K230 Product Full Datasheet#
Document version: V1.0 Release date: 2023-7-6
The products, services or features you purchase shall be subject to the commercial contracts and terms of Canaan Creative CO., LTD. (the “Company”) and its affiliates, and all or part of the products, services or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, the Company does not provide any express or implied representations or warranties as to the correctness, reliability, completeness, merchantability, fitness for a particular purpose and non-aggression of any statements, information, or content in this document.Unless otherwise agreed, this document is intended as a guide for use only.
Trademark Notice#
logo “Canaan” and other Canaan trademarks are trademarks of Canaan Creative CO., LTD. and its affiliates. All other trademarks or registered trademarks that may be mentioned in this document are owned by their respective owners.
Copyright©2023 Canaan Creative CO., LTD. This document is only suitable for the development and design of K230 platform, without the written permission of the company, any unit or individual shall not disseminate part or all of the content of this document in any form.
Canaan Creative CO., LTD. Website:canaan-creative.com Business Email:salesAI@canaan-creative.com
Purpose#
This document is intended to provide a full description of the K230 platform and its features.
Intended Audience#
The main people to whom this document (this guide) applies:
  • Design and maintenance personnel for electronic products
  • Sales personnel for electronic products
  • Technical support personnel
Terms#
Revision history#
Version Number
Modified by
Revision Date
Revision Notes
Ruizheng Li,Heng Wen
2023-7-6
Revised version
Index#
Chapter 1 Introduction#
1.1 Overview#
1.2 Feature#
1.2.1 CPU subsystem#
  • CPU0 subsystem
    • 64bit RISC-V processor
    • Supports WFI
  • CPU1 subsystem
    • 128bits vector-process-unit
    • Supports WFI
1.2.2 KPU subsystem#
  • Support INT8 and INT16
    • Resnet 50 ≥ 85fps @INT8
    • Mobilenet_v2 ≥ 670fps @INT8
    • YoloV5S ≥ 38fps @INT8
1.2.3 2D Engine#
  • 2D GDMA Engine
  • Non AI 2D
    • Support OSD mode
    • Support CSC mode
    • Support draw border mode
    • Support corp operation
  • Independent AI 2D Engine
    • Resize
    • Crop
    • Affine
    • Pad
    • CSC
      • YUV420_NV12
      • YUV420_NV12
      • YUV420_I420
      • YUV400
      • RGB_packed
      • NCHW
    • Shift
    • Support clk gating
      NOTE
1.2.4 DPU (Depth Processing Unit)#
1.2.5 Memory#
  • DDR
    • Maximum capacity: 2GB
    • Supports max to 2 ranks
    • 5 host ports using AMBA AXI
    • Support for:
      4. Data bus VREFDQ training
  • SRAM
  • Flash
      • Dual Data Rate(DDR) support
    • Programmable clock bit rate
      Note:
1.2.6 system component#
  • RMU
  • CMU
  • PWR
  • Interrupt
  • PDMA
  • SDMA
  • General-puspose timers
    • APB interface supports APB3
  • Stc timer
    • 64 bit timer width
    • Apb 3.0 interface
  • Watchdog
    • APB3 interface support
      • Generate a system reset
  • RTC
  • Mailbox
    • Support for hardware locks
  • Temperature Sensor
1.2.6 Video input#
  • 3 x MIPI CSI
  • Support sensor slave mode
  • Support timestamp
  • Support HDR sensor
  • 8/10/12/16 Bit Bayer RAW
1.2.7 ISP#
  • Total throughput:8MP@30fps
  • Auto Focus measurement (AF)
  • Black level Compensation
  • Sensor Linear Correction
  • Green Equalization
  • Digital Gain
  • Histogram Calculation
  • Anti-flicker
  • Sharpen/Blur Filter
  • Flash light control
  • Mechanical shutter control
  • Video Stabilization (VSM)
1.2.8 Video output#
  • Resolution: 2MP@60fps
  • Video Layer 0:
  • Video Layer 1:
  • Video Layer 2 & Layer 3:
    • ARGB8888
    • ARGB4444
    • ARGB1555
    • Monochrome(8-bit)
  • Display mix:
  • Support dither function
1.2.9 video codec#
  • Stride support.
Supported codecs
  • HEVC (H.265) Main.
  • H.264 Main Profile (MP).
  • H.264 High Profile (HP).
  • H.264 High 10 Profile.
  • MJPEG
  • Skipped CUs, Merge modes.
  • Deblocking.
  • Long term reference frame.
H.264 encoding features
  • I and P frames.
  • Progressive encoding.
  • 4 × 4 and 8 × 8 transform.
  • Skipped macroblocks.
  • Deblocking.
Supported codecs
  • HEVC (H.265) Main/Main10.
H.264 decoding features
  • For progressive streams
  • For interlaced streams
JPEG decoding features
1.2.10 2.5D GPU#
    • Alpha blending
  • Support draw engine
    • Gradient Filled rectangles
    • Triangles, Polygon
    • Path Generation
    • Linear gradient paint paths
    • 16-bit RGBA5551 / RGB565
    • 1/2/4/8-bit index format
  • Support Antialiasing
1.2.11 Audio#
  • Audio codec inside
  • Maximum 8 x PDM DMIC inputs
  • PDM audio
  • I2S audio
    • DMA mode enable and disable
1.2.12 peripheral#
  • UART
    • Support 5 UART interface
    • 9-bit serial data support
    • False start bit detection
    • APB data bus widths of 32
    • Busy functionality
  • I2C
    • Support 5 I2C interface
    • Three speeds:
      • High-speed mode (≤3.4 Mb/s)
    • Clock synchronization
    • Master I2C
    • 7- or 10-bit addressing
    • Bulk transmit mode
    • DMA operation.
    • Bus clear feature
    • Device ID feature
  • PWM
    • Support 6 channel
    • 64 x GPIO + 8 x PMU GPIO
    • 32-bit APB width
  • USB
    • Support 2 USB 2.0 OTG
  • SD/EMMC
        • CPU
        • SDMA
        • ADMA2
        • ADMA3
      • Supports auto-tuning
      • Support clock gating
      • SD
        • Supports 4-bit interface
        • Supports UHS-I mode
        • Supports SDIO read wait
        • Wake up on card interrupt
      • eMMC
  • SPI
      • AMBA 3 AXI
      • AXI data width : 64
      • AXI address width : 32
1.2.13 security#
  • Support PUF / OTP / TRNG
    • AES128/192/256
    • CMAC128/192/256
    • SM4-128
    • RSA-1024/2048/3072/4096
    • HMAC
    • SM3
  • TRNG
    • 160Mbps@20Mhz
1.2.14 PMU#
1.2.15 Others#
  • decompression
  • FFT/IFFT
1.3 Block Diagram#
2.1 K230#
Figure 2-1-1 K230 Package
K230_package
2.2 K230D#
Figure 2-2-1 K230D Package
K230_package
2.3 Pin information description#
3.1 Absolute Max Rating#
Power Parameter
Min
Max
Units
PMU
AVDD1P8_RTC
-0.1
1.98
V
PMU
AVDD1P8_LDO
-0.1
1.98
V
CORE
VDD0P8_CORE
-0.1
0.88
V
CPU
VDD0P8_CPU
-0.1
0.88
V
KPU
VDD0P8_KPU
-0.1
0.88
V
DDR
VDD0P8_DDR_CORE
-0.1
0.88
V
DDR
VDD1P1_DDR_IO
-0.1
1.21/1.32/1.485
V
DDR
VAA_DDR
-0.1
1.98
V
IO
VDDIO3P3_0
-0.1
1.98/3.63
V
IO
VDDIO3P3_1
-0.1
1.98/3.63
V
IO
VDDIO3P3_2
-0.1
1.98/3.63
V
IO
VDDIO3P3_3
-0.1
1.98/3.63
V
IO
VDDIO3P3_4
-0.1
1.98/3.63
V
IO
VDDIO3P3_5
-0.1
1.98/3.63
V
USB
AVDD3P3_USB
-0.1
3.63
V
USB
AVDD1P8_USB
-0.1
1.98
V
PLL
AVDD0P8_PLL
-0.1
0.88
V
MIPI
AVDD0P8_MIPI
-0.1
0.88
V
MIPI
AVDD1P8_MIPI
-0.1
1.98
V
ADC
AVDD1P8_ADC
-0.1
1.98
V
AUDIO CODEC
AVDD1P8_CODEC
-0.1
1.98
V
MMC
VDD3P3_SD
-0.1
3.63
V
SYSTEM
VDD1P8
-0.1
1.98
V
K230D LPDDR4
VDD1P8_DDR_VDD1
-0.1
1.98
V
K230D LPDDR4
VDD1P1_DDR_VDD2
-0.1
1.21
V
K230D LPDDR4
VDD1P1_DDR_VDDQ
-0.1
1.21
V
3.3 DC Characteristics#
3.3.1 Electrical Characteristics for General IO#
GPIO_ecectric
3.3.2 Electrical Characteristics for PLL#
Parameter
Min
Type
Max
Units
Fref
488K
4G
Hz
Fout
Total output frequency range
50M
NA
4G
Hz
Fvco
VCO frequency range
800M
NA
4G
Hz
Tlt
Lock time
500
div referency clock cycle
Ijitter
input jitter
2%
3.3.3 Electrical Characteristics for DDR#
Parameter
Symbol
Unit
Minimum
Typical
Maximum
Vref input leakage current
IIZ
uA
50
BP_DAT input leakage current
IIZ
uA
50
VIH-DC
V
Vref+0.02
Input low voltage for BP_DAT*
VIL-DC
V
Vref-0.02
VID-DC
V
0.1
Note:
Parameter
Symbol
Unit
Minimum
Typical
Maximum
Input capacitance DQ
CpadDQ
pF
1.54
1.62
1.76
Input capacitance DQS
CpadDQS
pF
1.44
1.56
1.66
Input capacitance,address/cmd
CpadAC
pF
1.71
1.81
1.94
Note:
Parameter
Symbol
Unit
Minimum
Maximum
tDQSDQRead800
UI
-0.39
0.39
tDQSDQRead1066
UI
-0.38
0.38
tDQSDQRead1333
UI
-0.37
0.37
tDQSDQRead1600
UI
-0.36
0.36
tDQSDQRead1866
UI
-0.35
0.35
tDQSDQRead2133
UI
-0.34
0.34
tDQSDQRead2400
UI
-0.33
0.33
tDQSDQRead2667
UI
-0.32
0.32
tDQSDQRead3200
UI
-0.31
0.31
Note:
Parameter
Symbol
Unit
Minimum
Typical
Maximum
Reference voltage
Vref
V
Variable
DC reference voltage error
VrefDC-err
VDDQ
-0.75%
0.75%
RTT
ohm
open, 240,120, 80, 60,48, 40
RODT-L/RTT
0.9
1.0
1.1
RODT-M/RTT
0.8
1.05
RODT-H/RTT
0.75
1.05
Parameter
Symbol
Unit
Minimum
Typical
Maximum
Reference voltage
VrefAC-err
VDDQ
-0.25%
0.25%
VIH-ACLS
V
Vref + 0.070
VDDQ +0.15
VIL-ACLS
V
-0.15
Vref - 0.070
VIH-ACHS
V
Vref + 0.070
Vref + 0.440
VIL-ACHS
V
Vref - 0.440
Vref - 0.070
RODTss-M /RTT
0.95
1.75
RODTss-M /RTT
0.85
1.05
RODTss-H /RTT
0.75
1.05
VIX
mV
VDQSavg-75
VDQSavg
VDQSavg +75
Parameter
Symbol
Unit
Minimum
Typical
Maximum
Reference voltage
Vref
V
Variable
VrefDC-err
VDDQ
-0.75%
0.75%
RTT
ohm
RODT-M/RTT
0.8
1.1
RODT-H/RTT
0.9
1.0
1.1
Parameter
Symbol
Unit
Minimum
Typical
Maximum
Reference voltage
VrefAC-err
VDDQ
-0.25%
0.25%
VIH-ACLS
V
Vref + 0.070
VDDQ +0.15
VIL-ACLS
V
-0.15
Vref - 0.070
VIH-ACHS
V
Vref + 0.070
Vref + 0.440
VIL-ACHS
V
Vref - 0.440
Vref - 0.070
RODTss-M /RTT
0.9
1.1
RODTss-H /RTT
0.95
1.75
VIX
mV
VDQSavg-75
VDQSavg
VDQSavg +75
3.3.4 Electrical Characteristics for MIPI DSI#
Symbol
Parameter
Condition
Minimum
Typical
Maximum
Unit
Vslew
Supplies slew rate
0.1
V/μs
Symbol
Parameter
Condition
Minimum
Typical
Maximum
Unit
VI
Input signal voltage range
-50
1350
mV
ILEAK
Input leakage current
-10
μA
VGNDSH
Ground shift
-50
50
mV
VOH(absmax)
-0.15
1.45
V
tVOH(absmax)
20
ns
Symbol
Parameter
Condition
Minimum
Typical
Maximum
Unit
|VOD|
140
200
270
mV
∆|VOD|
80 Ω ≤ RL ≤ 125 Ω
14
mV
VCMTX
80 Ω ≤ RL ≤ 125 Ω
150
200
250
mV
∆VCMTX(1,0)
80 Ω ≤ RL ≤ 125 Ω
5
mV
VOHHS
HS output high voltage
80 Ω ≤ RL ≤ 125 Ω
360
mV
ZOS
Single-ended output impedance
40
50
62.5
Ω
∆ZOS
Symbol
Parameter
Minimum
Typical
Maximum
Unit
VOL
Output low-level SE voltage
-50
50
mV
VOH
Output high-level SE voltage
1.1
1.2
1.3
V
ZOLP
110
Ω
∆ZOLP(01,10)
20
∆ZOLP(00,11)
5
Symbol
Parameter
Minimum
Typical
Maximum
Unit
VIL
550
mV
VIL-ULPS
Logic 0 input voltage, ULPS
300
mV
VIH
Input high voltage
740
mV
VHYST
Input hysteresis
25
mV
Symbol
Parameter
Minimum
Typical
Maximum
Unit
VILF
Input low fault threshold
200
mV
VIHF
Input high fault threshold
450
mV
3.3.5 Electrical Characteristics for MIPI CSI#
Symbol
Parameter
Condition
Minimum
Typical
Maximum
Unit
Vslew
Supplies slew rate
0.1
V/μs
Symbol
Parameter
Minimum
Typical
Maximum
Unit
Notes
VPIN
Pin signal voltage range
-50
1350
mV
ILEAK
Pin leakage current
-10
µA
VGNDSH
Ground shift
-50
50
mV
VPIN(absmax)
-0.15
1.45
V
VPIN(absmax)
20
ns
Symbol
Parameter
Minimum
Typical
Maximum
Unit
Notes
VIDTH
70
mV
VIDTH
40
mV
VIDTL
-70
mV
VIDTL
-40
mV
VIHHS
460
mV
VILHS
-40
mV
VCMRXDC
Input common mode voltage
70
330
mV
ZID
Differential input impedance
80
100
125
Ω
Symbol
Parameter
Minimum
Typical
Maximum
Unit
VOL
-50
50
mV
VOH
1.1
1.2
1.3
V
ZOLP
110
Ω
∆ZOLP(01,10)
20
∆ZOLP(00,11)
5
Symbol
Parameter
Minimum
Typical
Maximum
Unit
VIL
Input low voltage
550
mV
VIH
Input high voltage
740
mV
VIL-ULPS
300
mV
VHYST
Input hysteresis
25
mV
Symbol
Parameter
Minimum
Typical
Maximum
Unit
VILF
200
mV
VIHF
450
mV
3.3.6 Electrical Characteristics for USB#
Parameter
Symbol
Test Condition
Min
Max
Unit
High-power Port
VBUS
4.75
5.25
V
Low-power Port
VBUS
4.4
5.25
V
High-power Hub Port (out)
ICCPRT
500
mA
Low-power Hub Port (out)
ICCUPT
100
mA
High-power Function (in)
ICCHPF
500
mA
Low-power Function (in)
ICCLPF
100
mA
ICCINIT
100
mA
Suspended High-power Device
ICCSH
2.5
mA
Suspended Low-power Device
ICCSL
500
uA
High (driven)
VIH
V
High (floating)
VIHZ
2.7
3.6
V
Low
VIL
0.8
V
VDI
(D+)-(D-)
0.2
VCM
Includes VDI range;
0.8
2.5
V
VHSSQ
100
150
mV
VHSDSC
525
625
mV
VHSCM
-50
500
mV
Low
VOL
V
High (Driven)
VOH
2.8
3.6
V
SE1
VOSE1
0.8
V
VCRS
1.3
V
High-speed idle level
VHSOI
-10
mV
VHSOH
360
440
mV
High-speed data signaling low
VHSOL
-10
mV
VCHIRPJ
700
1100
mV
VCHIRPK
-900
-500
mV
CHPB
VBUS to GND,
120
uF
CRPB
VBUS to GND
uF
Downstream Facing Port
CIND
150
pF
CINUB
100
pF
CEDGE
75
pF
RPU
1.5 kΩ ±5%
1.425
1.575
RPD
15 kΩ±5%
14.25
15.75
ZINP
300
VTERM
3
3.6
V
VHSTERM
-10
mV
3.3.7 Electrical Characteristics for SD/eMMC#
Parameter
Test conditions
Min
Max
Units
MMC0_* signals
Relative to VSS
-0.3
3.63
V
Input High Voltage(ViH)
Relative to VSS
1.68
V
Input Low Voltage(ViL)
Relative to VSS
0.9
V
VOH
Relative to VSS
0.75*VDDIO33
V
VOL
Relative to VSS
0.125*VDDIO33
V
Operating temprature rang TJ
-40
125
C
