K230 FAQ#
- K230 SDK Frequently Asked Questions (C)
- Disclaimer
- Trademark Statement
- Table of Contents
- 1 TF Boot Failed with Exit Code 13
- 2 Bootrom Startup Error Codes
- 3 SPI NOR and SPI NAND Flash Identification
- 4 Perf Usage
- 5 Running Vector Linux on the Big Core
- 6 Big Core Serial Port ID
- 7 Uboot Command Line
- 8 How to Change Slow Boot to Fast Boot
- 9 How to Modify the Size of the Last Partition in Linux
- 10 How to Modify Bootargs
- 11 How to View Bootargs
- 12 How to Modify the Default Serial Port of the Small Core
- 13 How to Completely Recompile the SDK
- 14 Where is the List of Supported Sensors
- 15 Can the Canmmv Board Use Pingtouge’s CKLink for JTAG Debugging
- 16 How to Quickly Compile a Specific Package Under Buildroot
- 17 How to Run Only the RTT System and Mount the SD Card on Canmv
- 18 How to Quickly Verify Serial Port Transmission and Reception in Linux
- 19 How to Quickly Modify Linux Configuration
- 20 How to Switch the Auto-Start Program on the Big Core
- 21 Can libxml2 Be Used?
- 22 What Screens Are Supported?
- K230 nncase FAQ
- Disclaimer
- Table of Contents
- 1. Error Installing whl Package
- 2.Error Compiling Model
- 2.1
System.NotSupportedException: Not Supported *** op: XXX - 2.2
System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached - 2.3
RuntimeError: Failed to initialize hostfxr.orRuntimeError: Failed to get hostfxr path. - 2.4
The given key 'K230' was not present in the dictionary
- 2.1
- 3. Errors During Inference
- 4. Errors During Inference on K230 Development Board
- K230 AI Demo Frequently Asked Questions (C++)
- AI Cube Frequently Asked Questions
