K230 VICAP API Reference#
The products, services, or features you purchase are subject to the commercial contracts and terms of Beijing Canaan Creative Information Technology Co., Ltd. (“the Company”, hereinafter the same) and its affiliates. All or part of the products, services, or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, the Company does not provide any express or implied representations or warranties regarding the correctness, reliability, completeness, merchantability, fitness for a particular purpose, or non-infringement of any statements, information, or content in this document. Unless otherwise agreed, this document is only for reference as a usage guide.
Trademark Statement#
Copyright © 2023 Beijing Canaan Creative Information Technology Co., Ltd. All rights reserved. No part of this document may be excerpted, copied, or disseminated in any form without prior written permission from the Company.
Table of Contents#
This document mainly guides application developers on how to obtain image data through the VICAP module and describes the basic functions of various module APIs.
Intended Audience#
Technical Support Engineers
Abbreviation Definitions#
Abbreviation |
Document Version |
Modification Description |
Modifier |
Date |
Initial version |
Chenggen Wang |
2023/4/4 |
V1.1 |
Modified VICAP overview 2, added API and data type navigation |
Zhongxiang Zhao |
2023/4/6 |
V1.2 |
Removed ISP related interfaces, added API and data type descriptions, separated sensor interface from libvicap library to libsensor library, added ov9286 infrared/scatter type, updated VICAP description, updated document format |
Shidong Guo, Chenggen Wang |
2023/4/26 |
1. Overview#
1.1 Overview#
The VICAP subsystem is responsible for video image input capture and processing in the K230 SOC. It processes signals output by the sensor in real-time to obtain restored and enhanced digital images that are closer to what the human eye sees in reality. It mainly includes MIPI RxDphy, MIPI CSI, ISP, and DW. MIPI is used to receive high-speed differential signals from the sensor and convert them to the DVP interface for ISP processing; ISP is used for image information processing; DW is used for fisheye correction and multi-channel resize output.
This document mainly describes the application programming interface of the VICAP module, which provides application developers with operational interfaces and configuration parameters for capturing video image data through the VICAP module.
1.2 Function Description#
1.2.1 VICAP#
The VICAP module is an abstract description of the entire image acquisition and processing unit.
The VICAP hardware consists of four major modules: Sensor, VI, ISP, and Dewarp (as shown in Figure 1-1). It supports up to 3 sensors simultaneously. The MCM module inside the ISP implements time-division multiplexing management of multiple sensors. The output data of multiple sensors is written to DDR through the Memory Interface’s Write interface of the MCM, and then read and loaded into the ISP Pipeline for processing.
Figure 1-1 VICAP Hardware Architecture Diagram
The VICAP software architecture is shown in Figure 1-2, from top to bottom: Application Interface Layer, Media Interface Layer, System Framework Layer, Driver Layer, and Hardware Layer.
Application Interface Layer: Provides API interfaces in the form of kd_mapi_vicap_xxx and usage instructions. It further encapsulates the functional interfaces provided by each sub-module of the Media Interface Layer to simplify the application development process.
Media Interface Layer: This layer consists of various sub-modules of VICAP, each providing its own media interface API encapsulation.
Framework Layer: Responsible for the control and management of the entire system software functions and business logic of VICAP. It integrates and unifies the interfaces and functions provided by each sub-module to form a complete VICAP system control logic and process.
Driver Layer: A collection of kernel driver functions for various hardware modules of VICAP.
Hardware Layer: A collection of specific hardware modules of VICAP, including sensors.
1.2.2 Sensor#
The Sensor module is one of the data sources for VICAP image capture, responsible for configuring the operating parameters and working modes of the image sensor unit.
The K230 platform supports a variety of sensor interface types. We will use the current most commonly used MIPI CSI interface sensor as an example. The hardware connection diagram between the sensor and the main control platform is as follows:
Figure 1-3
The main control sends configuration register control to the sensor through the I2C interface, and the sensor sends image data to the main control SOC through the MIPI CSI interface.
The system architecture of the Sensor module is shown in Figure 1-4:
Figure 1-4 Sensor System Architecture Diagram
From top to bottom: Media Interface Layer, Hardware Driver Layer, and Hardware Layer
Media Interface Layer: Provides kd_mpi_sensor_xxx interfaces for external modules to operate and access sensor devices.
Driver Layer: This layer mainly includes two parts: sensor_dev and sensor_drv.
sensor_dev: Responsible for registering device driver files and providing the implementation process of file operation interfaces. By registering device file nodes /dev/sensorxx, it allows user-space programs to access the kernel driver.
sensor_drv: Specific sensor hardware driver, encapsulating operations on the sensor into a unified interface.
Hardware Layer: Sensor module hardware, supporting up to three hardware sensors simultaneously in the current system.
2. API Reference#
2.1 VICAP#
2.1.1 kd_mpi_vicap_get_sensor_info#
[Description]
Get sensor configuration information based on the specified sensor configuration type.
[Syntax]
[Parameters]
Parameter Name |
Input/Output |
sensor_type |
Sensor configuration type |
Input |
sensor_info |
Sensor configuration information |
Output |
[Return Value]
Return Value |
Success. |
Non-zero |
Failure, refer to error code. |
[Chip Differences]
None.
[Requirements]
Header file: mpi_vicap_api.h
Library file: libvicap.a
[Note]
Application developers need to first call this API to get sensor configuration information based on the sensor configuration type they need to use, and then call subsequent interfaces to initialize other VICAP modules based on the configuration information.
[Example]
None.
[Related Topics]
2.1.2 kd_mpi_vicap_set_dev_attr#
[Description]
Set VICAP device attributes.
[Syntax]
[Parameters]
Parameter Name |
Input/Output |
dev_num |
VICAP device number |
Input |
dev_attr |
VICAP device attributes |
Input |
[Return Value]
Return Value |
Success. |
Non-zero |
[Chip Differences]
None.
[Requirements]
[Note]
None.
[Example]
None.
[Related Topics]
2.1.3 kd_mpi_vicap_get_dev_attr#
[Description]
Get VICAP device attributes.
[Syntax]
k_s32 kd_mpi_vicap_get_dev_attr(k_vicap_dev dev_num, k_vicap_dev_attr *dev_attr)
[Parameters]
Parameter Name |
Input/Output |
dev_num |
Input |
dev_attr |
Output |
[Return Value]
Return Value |
Success. |
Non-zero |
[Chip Differences]
None.
[Requirements]
[Note]
None.
[Example]
None.
[Related Topics]
2.1.4 kd_mpi_vicap_set_chn_attr#
[Description]
Set VICAP channel attributes.
[Syntax]
[Parameters]
Parameter Name |
Input/Output |
dev_num |
Input |
chn_num |
VICAP output channel number |
Input |
chn_attr |
VICAP output channel attributes |
Input |
[Return Value]
Return Value |
Success. |
Non-zero |
[Chip Differences]
None.
[Requirements]
[Note]
None.
[Example]
None.
[Related Topics]
2.1.5 kd_mpi_vicap_get_chn_attr#
[Description]
Get VICAP channel attributes.
[Syntax]
[Parameters]
Parameter Name |
Input/Output |
dev_num |
Input |
chn_num |
Input |
chn_attr |
Output |
[Return Value]
Return Value |
Success. |
Non-zero |
[Chip Differences]
None.
[Requirements]
[Note]
None.
[Example]
None.
[Related Topics]
2.1.6 kd_mpi_vicap_init#
[Description]
VICAP device initialization.
[Syntax]
[Parameters]
Parameter Name |
Input/Output |
dev_num |
Input |
[Return Value]
Return Value |
Success. |
Non-zero |
[Chip Differences]
None.
Requirements:
Notes:
Before using this interface, you need to call kd_mpi_vicap_set_dev_attr to set the device attributes, and then call kd_mpi_vicap_set_chn_attr to set the output channel attributes.
Related Topics:
2.1.7 kd_mpi_vicap_deinit#
Description:
Deinitialize the VICAP device.
Syntax:
Parameters:
Parameter Name |
Input/Output |
dev_num |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.1.8 kd_mpi_vicap_start_stream#
Description:
Start the VICAP device output data stream.
Syntax:
Parameters:
Parameter Name |
Input/Output |
dev_num |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.1.9 kd_mpi_vicap_stop_stream#
Description:
Stop the VICAP device data stream output.
Syntax:
Parameters:
Parameter Name |
Input/Output |
dev_num |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.1.10 kd_mpi_vicap_dump_frame#
Description:
Dump VICAP data based on the specified device and output channel.
Syntax:
k_s32 kd_mpi_vicap_dump_frame(k_vicap_dev dev_num, k_vicap_chn chn_num, k_vicap_dump_format format,
Parameters:
Parameter Name |
Input/Output |
dev_num |
Input |
chn_num |
Input |
format |
Dump data type |
Input |
vf_info |
Dump frame information |
Output |
milli_sec |
Timeout duration |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.1.11 kd_mpi_vicap_dump_release#
Description:
Release the dumped data frame.
Syntax:
Parameters:
Parameter Name |
Input/Output |
dev_num |
Input |
chn_num |
Input |
vf_info |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.1.12 kd_mpi_vicap_set_vi_drop_frame#
Description:
Set hardware frame drop.
Syntax:
Parameters:
Parameter Name |
Input/Output |
csi |
Input |
frame |
Structure, see below |
m |
Drop n frames every m frames |
Input |
n |
Input |
mode |
HDR mode |
Input |
enable |
Enable or disable |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
2.1.13 kd_mpi_vicap_set_mclk#
Description:
Set MCLK frequency.
Syntax:
Parameters:
Parameter Name |
Input/Output |
id |
MCLK ID |
Input |
sel |
Clock source |
Input |
mclk_div |
Division factor |
Input |
mclk_en |
Enable or disable |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
2.1.14 kd_mpi_vicap_set_dump_reserved#
Description:
Set whether to enable fast dump mode.
Syntax:
Parameters:
Parameter Name |
Input/Output |
dev_num |
Input |
chn_num |
Input |
reserved |
Enable fast dump mode |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
2.1.15 kd_mpi_vicap_set_slave_enable#
Description:
Enable slave mode.
Syntax:
Parameters:
Parameter Name |
Input/Output |
id |
Slave mode ID |
Input |
enable |
Enable or disable slave mode |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
2.1.16 kd_mpi_vicap_set_slave_attr#
Description:
Set slave mode parameters.
Syntax:
Parameters:
Parameter Name |
Input/Output |
id |
Slave mode ID |
Input |
info |
Slave mode parameters |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
2.1.17 kd_mpi_vicap_3d_mode_crtl#
Description:
Enable 3D mode.
Syntax:
Parameters:
Parameter Name |
Input/Output |
enable |
Enable 3D mode |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
2.2 Sensor#
2.2.1 kd_mpi_sensor_open#
Description:
Open the sensor device based on the sensor device name.
Syntax:
Parameters:
Parameter Name |
Input/Output |
sensor_name |
Sensor device name |
Input |
Return Value:
Return Value |
Positive value |
Success. Returns device descriptor |
Negative value |
Chip Differences:
None.
Requirements:
Header file: mpi_sensor_api.h
Library file: libsensor.a
Notes:
None.
None.
Related Topics:
2.2.2 kd_mpi_sensor_close#
Description:
Close the sensor device.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Sensor device file descriptor |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.3 kd_mpi_sensor_power_set#
Description:
Set the sensor power state.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
on |
Set sensor power state, K_TRUE: power on, K_FALSE: power off |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.4 kd_mpi_sensor_id_get#
Description:
Get the sensor ID.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
sensor_id |
Acquired sensor ID |
Output |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.5 kd_mpi_sensor_init#
Description:
Initialize the sensor.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
mode |
Initialize sensor configuration registers based on the specified sensor mode |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.6 kd_mpi_sensor_reg_read#
Description:
Read the content of the sensor register.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
reg_addr |
Sensor register address |
Input |
reg_val |
Content of the read register |
Output |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.7 kd_mpi_sensor_reg_write#
Description:
Write content to the sensor register.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
reg_addr |
Input |
reg_val |
Content to write to the sensor register |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.8 kd_mpi_sensor_mode_get#
Description:
Get the sensor mode configuration.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
mode |
Acquired sensor mode configuration parameters |
Output |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.9 kd_mpi_sensor_mode_set#
Description:
Set the sensor mode configuration.
Syntax:
k_s32 kd_mpi_sensor_mode_set(k_s32 fd, k_sensor_mode mode)
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
mode |
Sensor mode configuration parameters |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.10 kd_mpi_sensor_stream_enable#
Description:
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
enable |
Set sensor stream output state, 0: disable output, non-0: enable output |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.11 kd_mpi_sensor_again_set#
Description:
Set the sensor analog gain.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
gain |
Gain configuration parameters |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.12 kd_mpi_sensor_again_get#
Description:
Get the sensor analog gain.
Syntax:
k_s32 kd_mpi_sensor_again_get(k_s32 fd, k_sensor_gain *gain)
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
gain |
Output |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.13 kd_mpi_sensor_dgain_set#
Description:
Set the sensor digital gain.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
gain |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.14 kd_mpi_sensor_dgain_get#
Description:
Get the sensor digital gain.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
gain |
Output |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.15 kd_mpi_sensor_intg_time_set#
Description:
Set the sensor integration time.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
time |
Integration time configuration parameters |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.16 kd_mpi_sensor_intg_time_get#
Description:
Get the sensor integration time.
Syntax:
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
time |
Output |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.17 kd_mpi_sensor_otpdata_get#
Description:
Get the sensor OTP data.
Syntax:
k_s32 kd_mpi_sensor_otpdata_get(k_s32 fd, void *otp_data)
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
otp_data |
OTP data |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
2.2.18 kd_mpi_sensor_otpdata_set#
Description:
Set the sensor OTP data.
Syntax:
k_s32 kd_mpi_sensor_otpdata_set(k_s32 fd, void *otp_data)
Parameters:
Parameter Name |
Input/Output |
fd |
Input |
otp_data |
OTP data |
Input |
Return Value:
Return Value |
Success. |
Non-zero |
Chip Differences:
None.
Requirements:
Notes:
None.
None.
Related Topics:
3. Data Types#
3.1 VICAP#
The related data types for this functional module are defined as follows:
3.1.1 k_vicap_sensor_type#
Description: Definition of sensor types supported by the current system.
Definition:
SENSOR_TYPE_MAX,
} k_vicap_sensor_type;
Members:
Member Name |
OV9732 1-lane 10-bit 720P 30fps linear output configuration, external crystal 16M, connected to CSI0 |
OV9286 2-lane 10-bit 720P 30fps linear output configuration for IR image, external crystal 25M, connected to CSI1 |
OV9286 2-lane 10-bit 720P 30fps linear output configuration for speckle image, external crystal 25M, connected to CSI1 |
OV_OV9286_MIPI_1280X720_60FPS_10BIT_LINEAR_IR |
OV9286 2-lane 10-bit 720P 60fps linear output configuration for IR image, external crystal 25M, connected to CSI1 |
OV_OV9286_MIPI_1280X720_60FPS_10BIT_LINEAR_SPECKLE |
OV9286 2-lane 10-bit 720P 60fps linear output configuration for speckle image, external crystal 25M, connected to CSI1 |
IMX335_MIPI_2LANE_RAW12_1920X1080_30FPS_LINEAR |
IMX335 12-bit 2-lane 1080P 30fps linear output, external crystal 24M, connected to CSI0 |
IMX335_MIPI_2LANE_RAW12_2592X1944_30FPS_LINEAR |
IMX335 12-bit 2-lane full resolution 30fps linear output, external crystal 24M, connected to CSI0 |
IMX335_MIPI_4LANE_RAW12_2592X1944_30FPS_LINEAR |
IMX335 12-bit 4-lane full resolution 30fps linear output, external crystal 24M, connected to CSI0 |
IMX335_MIPI_2LANE_RAW12_1920X1080_30FPS_MCLK_7425_LINEAR |
IMX335 12-bit 2-lane 1080P 30fps linear output, chip output 74.25M clock, connected to CSI0 |
IMX335_MIPI_2LANE_RAW12_2592X1944_30FPS_MCLK_7425_LINEAR |
IMX335 12-bit 2-lane full resolution 30fps linear output, chip output 74.25M clock, connected to CSI0 |
IMX335_MIPI_4LANE_RAW12_2592X1944_30FPS_MCLK_7425_LINEAR |
IMX335 12-bit 4-lane full resolution 30fps linear output, chip output 74.25M clock, connected to CSI0 |
IMX335_MIPI_4LANE_RAW10_2XDOL |
IMX335 10-bit 4-lane full resolution 15fps 2DOL output, external crystal 24M, connected to CSI0 |
IMX335_MIPI_4LANE_RAW10_3XDOL |
IMX335 10-bit 4-lane full resolution 15fps 3DOL output, external crystal 24M, connected to CSI0 |
SC_SC035HGS_MIPI_1LANE_RAW10_640X480_120FPS_LINEAR |
SC035 10-bit 1-lane 640x480 120fps linear output, external crystal 24M, connected to CSI2 |
SC_SC035HGS_MIPI_1LANE_RAW10_640X480_60FPS_LINEAR |
SC035 10-bit 1-lane 640x480 60fps linear output, external crystal 24M, connected to CSI2 |
SC_SC035HGS_MIPI_1LANE_RAW10_640X480_30FPS_LINEAR |
SC035 10-bit 1-lane 640x480 30fps linear output, external crystal 24M, connected to CSI2 |
OV_OV9286_MIPI_1280X720_30FPS_10BIT_MCLK_25M_LINEAR_SPECKLE |
OV9286 2-lane 10-bit 720P 30fps linear output configuration for speckle image, chip output 25M clock, connected to CSI1 |
OV_OV9286_MIPI_1280X720_30FPS_10BIT_MCLK_25M_LINEAR_IR |
OV9286 2-lane 10-bit 720P 30fps linear output configuration for IR image, chip output 25M clock, connected to CSI1 |
OV_OV9732_MIPI_1280X720_30FPS_10BIT_MCLK_16M_LINEAR |
OV9732 1-lane 10-bit 720P 30fps linear output configuration, chip output 16M clock, connected to CSI0 |
OV_OV5647_MIPI_1920X1080_30FPS_10BIT_LINEAR |
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, external crystal 25M, connected to CSI2 |
OV_OV5647_MIPI_2592x1944_10FPS_10BIT_LINEAR |
OV5647 2-lane 10-bit full resolution 10fps linear output configuration, external crystal 25M, connected to CSI2 |
OV_OV5647_MIPI_640x480_60FPS_10BIT_LINEAR |
OV5647 2-lane 10-bit 640x480 60fps linear output configuration, external crystal 25M, connected to CSI2 |
OV_OV5647_MIPI_CSI0_1920X1080_30FPS_10BIT_LINEAR |
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, chip output 25M clock, connected to CSI0 |
SC_SC201CS_MIPI_1LANE_RAW10_1600X1200_30FPS_LINEAR |
SC201 1-lane 10-bit 1600x1200 30fps linear output, crystal 27M, connected to CSI1 |
SC_SC201CS_SLAVE_MODE_MIPI_1LANE_RAW10_1600X1200_30FPS_LINEAR |
SC201 1-lane 10-bit slave mode 1600x1200 30fps linear output, crystal 27M, connected to CSI1 |
OV_OV5647_MIPI_CSI1_1920X1080_30FPS_10BIT_LINEAR |
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, external crystal 25M, connected to CSI1 |
OV_OV5647_MIPI_CSI2_1920X1080_30FPS_10BIT_LINEAR |
XS9950_MIPI_CSI0_1280X720_30FPS_YUV422 |
XS9950 2-lane YUV422 720P 25fps linear output, analog camera, connected to CSI0 |
XS9950_MIPI_CSI1_1280X720_30FPS_YUV422 |
XS9950 2-lane YUV422 720P 25fps linear output, analog camera, connected to CSI1 |
OV_OV9286_MIPI_1280X720_30FPS_10BIT_MCLK_25M_LINEAR_SPECKLE_V2 |
OV_OV9286_MIPI_1280X720_30FPS_10BIT_MCLK_25M_LINEAR_IR_V2 |
OV_OV9732_MIPI_1280X720_30FPS_10BIT_MCLK_16M_LINEAR_V2 |
OV9732 1-lane 10-bit 720P 30fps linear output configuration, chip output 16M clock, connected to CSI2 |
OV_OV5647_MIPI_CSI0_1920X1080_30FPS_10BIT_LINEAR_V2 |
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, external crystal 25M, connected to CSI0 |
OV_OV5647_MIPI_CSI1_1920X1080_30FPS_10BIT_LINEAR_V2 |
OV_OV5647_MIPI_CSI2_1920X1080_30FPS_10BIT_LINEAR_V2 |
OV5647 2-lane 10-bit 1080P 30fps linear output configuration, chip output 25M clock, connected to CSI2 |
GC2053_MIPI_CSI0_1920X1080_30FPS_10BIT_LINEAR |
GC2053 2-lane 10-bit 1080P 30fps linear output configuration, chip output 16M clock, connected to CSI0 |
Notes:
This list needs to be maintained by sensor driver developers. Application developers use the sensor types defined here to open specific types of sensor devices.
3.1.2 k_vicap_dev#
Description: Definition of VICAP device IDs.
Definition:
VICAP_DEV_ID_0 = 0,
VICAP_DEV_ID_1 = 1,
VICAP_DEV_ID_2 = 2,
VICAP_DEV_ID_MAX,
} k_vicap_dev;
Members:
Member Name |
VICAP_DEV_ID_0 |
VICAP Device 0 |
VICAP_DEV_ID_1 |
VICAP Device 1 |
VICAP_DEV_ID_2 |
VICAP Device 2 |
3.1.3 k_vicap_chn#
Description: Definition of VICAP output channel numbers.
Definition:
VICAP_CHN_ID_0 = 0,
VICAP_CHN_ID_1 = 1,
VICAP_CHN_ID_2 = 2,
VICAP_CHN_ID_MAX,
} k_vicap_chn;
Members:
Member Name |
VICAP_CHN_ID_0 |
VICAP output channel 0 |
VICAP_CHN_ID_1 |
VICAP output channel 1 |
VICAP_CHN_ID_2 |
VICAP output channel 2 |
3.1.4 k_vicap_csi_num#
Description: Definition of VICAP CSI numbers.
Definition:
VICAP_CSI0 = 1,
VICAP_CSI1 = 2,
VICAP_CSI2 = 3,
} k_vicap_csi_num;
Members:
Member Name |
VICAP_CSI0 |
CSI0 |
VICAP_CSI1 |
CSI1 |
VICAP_CSI2 |
CSI2 |
Notes:
The CSI number to which the sensor is connected is determined by the hardware physical connection.
3.1.5 k_vicap_mipi_lanes#
Description: Definition of VICAP MIPI lane numbers.
Definition:
VICAP_MIPI_1LANE = 0,
VICAP_MIPI_2LANE = 1,
VICAP_MIPI_4LANE = 3,
} k_vicap_mipi_lanes;
Members:
Member Name |
VICAP_MIPI_1LANE |
1 lane |
VICAP_MIPI_2LANE |
2 lanes |
VICAP_MIPI_4LANE |
4 lanes |
Notes:
The number of MIPI lanes used by the sensor is determined by the hardware physical connection. When using 4 lanes, a maximum of two sensors can be connected.
3.1.6 k_vicap_csi_data_type#
Description: Definition of VICAP MIPI data types.
Definition:
} k_vicap_csi_data_type;
Members:
Member Name |
VICAP_CSI_DATA_TYPE_RAW8 |
RAW8 |
VICAP_CSI_DATA_TYPE_RAW10 |
RAW10 |
VICAP_CSI_DATA_TYPE_RAW12 |
RAW12 |
VICAP_CSI_DATA_TYPE_RAW14 |
RAW14 |
Notes:
3.1.7 k_vicap_data_source#
Description: Definition of VICAP data sources.
Definition:
VICAP_SOURCE_CSI0 = 0, /**< VICAP acquire data from the CSI0 */
VICAP_SOURCE_CSI1 = 1, /**< VICAP acquire data from the CSI1 */
VICAP_SOURCE_CSI1_FS_TR0 = 2, /**< VICAP acquire data from the CSI1 for flash trigger 0 */
VICAP_SOURCE_CSI1_FS_TR1 = 3, /**< VICAP acquire data from the CSI1 for flash trigger 1 */
VICAP_SOURCE_CSI2 = 4, /**< VICAP acquire data from the CSI2 */
} k_vicap_data_source;
Members:
Member Name |
VICAP_SOURCE_CSI0 |
VICAP data source is CSI0 |
VICAP_SOURCE_CSI1 |
VICAP data source is CSI1 |
VICAP_SOURCE_CSI1_FS_TR0 |
VICAP data source is CSI1 Flash trigger 0 |
VICAP_SOURCE_CSI1_FS_TR1 |
VICAP data source is CSI1 Flash trigger 1 |
VICAP_SOURCE_CSI2 |
VICAP data source is CSI2 |
Notes:
3.1.8 k_vicap_vi_dvp_port#
Description: Definition of VICAP VI DVP port numbers.
Definition:
VICAP_VI_DVP_PORT0 = 0,
VICAP_VI_DVP_PORT1 = 1,
VICAP_VI_DVP_PORT2 = 2,
VICAP_VI_DVP_PORT_MAX,
} k_vicap_vi_dvp_port;
Members:
Member Name |
VICAP_VI_DVP_PORT0 |
DVP port 0 |
VICAP_VI_DVP_PORT1 |
DVP port 1 |
VICAP_VI_DVP_PORT2 |
DVP port 2 |
Notes:
By default, port 0 corresponds to CSI0, port 1 corresponds to CSI1, and port 2 corresponds to CSI2.
Only port 0 supports HDR sensors. When using HDR mode, it must be bound to DVP port 0.
To change the port mapping relationship, binding operations are required.
3.1.9 k_vicap_vi_flash_mode#
Description: Definition of VICAP flash light control modes.
Definition:
VICAP_FLASH_NORMAL_PWM = 2,
VICAP_FLASH_DISABLE = 3, /**< disable flash light */
} k_vicap_vi_flash_mode;
Members:
Member Name |
VICAP_FLASH_FOLLOW_STROBE |
Controlled by strobe signal |
Controlled by strobe signal based on PWM mode |
VICAP_FLASH_NORMAL_PWM |
Controlled by PWM signal |
VICAP_FLASH_DISABLE |
Disabled |
Notes:
3.1.10 k_vicap_img_window#
Description: Definition of VICAP image window.
Definition:
k_u16 h_start;
k_u16 v_start;
k_u16 width;
k_u16 height;
} k_vicap_img_window;
Members:
Member Name |
h_start |
Horizontal start position |
v_start |
Vertical start position |
Image width |
Image height |
3.1.11 k_vicap_work_mode#
Description: Definition of VICAP work modes.
Definition:
VICAP_WORK_ONLINE_MODE,
VICAP_WORK_OFFLINE_MODE,
VICAP_WORK_ONLY_MCM_MODE,
} k_vicap_work_mode;
Members:
Member Name |
VICAP_WORK_ONLINE_MODE |
Online mode |
VICAP_WORK_OFFLINE_MODE |
Offline mode |
VICAP_WORK_ONLY_MCM_MODE |
Only work in MCM mode |
Notes:
When supporting multiple camera inputs, it must be specified as offline mode. When configuring VICAP_WORK_ONLY_MCM_MODE, the dumped image can only use the YUV444 format.
3.1.12 k_vicap_sensor_info#
Description: VICAP sensor configuration information.
Definition:
const char *sensor_name;
k_vicap_csi_num csi_num; /**< CSI number that the sensor connects to */
k_vicap_mipi_lanes mipi_lanes; /**< MIPI lanes that the sensor connects to */
k_vicap_data_source source_id; /**< Source ID that the sensor uses */
k_bool is_3d_sensor;
k_vicap_hdr_mode hdr_mode;
} k_vicap_sensor_info;
Members:
Member Name |
sensor_name |
Sensor name |
csi_num |
CSI number to which the sensor is connected |
mipi_lanes |
Number of MIPI lanes used by the sensor |
source_id |
VICAP data source ID used by the sensor |
is_3d_sensor |
Whether it is a 3D sensor |
phy_freq |
PHY frequency |
data_type |
MIPI CSI data type |
hdr_mode |
HDR mode |
flash_mode |
Flash light configuration mode |
sensor_type |
3.1.13 k_vicap_dump_format#
Description: VICAP dump data frame format.
Definition:
VICAP_DUMP_YUV = 0,
VICAP_DUMP_RGB = 1,
VICAP_DUMP_RAW = 2,
VICAP_DUMP_YUV444 = 3,
} k_vicap_dump_format;
Members:
Member Name |
VICAP_DUMP_YUV |
Dump YUV data |
VICAP_DUMP_RGB |
Dump RGB data |
VICAP_DUMP_RAW |
Dump RAW data |
VICAP_DUMP_YUV444 |
Dump YUV444 data |
3.1.14 k_vicap_dev_attr#
Description: VICAP device attributes.
Definition:
k_vicap_window acq_win;
k_vicap_work_mode mode;
k_u32 capture_frame;
k_bool dw_enable;
k_u32 buffer_num;
k_u32 buffer_size;
k_vicap_mirror mirror;
} k_vicap_dev_attr;
Members:
Member Name |
acq_win |
Image capture window |
mode |
VICAP work mode. When supporting multiple camera inputs, it must be specified as offline mode. |
pipe_ctrl |
ISP pipeline control switch |
capture_frame |
Number of frames to capture, range [0,1023], 0: continuous capture |
sensor_info |
dw_enable |
Dewarp enable (refer to K230_SDK_Dewarp Usage Guide.md) |
buffer_num |
Number of buffers for receiving sensor data in offline mode |
buffer_size |
Buffer size for receiving sensor data in offline mode |
mirror |
Sensor mirror function |
Notes:
For low-memory application scenarios, it is recommended to disable the 3DNR module to reduce memory usage. To disable, set pipe_ctrl.bits.dnr3_enable to 0 when setting device attributes.
3.1.15 k_vicap_chn_attr#
Description: VICAP channel attributes.
Definition:
k_vicap_window out_win;
k_vicap_window crop_win;
k_vicap_window scale_win;
k_bool crop_enable;
k_bool scale_enable;
k_bool chn_enable;
k_pixel_format pix_format;
k_u32 buffer_num;
k_u32 buffer_size;
k_u8 alignment;
} k_vicap_chn_attr;
Members:
Member Name |
out_win |
Output window size |
crop_win |
Crop window size |
scale_win |
Scale window size |
crop_enable |
Crop enable |
scale_enable |
Scale enable |
chn_enable |
Channel enable |
pix_format |
Output pixel format |
buffer_num |
Number of buffers used by the channel |
buffer_size |
Buffer size |
alignment |
Buffer alignment method |
3.1.16 k_vicap_mirror#
Description: VICAP sensor mirror function.
Definition:
VICAP_MIRROR_NONE = 0,
VICAP_MIRROR_HOR = 1,
VICAP_MIRROR_VER = 2,
VICAP_MIRROR_BOTH = 3,
} k_vicap_mirror;
Members:
Member Name |
VICAP_MIRROR_NONE |
No mirror for the sensor |
VICAP_MIRROR_HOR |
Horizontal mirror for the sensor |
VICAP_MIRROR_VER |
Vertical mirror for the sensor |
VICAP_MIRROR_BOTH |
Horizontal and vertical mirror for the sensor |
Notes:
3.2 Sensor#
The related data type definitions of this functional module are as follows:
3.2.1 k_sensor_bayer_pattern#
Definition: Definition of Bayer pattern output by the sensor.
BAYER_RGGB = 0,
BAYER_GRBG = 1,
BAYER_GBRG = 2,
BAYER_BGGR = 3,
BAYER_BUTT
} k_sensor_bayer_pattern;
Members:
Member Name |
BAYER_RGGB |
RGGB pattern |
BAYER_GRBG |
GRBG pattern |
BAYER_GBRG |
GBRG pattern |
BAYER_BGGR |
BGGR pattern |
3.2.2 k_sensor_exp_frame_type#
Description:
Definition:
SENSOR_EXPO_FRAME_TYPE_MAX
} k_sensor_exp_frame_type;
Members:
Member Name |
Linear mode, single-frame exposure |
2-frame HDR exposure mode |
3-frame HDR exposure mode |
4-frame HDR exposure mode |
3.2.3 k_sensor_exposure_param#
Description: Definition of sensor exposure parameters.
Definition:
k_u8 exp_frame_type;
} k_sensor_exposure_param;
Members:
Member Name |
exp_frame_type |
Exposure type |
gain |
Exposure gain |
exp_time |
Exposure time |
3.2.4 k_sensor_intg_time#
Description: Definition of sensor exposure time.
Definition:
} k_sensor_intg_time;
Members:
Member Name |
exp_frame_type |
Exposure type |
intg_time |
Integration time |
3.2.5 k_sensor_gain#
Description: Definition of exposure gain.
Definition:
} k_sensor_gain;
Members:
Member Name |
exp_frame_type |
Exposure type |
gain |
Exposure gain |
3.2.6 k_sensor_size#
Description: Definition of sensor-supported image sizes.
Definition:
k_u32 bounds_width;
k_u32 bounds_height;
k_u32 top;
k_u32 left;
k_u32 width;
k_u32 height;
} k_sensor_size;
Members:
Member Name |
bounds_width |
Boundary width |
bounds_height |
Boundary height |
top |
Top boundary |
left |
Left boundary |
Width |
Height |
3.2.7 k_sensor_ae_info#
Description: AE parameter configuration.
Definition:
k_u16 frame_length;
k_u16 cur_frame_length;
float one_line_exp_time;
k_u32 gain_accuracy;
float min_gain;
float max_gain;
float gain_increment;
k_u16 max_long_integration_line;
k_u16 min_long_integration_line;
k_u16 max_integration_line;
k_u16 min_integration_line;
k_u16 max_vs_integration_line;
k_u16 min_vs_integration_line;
float max_long_integration_time;
float min_long_integration_time;
float max_integration_time;
float min_integration_time;
float max_vs_integration_time;
float min_vs_integration_time;
float cur_integration_time;
float cur_long_gain;
float cur_long_again;
float cur_long_dgain;
float cur_gain;
float cur_again;
float cur_dgain;
float cur_vs_gain;
float cur_vs_again;
float cur_vs_dgain;
k_sensor_gain_info long_gain;
k_sensor_gain_info gain;
k_sensor_gain_info vs_gain;
k_sensor_gain_info a_gain;
k_sensor_gain_info a_vs_gain;
k_sensor_gain_info d_gain;
k_sensor_gain_info d_vs_gain;
k_u32 max_fps;
k_u32 min_fps;
k_u32 cur_fps;
k_sensor_auto_fps afps_info;
k_u32 hdr_ratio;
} k_sensor_ae_info;
Members:
Member Name |
frame_length |
Frame length |
cur_frame_length |
Current frame length |
one_line_exp_time |
Line exposure time (unit: s) |
gain_accuracy |
Gain accuracy |
min_gain |
Minimum gain |
max_gain |
Maximum gain |
integration_time_increment |
Integration time increment |
gain_increment |
Gain increment |
max_long_integration_line |
Maximum long frame integration line |
min_long_integration_line |
Minimum long frame integration line |
max_integration_line |
Maximum mid frame integration line |
min_integration_line |
Minimum mid frame integration line |
max_vs_integration_line |
Maximum short frame integration line |
min_vs_integration_line |
Minimum short frame integration line |
max_long_integration_time |
Maximum long frame integration time |
min_long_integration_time |
Minimum long frame integration time |
max_integration_time |
Maximum mid frame integration time |
min_integration_time |
Minimum mid frame integration time |
max_vs_integration_time |
Maximum short frame integration time |
min_vs_integration_time |
Minimum short frame integration time |
cur_long_integration_time |
Current long frame integration time |
cur_integration_time |
Current frame integration time |
cur_vs_integration_time |
Current short frame integration time |
cur_long_gain |
Current long frame gain |
cur_long_again |
Current long frame analog gain |
cur_long_dgain |
Current long frame digital gain |
cur_gain |
Current frame gain |
cur_again |
Current frame analog gain |
cur_dgain |
Current frame digital gain |
cur_vs_gain |
Current short frame gain |
cur_vs_again |
Current short frame analog gain |
cur_vs_dgain |
Current short frame digital gain |
long_gain |
Long frame gain |
gain |
Mid frame gain |
vs_gain |
Short frame gain |
a_long_gain |
Long frame analog gain |
a_gain |
Mid frame analog gain |
a_vs_gain |
Short frame analog gain |
d_long_gain |
Long frame digital gain |
d_gain |
Mid frame digital gain |
d_vs_gain |
Short frame digital gain |
max_fps |
Maximum frame rate |
min_fps |
Minimum frame rate |
cur_fps |
Current frame rate |
hdr_ratio |
HDR ratio |
3.2.8 k_sensor_mode#
Description: Sensor mode parameters.
Definition:
k_u32 index;
k_sensor_size size;
k_u32 fps;
k_u32 hdr_mode;
k_u32 stitching_mode;
k_u32 bit_width;
k_u32 bayer_pattern;
k_sensor_mipi_info mipi_info;
k_sensor_ae_info ae_info;
k_sensor_reg_list *reg_list;
} k_sensor_mode;
Members:
Member Name |
index |
Current mode index |
sensor_type |
size |
Sensor size for the current mode |
fps |
Frame rate |
hdr_mode |
HDR mode |
stitching_mode |
HDR stitching mode |
bit_width |
Output data width |
bayer_pattern |
Bayer pattern |
mipi_info |
MIPI parameter information |
ae_info |
AE parameter information |
reg_list |
Register configuration list for the current mode |
otp_type |
OTP type: sensor-specific and user-specific |
otp_date |
OTP data |
3.2.9 k_sensor_otp_date#
Description: Sensor OTP parameters.
Definition:
k_u8 otp_type;
k_u8 otp_date[20];
} k_sensor_otp_date;
Members:
Member Name |
otp_type |
otp_date |
OTP data |
4. MAPI#
[kd_mapi_vicap_get_sensor_fd]
[kd_mapi_vicap_get_sensor_info]
[kd_mapi_vicap_set_dev_attr]
[kd_mapi_vicap_set_chn_attr]
[kd_mapi_vicap_start]
[kd_mapi_vicap_stop]
[kd_mapi_vicap_dump_frame]
[kd_mapi_vicap_release_frame]
[kd_mapi_vicap_set_vi_drop_frame]
[kd_mapi_vicap_set_mclk]
[kd_mapi_vicap_tuning]
[kd_mapi_isp_ae_get_roi]
[kd_mapi_isp_ae_set_roi]
[kd_mapi_sensor_otpdata_get]
4.1 API#
4.1.1 kd_mapi_vicap_get_sensor_fd#
Description:
Get the file descriptor for the specified sensor.
Syntax:
Parameters:
Parameter Name |
Input/Output |
sensor_attr |
Sensor attributes |
Input & Output |
Return Value:
Return Value |
Success |
Non-zero |
Failure, refer to error code definitions |
Chip Differences:
Requirements:
Header file: mapi_vicap_api.h
Library file: libmapi.a
4.1.2 kd_mapi_vicap_get_sensor_info#
Description:
Get sensor configuration information based on the specified sensor configuration type. Refer to kd_mpi_vicap_get_sensor_info. Put sensor_type into sensor_info.sensor_type, usage is the same.
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.3 kd_mapi_vicap_set_dev_attr#
Description:
Set VICAP device attributes. Refer to kd_mpi_vicap_set_dev_attr. Put dev_num into dev_info.vicap_dev, usage is the same.
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.4 kd_mapi_vicap_set_chn_attr#
Description:
Set VICAP channel attributes. Refer to kd_mpi_vicap_set_chn_attr. Put dev_num into chn_info.vicap_dev, and chn_num into chn_info.vicap_chn, usage is the same.
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.5 kd_mapi_vicap_start#
Description:
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.6 kd_mapi_vicap_stop#
Description:
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.7 kd_mapi_vicap_dump_frame#
Description:
Dump VICAP data based on the specified device and output channel. Refer to kd_mpi_vicap_dump_frame.
Syntax:
k_s32 kd_mapi_vicap_dump_frame(k_vicap_dev dev_num, k_vicap_chn chn_num, k_vicap_dump_format format, k_video_frame_info *vf_info, k_u32 milli_sec)
Parameters:
Parameter Name |
Input/Output |
dev_num |
Input |
chn_num |
Input |
format |
Dump data type |
Input |
vf_info |
Output |
milli_sec |
Timeout duration |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.8 kd_mapi_vicap_release_frame#
Description:
Release the dumped data frame. Refer to kd_mpi_vicap_dump_release.
Syntax:
Parameters:
Parameter Name |
Input/Output |
dev_num |
Input |
chn_num |
Input |
vf_info |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.9 kd_mapi_vicap_set_vi_drop_frame#
Description:
Set hardware frame dropping. Refer to kd_mpi_vicap_set_vi_drop_frame.
Syntax:
Parameters:
Parameter Name |
Input/Output |
csi |
Input |
frame |
m |
Input |
n |
Input |
mode |
HDR mode |
Input |
enable |
Enable or disable |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.10 kd_mapi_vicap_set_mclk#
Description:
Set the MCLK frequency. Refer to kd_mpi_vicap_set_mclk.
Syntax:
Parameters:
Parameter Name |
Input/Output |
id |
MCLK ID |
Input |
sel |
Clock source |
Input |
mclk_div |
Division factor |
Input |
mclk_en |
Enable or disable |
Input |
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.11 kd_mapi_vicap_tuning#
Description:
Handle commands sent by the tuning client.
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.12 kd_mapi_isp_ae_get_roi#
Description:
Get AE ROI configuration.
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
Header file: mapi_isp_api.h
4.1.13 kd_mapi_isp_ae_set_roi#
Description:
Set AE ROI.
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
4.1.14 kd_mapi_sensor_otpdata_get#
Description:
Get sensor OTP data.
Syntax:
Return Value:
Return Value |
Success |
Non-zero |
Chip Differences:
Requirements:
5. Error Codes#
Table 41 VICAP API Error Codes
Error Code |
Macro Definition |
0xA0158001 |
K_ERR_VICAP_INVALID_DEVID |
Device ID out of valid range |
0xA0158002 |
K_ERR_VICAP_INVALID_CHNID |
Channel ID out of valid range |
0xA0158003 |
K_ERR_VICAP_ILLEGAL_PARAM |
Parameter out of valid range |
0xA0158004 |
K_ERR_VICAP_EXIST |
Attempt to create an already existing device, channel, or resource |
0xA0158005 |
K_ERR_VICAP_UNEXIST |
Attempt to use or destroy a non-existent device, channel, or resource |
0xA0158006 |
K_ERR_VICAP_NULL_PTR |
Null pointer in function parameters |
0xA0158007 |
K_ERR_VICAP_NOT_CONFIG |
Not configured before use |
0xA0158008 |
K_ERR_VICAP_NOT_SUPPORT |
Unsupported parameter or function |
0xA0158009 |
K_ERR_VICAP_NOT_PERM |
Operation not allowed, such as trying to modify static configuration parameters |
0xA015800C |
K_ERR_VICAP_NOMEM |
Memory allocation failure, such as insufficient system memory |
0xA015800D |
K_ERR_VICAP_NOBUF |
Buffer allocation failure, such as requesting a data buffer that is too large |
0xA015800E |
K_ERR_VICAP_BUF_EMPTY |
No data in the buffer |
0xA015800F |
K_ERR_VICAP_BUF_FULL |
Data buffer full |
0xA0158010 |
K_ERR_VICAP_NOTREADY |
System not initialized or relevant module not loaded |
0xA0158011 |
K_ERR_VICAP_BADADDR |
Address out of valid range |
0xA0158012 |
K_ERR_VICAP_BUSY |
VICAP system busy |
6. Debug Information#
For VICAP memory management and system binding debug information, refer to the “K230 System Control API Reference”.
