K230 System Control MAPI Reference#
Directory#
preface#
This document mainly introduces the functions and usage of the system control module in MAPI, and the functions and usage of other modules will be discussed in their own special documents.
Reader object#
Technical Support Engineer
Software Development Engineer
Definition of acronyms#
abbreviation |
illustrate |
cdk |
Media Process Platform |
.vb |
Video buffer |
Revision history#
Document version number |
Modify the description |
Author |
date |
Initial edition |
Haibo Hao |
2023/5/4 |
According to the characteristics of the k230 chip, the system control completes the reset and basic initialization of each component of the hardware, and is responsible for completing the inter-core communication establishment of the cdk (Media Process Platform media processing platform) system, the initialization and deinitialization of multimedia memory management and other modules.
Function Description#
The feature of MAPI is cross-OS calling, and the same API can be called on both large and little cores of the K230 to achieve the required functions. The overall system architecture is shown in the figure below
For details on binding and memory management in MAPI, please refer to the document “K230 System Control API Reference V1.0”
API Reference#
kd_mapi_sys_init#
【Description】
Initialize system resources and establish a message communication pipeline between the two cores. In order to establish a dual-core connection, services running on each operating system need to call this interface during initialization to establish a connection before intercore communication can take place.
【Syntax】
【Parameters】
none
【Return value】
Return value |
succeed |
Non-0 |
Failed, the value of which is described in error code |
【Differences】
none.
【Requirement】
Header file: mapi_sys_api.h
Library file: libmapi.a
【Note】
This function needs to be called before calling the kd_mapi_media_init
【Example】
none
【See Also】
none
kd_mapi_sys_deinit#
【Description】
To initialize system resources, disconnect the message communication pipeline between the two cores.
【Syntax】
【Parameters】
none
【Return value】
Return value |
succeed |
Non-0 |
【Differences】
none.
【Requirement】
【Note】
When the kd_mapi_sys_init is not called, the call to this MAPI returns success.
【Example】
none
【See Also】
none
kd_mapi_media_init#
【Description】
Initialize multimedia related resources. Configure the number and size of VBs
【Syntax】
k_s32 kd_mapi_media_init(const [k_mapi_media_attr_t](#k_mapi_media_attr_t) *media_attr);
【Parameters】
Parameter name |
Input/output |
media_attr |
Media property pointer |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Differences】
none.
【Requirement】
【Note】
none
【Example】
none
【See Also】
none
kd_mapi_media_deinit#
【Description】
Go and initialize multimedia related resources.
【Syntax】
【Parameters】
none
【Return value】
Return value |
succeed |
Non-0 |
【Differences】
none.
【Requirement】
【Note】
none
【Example】
none
【See Also】
none
kd_mapi_alloc_buffer#
【Description】
Allocate memory for MMZ in user mode (with cache)
【Syntax】
【Parameters】
Parameter name |
Input/output |
phys_addr |
The physical address of the buffer |
output |
virt_addr |
The virtual address of buffer |
output |
only |
The length of the buffer |
input |
name |
The name of buffer |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Differences】
none.
【Requirement】
【Note】
The virtual and physical addresses of the buffer are mapped
After allocating memory, use cat/proc/umap/media-mem under the large kernel msh to see if the buffer is allocated successfully.
【Example】
none
【See Also】
none
kd_mapi_free_buffer#
【Description】
Frees the memory of the MMZ in user mode.
【Syntax】
【Parameters】
Parameter name |
Input/output |
phys_addr |
input |
virt_addr |
input |
only |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Differences】
none.
【Requirement】
【Note】
After freeing the memory, check whether the buffer is successfully freed under the large kernel side msh through cat /proc/umap/media-mem.
【Example】
none
【See Also】
none
kd_mapi_sys_get_vb_block#
【Description】
Gets a vb block in user mode.
【Syntax】
k_s32 kd_mapi_sys_get_vb_block(k_u32 \*pool_id, k_u64 \*phys_addr, k_u64 blk_size, const char\* mmz_name);
【Parameters】
Parameter name |
Input/output |
pool_id |
The ID number of the vb pool where the vb block resides |
output |
phys_addr |
The physical address of the vb block |
output |
blk_size |
The size of the vb block |
input |
mmz_name |
The name of the DDR where the vb pool resides |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Differences】
none.
【Requirement】
【Note】
If the user needs to fetch a block of the specified size from any of the public vb pools, set parameter 2 blk_size to the desired vb block size and specify the public vb pool on which DDR to obtain the vb block from. If there is no public vb pool on the specified DDR, the vb block will not be fetched. If mmz_name equals NULL, it means that the public vb pool on an unnamed DDR fetches vb blocks
When media initializes, if VB creates a vb pool in an unnamed DDR, it obtains a block of the specified size from any public vb pool, mmz_name set to NULL
【Example】
none
【See Also】
none
kd_mapi_sys_release_vb_block#
【Description】
A vb block is released in user mode.
【Syntax】
【Parameters】
Parameter name |
Input/output |
phys_addr |
output |
blk_size |
input |
【Return value】
Return value |
succeed |
Non-0 |
【Differences】
none.
【Requirement】
【Note】
After the obtained vb block is exhausted, this interface should be called to free the vb block.
【Example】
none
【See Also】
none
Data Type#
k_mapi_mod_id_e#
【Description】
Define the MAPI module ID
【Definition】
K_MAPI_MOD_SYS = 0,
K_MAPI_MOD_VI,
K_MAPI_MOD_VPROC,
K_MAPI_MOD_VENC,
K_MAPI_MOD_VDEC,
K_MAPI_MOD_VREC,
K_MAPI_MOD_VO,
K_MAPI_MOD_AI,
K_MAPI_MOD_AENC,
K_MAPI_MOD_ADEC,
K_MAPI_MOD_AREC,
K_MAPI_MOD_AO,
K_MAPI_MOD_VVI,
K_MAPI_MOD_VVO,
K_MAPI_MOD_DPU,
K_MAPI_MOD_VICAP,
K_MAPI_MOD_SENSOR,
K_MAPI_MOD_ISP,
K_MAPI_MOD_BUTT,
} k_mapi_mod_id_e;
【Members】
none
【Note】
none
【See Also】
none
k_mapi_media_config_t#
【Description】
Define the media configuration attribute structure
【Definition】
k_vb_config vb_config;
} k_mapi_media_config_t;
【Members】
Member Name |
vb_supp |
VB Additional Information Structure, see K230 System Control API Reference |
vb_config |
For the video buffer pool attribute structure, see K230 System Control API Reference |
【Note】
none
【See Also】
none
k_mapi_media_attr_t#
【Description】
Defines the media initialization attribute structure
【Definition】
} k_mapi_media_attr_t;
【Members】
Member Name |
media_config |
Media configuration attribute struct |
【Note】
none
【See Also】
none
Error codes#
Table 41
Error code |
Macro definitions |
0xb0008003 |
K_MAPI_ERR_SYS_ILLEGAL_PARAM |
Parameter error |
0xb0008006 |
K_MAPI_ERR_SYS_NULL_PTR |
Null pointer error |
0xb0008009 |
K_MAPI_ERR_SYS_NOT_PERM |
Operation is not allowed |
0xb0008010 |
K_MAPI_ERR_SYS_NOTREADY |
The device is not ready |
0xb0008012 |
K_MAPI_ERR_SYS_BUSY |
The system is busy |
0xb000800c |
K_MAPI_ERR_SYS_NOMEM |
Failed to allocate memory, such as low system memory |
