
8
K230 SDK V0.5
pdm audio input
Sampling precision (16/24), sampling rate (8k-192k), oversampling (32/64/128), single/dual-channel, timestamp (us), configurable samples per frame.
9
K230 SDK V0.5
i2s audio output
Sampling precision (16/24/32), sampling rate (8k-192k), dual-channel, configurable samples per frame.
K230 SDK V0.5
built-in audio codec
Supports adc, dac, sampling precision (16/24), sampling rate (8k-192k)
11
K230 SDK V0.5
ai(i2s) bind ao(i2s)
ai bound to ao, i2s audio capture to i2s audio output loopback
12
K230 SDK V0.5
ai(pdm) bind ao(i2s)
ai bound to ao, pdm audio capture to i2s audio output loopback
13
K230 SDK V0.6
venc
Multi-channel encoding, rotation, and mirroring
14
K230 SDK V0.6
venc_2d
Frame drawing
15
K230 SDK V0.6
venc MAPI
VI->VENC->save file on small core
16
K230 SDK V0.6
aenc
Audio encoding, built-in g711a/u
17
K230 SDK V0.6
adec
Audio decoding, built-in g711a/u
18
K230 SDK V0.6
ai bind aenc
ai bound to aenc, collecting encoded data
19
K230 SDK V0.6
adec bind ao
adec bound to ao, playing decoded audio output
20
K230 SDK V0.6
audio 3a
AEC (Echo Cancellation), ANS (Noise Suppression), AGC (Automatic Gain Control)
21
K230 SDK V0.7
venc gop
Supports setting encoding GOP
22
K230 SDK V0.7
venc mirror
Supports setting encoding horizontal and vertical flip
23
K230 SDK V0.7
venc idr
Supports enabling/disabling encoding IDR frames
24
K230 SDK V0.7
venc multi channel
mapi_venc_2-channel h264 encoding
25
K230 SDK V0.7
audio i2s mapi
mapi-audio_i2S captures audio, encodes it, and passes it to the main core
26
K230 SDK V0.7
audio enc mapi
mapi-audio_small core encodes the file, passes it to the main core for decoding and playback
27
K230 SDK V0.7
audio volume
Adds interface for digital and analog volume control of the built-in audio codec.
28
K230 SDK V0.7
mapi rtsp
mapi-network transmission-rtsp audio and video streaming
29
K230 SDK V0.8
mapi vdec
Small core video encoded file passed to the main core for decoding and playback
30
K230 SDK V0.8
venc mpi
31
K230 SDK V0.8
vdec mpi
Supports downscale
32
K230 SDK V0.8
dpu demo
Screen display depth map: vicap->dma->dpu->vo
32
K230 SDK V0.8
Voice intercom demo
Adds voice intercom demo
33
K230 SDK V0.9
Cat-eye poc
Remote cat-eye, realizing visual intercom, voice change, recording, human detection, and snapshot functions.
34
K230 SDK V1.0
Cat-eye poc
1. Adds UI control on the cat-eye device side. 2. Adds local cat-eye voice intercom functionality. 3. Changes the mobile phone recording feature to be implemented on the device side, always recording. 4.
34
K230 SDK V1.0
Cat-eye poc
Added playback function on the cat-eye device side.
35
K230 SDK V1.2
Cat-eye poc
Changed to nor flash boot
35
K230 SDK V1.3
Depth camera poc
Added depth camera poc function, cat-eye poc changed to SD card boot
36
K230 SDK V1.4
nonai_2d API
Added nonai_2d CSC function mpi and mapi
37
K230 SDK V1.4
YUV Sensor Demo
Added YUV sensor demo, 3-way YUV sensor input, 3-way streaming and display
Image#
ID
Supported Version
Feature Summary
Feature Description
Remarks
K230 SDK V0.5
vicap
Supports sensor image capture (OV9732, OV9286)
K230 SDK V0.5
AE
Supports AE auto exposure
3
K230 SDK V0.5
vicap bind vo
vicap bound to vo for image output
4
K230 SDK V0.5
GPU drawing
Vector drawing and filling (lines, quadratic Bezier curves, cubic Bezier curves, elliptical curves), linear gradient, color lookup table, image composition/blending, BLIT
5
K230 SDK V0.5
Image tuning
Tuning tool connects to the development board via network or serial port for image tuning. Black level correction, lens shading correction, color calibration, AWB, CAC, gamma
6
K230 SDK V0.5
display bind
Supports vo and vicap, vo and vdec binding
7
K230 SDK V0.5
display
Supports OSD and YUV display, supports frame dump function, supports configurable DSI and vo timing, supports frame insertion function
8
K230 SDK V0.6
Image tuning
Tuning tool can configure sensor registers
9
K230 SDK V0.6
Timestamp, frame number
Supports timestamp and frame number
K230 SDK V0.6
ISP+KPU Demo
Face detection linkage demo
11
K230 SDK V0.7
dewarp
Added dewarp function for distortion correction
12
K230 SDK V0.7
Face AE
Added FaceAE function and corresponding FaceAE demo
13
K230 SDK V0.7
Added Imx335
Added Imx335 sensor driver and demo
14
K230 SDK V0.8
Added DRM
Added DRM driver and demo for Linux small core
15
K230 SDK V0.8
Added LVGL
Added LVGL and demo for Linux small core
16
K230 SDK V0.8
Fast start APP
Fast start APP sensor changed to Imx335 (with crystal oscillator)
17
K230 SDK V0.9
mcm
Supports up to three sensors
18
K230 SDK V0.9
display mapi
Added video output MAPI
19
K230 SDK V1.0
Debug-Dump sensor raw
Supports dumping sensor raw data
20
K230 SDK V1.0
Debug-Frame count statistics
Supports total input and output frame count statistics
21
K230 SDK V1.0
dewarp-Split screen
Supports 2, 4 split screen output
22
K230 SDK V1.0
HDR
Supports HDR function, supports Imx335 2dol HDR
23
K230 SDK V1.1
MAPI
Added vicap MAPI
24
K230 SDK V1.1
HDR frequency change
Supports HDR frequency change
25
K230 SDK V1.1
Parameter export
Supports exporting isp dewarp parameters
26
K230 SDK V1.2
Added dictionary pen POC
27
K230 SDK V1.3
Added three-camera demo
Added demo for Canmv-K230 board with three cameras (ov5647) working simultaneously
28
K230 SDK V1.4
Vicap MCM only mode
Vicap MCM only mode adapted for YUV sensor
29
K230 SDK V1.4
linear mode supports adaptive
30
K230 SDK V1.5
GC2053
Added GC2053 driver
Platform#
ID
Supported Version
Function Overview
Function Description
Remarks
K230 SDK V0.5
Boot Peripherals
Supports eMMC, 1/4 wire SD card
K230 SDK V0.5
Big Core DPU Driver
Image input, output driver development; Basic functions, e.g., read parameters, support dynamic update of long-cycle parameters, output buffer, timestamp, algorithm, etc.; support pipeline binding
3
K230 SDK V0.5
Small Core UBOOT
DDR training, disk driver (eMMC, SD, SPI 1 wire); supports PUFs and gzip decompression
4
K230 SDK V0.5
Small Core SPI Driver
1 wire
5
K230 SDK V0.5
Small Core SDIO Driver
Supports SDIO0/1 connecting SDCard
6
K230 SDK V0.5
Small Core USB (UVC) Driver
Supports UVC driver (K230 chip as slave)
7
K230 SDK V0.5
Small Core GPIO Driver
Supports each IO as a separate logical resource allocation; supports IO and interrupt
8
K230 SDK V0.5
Small Core Disk and File System
Supports SDIO0/1 connecting SDCard, supports SDIO0/1 connecting eMMC; supports ext2/3/4, FAT32 file system
9
K230 SDK V0.5
I2C Driver
Big and small core I2C bus driver
K230 SDK V0.5
UART Driver
Big and small core UART driver
11
K230 SDK V0.5
UVC Basic Demo
UVC camera, using the board as a camera
12
K230 SDK V0.5
GSDMA (Big Core Driver)
Supports using GDMA for image transfer, through configuration of channel attributes to achieve image rotation and mirroring, transfer multiple image formats (e.g., YUV400, YUV420, YUV444), transfer images with multiple pixel bit widths (e.g., 8bit, 10bit, 16bit); supports using SDMA for data transfer, supports 1D mode and 2D mode transfer; supports pipeline binding
13
K230 SDK V0.6
Big Core GPIO Driver
Supports independent configuration and use of IO functions, independent configuration and triggering of interrupts, added hardware mutex lock to ensure mutual exclusion of register access
14
K230 SDK V0.6
Boot Peripherals
Supports SPI NOR flash image generation and boot
15
K230 SDK V0.6
UBOOT SPI NOR Flash Driver
Supports 8-wire DMA
16
K230 SDK V0.6
Big Core ADC Driver
Supports ADC voltage reading
17
K230 SDK V0.7
Big and Small Core WDT Driver
Supports watchdog reset SOC
18
K230 SDK V0.7
Big Core SPI Driver
Supports SPI single-wire mode, supports NAND flash
19
K230 SDK V0.7
Supports SPI single-wire, 8-wire mode, supports NOR flash
20
K230 SDK V0.7
Quick Boot
SDK defaults to quick boot, non-quick boot version can disable CONFIG_QUICK_BOOT macro via make menuconfig; quick boot version UBOOT will not enter command line
21
K230 SDK V0.7
Secure Image
SDK defaults to not generating secure image, can configure CONFIG_GEN_SECURITY_IMG via make menuconfig to generate secure image
22
K230 SDK V0.7
UVC Basic Demo
Added support for H264 format, currently has bugs, can only run for a short time
23
K230 SDK V0.7
DPU, GSDMA
Buffer quantity configurable
24
K230 SDK V0.8
Big Core Timer, RTC, PWM
Added timer driver and demo for big core; added PWM driver and demo for big core; added RTC driver and demo for big core
25
K230 SDK V0.8
SPI NAND Support
Small core (UBOOT, Linux) supports 4-wire SPI NAND driver, SDK supports boot from SPI NAND
26
K230 SDK V0.8
UVC Basic Demo
UVC supports IMX335 camera, UVC supports MJPEG format
27
K230 SDK V0.8
SPI NOR Adds Face Feature and Other Parameter Partitions
SPI NOR adds face feature, AI model, calibration parameters, big core app, speckle, quick boot parameters and other parameter partitions; when booting from SPI NOR, UBOOT will parse and load each partition data
28
K230 SDK V0.9
Small Core PWM Driver
Supports small core PWM driver
29
K230 SDK V0.9
Small Core ADC Driver
Supports small core ADC driver
30
K230 SDK V0.9
Supports K230D Development Board
SDK supports K230D development board (SD card boot)
31
K230 SDK V0.9
OTA
Supports OTA upgrade
32
K230 SDK V1.0
Big Core FFT
Supports FFT driver
33
K230 SDK V1.0.1
Supports CanMV-K230 Development Board
SDK supports CanMV-K230 development board (SD card boot)
34
K230 SDK V1.1
Small Core WiFi Driver
Small core supports AP6256 driver
35
K230 SDK V1.1
Small Core Tri-Color LED Driver
Small core supports I2S interface WS2812 driver
36
K230 SDK V1.1
Small Core SPI LCD Driver
Small core supports SPI interface ST7735S 0.96-inch LCD screen driver
37
K230 SDK V1.1
Burntool V2
Removed full image burning page, added loader_sip.bin support for SIP burning, for details see K230_SDK_Burntool Usage Guide.md
38
K230 SDK V1.1
USB Port Usage
USB1 fixed as host mode, can connect USB-ETH or U disk and other peripherals, connect pin 3 and pin 4 of J5 header on EVB with jumper cap to enable power supply to peripherals; USB0 used for USB gadget testing and USB upgrade, no longer connect pin 1 and pin 2 of J5 header on EVB with jumper cap
39
K230 SDK V1.2
CanMV WiFi AP6212
CanMV supports AP6212
40
K230 SDK V1.2
CanMV Only Linux
CanMV adds configuration for running vector Linux on big core (k230_canmv_only_linux_defconfig)
41
K230 SDK V1.3
Added Debian and Ubuntu Release Images
Added Debian and Ubuntu release images for CanMV
42
K230 SDK V1.3
OTA
Buildroot adds swupdate OTA upgrade function, supports dual partition switch upgrade (requires dual partition boot scheme)
Refer to description in k230_sdk/tools/ota/README
43
K230 SDK V1.5
USB to Ethernet
Fixed instability issue of USB to Ethernet network
44
K230 SDK V1.5
Touch Control
Added touch control for LCD screen
45
K230 SDK V1.5
CanMV 2.0
Supports CanMV-K230-V2.0 board
46
K230 SDK V1.6
01Studio-CanMV-K230
Supports 01Studio-CanMV-K230 board
47
K230 SDK V1.6
Supports RTT Only System
Supports RTT only single system
Architecture#
ID
Supported Version
Function Overview
Remarks
K230 SDK V0.5
Multimedia Memory Management
Multimedia memory management driver, MPI, MAPI; video buffer pool driver, MPI, MAPI
K230 SDK V0.5
Log Management
Multimedia log management driver, MPI, MAPI
3
K230 SDK V0.5
System Binding
Multimedia system binding driver, MPI
4
K230 SDK V0.5
Big Core Multimedia Debugging
Provides proc file system for debugging
5
K230 SDK V0.5
Inter-Core Communication
Inter-core communication driver
6
K230 SDK V0.5
Inter-Core Control Communication
IPCMSG library
7
K230 SDK V0.5
Inter-Core Data Communication
DATAFIFO library
8
K230 SDK V0.5
Shared File System
sharefs
Small core as server, big core as client
9
K230 SDK V0.5
System Control
Big and small core clock power and reset driver
K230 SDK V0.5
KPU
KPU driver
11
K230 SDK V0.5
Big Core System Debugging
JTAG debugging; local serial port
12
K230 SDK V0.5
Small Core System Debugging
JTAG debugging, serial port debugging, network port debugging, CPU usage statistics and analysis, performance debugging methods, debugging and log output ports (physical serial port), kernel and exception information output, dump, debug version
perf is not configured by default in the kernel and buildroot
13
K230 SDK V0.7
Software SHA256
Added software implementation of SHA256 under big core MPP
14
K230 SDK V0.7
OTP Read/Write Function
Added OTP read/write function in big core rt-smart, added OTP read function in small core Linux
15
K230 SDK V0.7
Tsensor Read Function
Added Tsensor read function in big core rt-smart, added Tsensor read function in small core Linux, used to read chip junction temperature
16
K230 SDK V0.7
TRNG Read Function
Added TRNG read function in small core Linux
17
K230 SDK V0.7
Quick Start Demo
Added quick start face detection demo for big core
18
K230 SDK V0.7
PMU Function
Added PMU standby and wake-up function for small core Linux
19
K230 SDK V0.8
Door Lock POC
Added POC door lock function in big core, added UI function in small core, register and recognize faces via UI interface or SD card
20
K230 SDK V0.9
Door Lock POC
Supports ov9286, face detection and recognition (including IR and speckle liveness detection, speckle includes DPU depth extraction)
21
K230 SDK V0.9
Encryption/Decryption
Added AES-GCM encryption/decryption function for small core Linux
22
K230 SDK V0.9
Power Consumption Control
Added chip clock/power domain management in uboot, added power consumption control for CPU1, DPU, VPU, KPU, and display in big core rt-smart, added power consumption control for display in small core Linux
23
K230 SDK V1.0
Door Lock POC
Added face feature encryption/decryption function
24
K230 SDK V1.0
SH256 Driver
Added hardware SH256 driver for both big and small cores
25
K230 SDK V1.1
Big Core Encryption/Decryption Driver
Added hardware AES-GCM driver and SM4-ECB/CBC/CFB/OFB/CTR driver for big core
26
K230 SDK V1.2
Door Lock OTA Function
Added door lock OTA function
27
K230 SDK V1.3
OTP Space Adjustment
Adjusted the OTP space operated by SDK, users can read/write 768 bytes. The remaining space is reserved for chip manufacturers
Others#
ID
Supported Version
Function Overview
Remarks
K230 SDK V0.5
AI Demo
Provides three AI demos: door_lock, object_detect, image_classify
K230 SDK V0.5
AiW4211LV10 WiFi Driver
Supports network data communication; supports control command sending
3
K230 SDK V0.6
AiW4211LV10 WiFi Firmware
Firmware compatible with commands and network configuration, supports reconnection after disconnection, supports K230 level detection and wake-up
4
K230 SDK V0.6
Touch Screen Support
Touch screen support
5
K230 SDK V0.7
Software Image
SDK compilation will generate demo executable files, but by default not packaged into the image; secure image files are not generated by default, can be manually configured
6
K230 SDK V0.7
Toolchain
Big core toolchain version updated to: riscv64-unknown-linux-musl-rv64imafdcv-lp64d-20230420.tar.bz2
7
K230 SDK V0.8
Software Image
When packaging Emmc/Sdcard images, the big core demos will be packaged into the small core/sharefs
8
K230 SDK V0.8
Demo
Modified related demos to adapt to different camera modules, such as encoding/UVC. Specific usage can be found in the “K230 SDK Demo Usage Guide”
