K230 FFT API Reference#
Directory#
preface#
This document mainly introduces the API of K230 FFT, including API usage and test program introduction.
Reader object#
Technical Support Engineer
Software Development Engineer
Definition of acronyms#
abbreviation |
illustrate |
FFT |
Fast Fourier Transform, a fast algorithm for discrete Fourier transforms |
IFFT |
Inverse fast Fourier transform |
Revision history#
Version |
Author |
date |
Initial edition |
Wang Jianxin |
2023-08-08 |
Introduction to the K230 FFT#
The FFT module of K230 is mainly used for hardware-accelerated FFT and IFFT calculations, and its characteristics are as follows:
Support 64, 128, 256, 512, 1024, 2048, 4096 point FFT, IFFT calculation. Support int16 calculation accuracy, that is, the real and imaginary parts of the input and output are in INT16 format. Supports the standard AXI4 slave interface, which is used for parameter configuration and data migration. Input support RIRI…., RRRR…., RRRR… IIII… Format arrangement, output support RIRI…., RRRR… IIII… Format arrangement. Using the basis 2-time decimation calculation method, there is only one butterfly operator inside. With a single-clock domain design, the bus clock is also used as an arithmetic clock to save overhead across clock domains. The calculation time of 4096-point FFT/IFFT is controlled within 1ms, including the total overhead of data migration, calculation, and interrupt interaction. Supports interrupt mask and raw interrupt query.
API Reference#
The k230 FFT module mainly provides the following APIs:
kd_mpi_fft_or_ifft#
【Description】
FFT or IFFT computes core functions.
【SYNOPSIS】
【Parameters】
Parameter name |
description |
Input/output |
fft_args |
Input/output |
【Return value】
Return value |
description |
Succeed. |
other |
fail |
【Differences】
【Requirement】
Header file: mpi_fft_api.h
Library file: libfft.a
【Note】
【Example】
int kd_mpi_fft(int point , k_fft_input_mode_e im, k_fft_out_mode_e om,
k_u32 timeout , k_u16 shift ,
int ret = 0 ;
k_fft_args_st fft_args;
timeout, shift, rx_in, iy_in , &fft_args); ERET(ret);
【See Also】
kd_mpi_fft_args_init#
【Description】
fft_args initialization (helper functions)
【SYNOPSIS】
int kd_mpi_fft_args_init( int point, k_fft_mode_e mode, k_fft_input_mode_e im,
k_fft_out_mode_e om, k_u32 timeout , k_u16 shift,
【Parameters】
Parameter name |
description |
Input/output |
point |
Points, valid values are 64, 128, 256, 512, 1024, 2048, 4096 |
input |
mode |
k_fft_mode_e FFT_MODE IFFT_MODE |
input |
in |
k_fft_input_mode_e Input Mode |
input |
to |
input |
time_out |
Timeout |
input |
shift |
offset |
input |
rx_input |
Enter real data |
input |
iy_input |
Enter imaginary data |
input |
fft_args |
k_fft_args_st Variables to populate |
output |
【Return value】
Return value |
description |
Succeed. |
other |
fail |
【Differences】
【Requirement】
【Note】
【Example】
int ret = 0 ;
【See Also】
kd_mpi_fft_args_2_array#
【Description】
Convert FFT output to arrays (auxiliary functions for easy printing).
【SYNOPSIS】
【Parameters】
Parameter name |
description |
Input/output |
fft_args |
input |
rx_out |
Real data |
output |
iy_out |
Imaginary data |
output |
【Return value】
Return value |
description |
Succeed. |
other |
fail |
【Differences】
【Requirement】
【Note】
【Example】
int kd_mpi_fft(int point , fft_input_mode_e im, fft_out_mode_e om,
k_u32 timeout , k_u16 shift , k_u16 dma_ch,
int ret = 0 ;
timeout, shift, dma_ch, rx_in, iy_in , &fft_args); ERET(ret);
【See Also】
kd_mpi_fft#
【Description】
FFT calculation,
The core is kd_mpi_fft_args_init, kd_mpi_fft_or_ifft, and kd_mpi_fft_args_2_arra three functions packaged together for easy use.
【SYNOPSIS】
【Parameters】
Parameter name |
description |
Input/output |
point_num |
input |
in |
input |
to |
input |
time_out |
Timeout |
input |
shift |
offset |
input |
rx_input |
Enter real data |
input |
iy_input |
input |
rx_out |
Calculate the resulting real data |
output |
iy_out |
Calculation results: imaginary data |
output |
【Return value】
Return value |
description |
Succeed. |
other |
fail |
【Differences】
【Requirement】
【Note】
【Example】
//soft_fft_ifft_calc(point);
kd_mpi_fft(point, RIRI,RR_II_OUT, 0, 0x555, i_real, i_imag, o_h_real, o_h_imag);
kd_mpi_ifft(point, RIRI,RR_II_OUT, 0, 0xaaa, o_h_real, o_h_imag, o_h_ifft_real, o_h_ifft_imag);
display_calc_result(point);
【See Also】
kd_mpi_ifft#
【Description】
IFFT calculation
【SYNOPSIS】
int kd_mpi_ifft(int point , k_fft_input_mode_e im, k_fft_out_mode_e om,
【Parameters】
Parameter name |
description |
Input/output |
point_num |
input |
in |
input |
to |
input |
time_out |
Timeout |
input |
shift |
offset |
input |
dma_ch |
DMA channels 0-3 are valid; other values are illegal |
input |
rx_input |
Enter real data |
input |
iy_input |
input |
rx_out |
output |
iy_out |
output |
【Return value】
Return value |
description |
Succeed. |
other |
fail |
【Differences】
【Requirement】
【Note】
【Example】
【See Also】
Data structure#
The relevant data types for this function module are defined as follows:
k_fft_args_st#
【Description】FFT IOCTL parameter
【Definition】
typedef union
struct {
volatile fft_point_e point:3; //2:0 0:64;1:128;2:256;3:512;4:1024;5:2048;6:4096
volatile k_fft_mode_e mode:1; //3 0:fft 1:ifft
volatile k_fft_input_mode_e im:2; //5:4 0:RIRI....;1:RRRR...;2:RRRR...IIII..
volatile k_u16 shift:12; //19:8
volatile k_u32 fft_disable_cg : 1;//20 write 1 disable fft clock gating
volatile k_u32 time_out:32;//63:32
}__attribute__ ((packed));
volatile k_u64 cfg_value;
k_fft_cfg_reg_st reg;
k_char rsv[4];
}k_fft_args_st;
【Members】
Member Name |
reg |
The configuration register value of the FFT |
data |
Input and output data of FFT |
【Note】
k_fft_mode_e#
【Definition】
FFT_MODE = 0,
IFFT_MODE,
}k_fft_mode_e;
【Members】
Member Name |
**** Description |
FFT_MODE |
fft |
IFFT_MODE |
ifft |
【Note】
k_fft_input_mode_e#
【Definition】
RIRI = 0,
RRRR,
RR_II,
} k_fft_input_mode_e;
【Members】
Member Name |
RI |
RIRI format data |
RRRR |
RRRR solid data |
RR_II |
RR_II format data |
【Note】
none
k_fft_out_mode_e#
【Definition】
RIRI_OUT = 0,
RR_II_OUT,
} k_fft_out_mode_e;
【Members】
Member Name |
RIRI_OUT |
RIRI format data |
RR_II_OUT |
RR_II format data |
【Note】
