K230 System Control MAPI Reference#
The products, services, or features you purchase are subject to the commercial contracts and terms of Beijing Canaan Creative Information Technology Co., Ltd. (“the Company”, hereinafter) and its affiliates. All or part of the products, services, or features described in this document may not be within your purchase or usage scope. Unless otherwise stipulated in the contract, the Company does not make any express or implied statements or warranties regarding the accuracy, reliability, completeness, merchantability, fitness for a particular purpose, or non-infringement of any representations, information, or content in this document. Unless otherwise agreed, this document is for reference purposes only.
Trademark Statement#
Copyright © 2023 Beijing Canaan Creative Information Technology Co., Ltd. All rights reserved. No part of this document may be excerpted, copied, or disseminated in any form without the written permission of the Company.
Table of Contents#
This document mainly introduces the functions and usage of the system control module in MAPI. The functions and usage of other modules will be discussed in their respective dedicated documents.
Intended Audience#
Technical Support Engineers
Abbreviations#
Abbreviation |
mpp |
Media Process Platform |
vb |
video buffer |
Document Version |
Author |
Date |
Initial Version |
Haibo Hao |
2023/5/4 |
1. Overview#
1.1 Overview#
System control, based on the characteristics of the K230 chip, completes the reset and basic initialization of various hardware components. It is also responsible for establishing inter-core communication for the MPP (Media Process Platform) system and initializing and deinitializing modules such as multimedia memory management.
1.2 Function Description#
MAPI features cross-OS calls, enabling the same API to be called on both the big and small cores of the K230 to achieve the required functionality.
For specific details on binding and memory management in MAPI, please refer to the document “K230 System Control API Reference V1.0”.
2. API Reference#
2.1 kd_mapi_sys_init#
Description:
Initialize system resources and establish message communication channels between the two cores. To establish a dual-core connection, services running on each operating system need to call this interface during initialization to establish the connection, after which inter-core communication can be performed.
Syntax:
k_s32 kd_mapi_sys_init(void);
Parameters:
Return Values:
Return Value |
Success |
Non-zero |
Failure, see Error Codes for values |
Chip Differences:
Requirements:
Header file: mapi_sys_api.h
Library file: libmapi.a
Notes:
This function needs to be called before calling kd_mapi_media_init.
Related Topics:
2.2 kd_mapi_sys_deinit#
Description:
Deinitialize system resources and disconnect the message communication channels between the two cores.
Syntax:
k_s32 kd_mapi_sys_deinit(void);
Parameters:
Return Values:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
Notes:
If kd_mapi_sys_init has not been called, calling this API will return success.
Related Topics:
2.3 kd_mapi_media_init#
Description:
Initialize multimedia-related resources, mainly configuring the number and size of the video buffers (vb).
Syntax:
Parameters:
Parameter Name |
Input/Output |
media_attr |
Pointer to media attributes |
Input |
Return Values:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
Notes:
Related Topics:
2.4 kd_mapi_media_deinit#
Description:
Deinitialize multimedia-related resources.
Syntax:
Parameters:
Return Values:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
Notes:
Related Topics:
2.5 kd_mapi_alloc_buffer#
Description:
Allocate MMZ memory in user space (with cache).
Syntax:
Parameters:
Parameter Name |
Input/Output |
phys_addr |
Physical address of the buffer |
Output |
virt_addr |
Virtual address of the buffer |
Output |
len |
Length of the buffer |
Input |
name |
Name of the buffer |
Input |
Return Values:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
Notes:
The virtual address and physical address of the buffer are already mapped.
After allocating memory, check whether the buffer is successfully allocated on the big core side via
cat /proc/umap/media-mem.
Related Topics:
2.6 kd_mapi_free_buffer#
Description:
Free MMZ memory in user space.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phys_addr |
Input |
virt_addr |
Input |
len |
Input |
Return Values:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
Notes:
After freeing memory, check whether the buffer is successfully released on the big core side via cat /proc/umap/media-mem.
Related Topics:
2.7 kd_mapi_sys_get_vb_block#
Description:
Get a buffer block in user space.
Syntax:
Parameters:
Parameter Name |
Input/Output |
pool_id |
ID of the buffer pool containing the block |
Output |
phys_addr |
Physical address of the buffer block |
Output |
blk_size |
Size of the buffer block |
Input |
mmz_name |
Name of the DDR containing the buffer pool |
Input |
Return Values:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
Notes:
If the user needs to get a buffer block of a specified size from any public buffer pool, set the second parameter blk_size to the required buffer block size and specify from which DDR to get the buffer block. If there is no public buffer pool on the specified DDR, the buffer block cannot be obtained. If mmz_name is NULL, it means getting the buffer block from the public buffer pool on an unnamed DDR.
During media initialization, if a buffer pool is created in an unnamed DDR, set mmz_name to NULL to get a buffer block of the specified size from any public buffer pool.
Related Topics:
2.8 kd_mapi_sys_release_vb_block#
Description:
Release a buffer block in user space.
Syntax:
Parameters:
Parameter Name |
Input/Output |
phys_addr |
Output |
blk_size |
Input |
Return Values:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
Notes:
After using the buffer block, this interface should be called to release the buffer block.
Related Topics:
3. Data Types#
3.1 k_mapi_mod_id_e#
Description:
Defines MAPI module IDs.
Definition:
K_MAPI_MOD_SYS = 0,
K_MAPI_MOD_VI,
K_MAPI_MOD_VPROC,
K_MAPI_MOD_VENC,
K_MAPI_MOD_VDEC,
K_MAPI_MOD_VREC,
K_MAPI_MOD_VO,
K_MAPI_MOD_AI,
K_MAPI_MOD_AENC,
K_MAPI_MOD_ADEC,
K_MAPI_MOD_AREC,
K_MAPI_MOD_AO,
K_MAPI_MOD_VVI,
K_MAPI_MOD_VVO,
K_MAPI_MOD_DPU,
K_MAPI_MOD_VICAP,
K_MAPI_MOD_SENSOR,
K_MAPI_MOD_ISP,
K_MAPI_MOD_BUTT,
} k_mapi_mod_id_e;
Members:
Notes:
3.2 k_mapi_media_config_t#
Description:
Defines the media configuration attribute structure.
Definition:
k_vb_config vb_config;
} k_mapi_media_config_t;
Members:
Member Name |
vb_supp |
VB Supplement Information Structure, see “K230 System Control API Reference” |
vb_config |
Video Buffer Pool Attribute Structure, see “K230 System Control API Reference” |
Notes:
3.3 k_mapi_media_attr_t#
Description:
Defines the media initialization attribute structure.
Definition:
} k_mapi_media_attr_t;
Members:
Member Name |
media_config |
Media configuration attribute structure |
Notes:
4. Error Codes#
Table 41
Error Code |
Macro Definition |
0xb0008003 |
K_MAPI_ERR_SYS_ILLEGAL_PARAM |
Parameter error |
0xb0008006 |
K_MAPI_ERR_SYS_NULL_PTR |
Null pointer error |
0xb0008009 |
K_MAPI_ERR_SYS_NOT_PERM |
Operation not permitted |
0xb0008010 |
K_MAPI_ERR_SYS_NOTREADY |
Device not ready |
0xb0008012 |
K_MAPI_ERR_SYS_BUSY |
System busy |
0xb000800c |
K_MAPI_ERR_SYS_NOMEM |
Memory allocation failure, such as insufficient system memory |
