K230 Practical Basics - Hello World#
All rights reserved ©2023 Beijing Canaan Creative Information Technology Co., Ltd.
The products, services, or features you purchase are subject to the commercial contracts and terms of Beijing Canaan Creative Information Technology Co., Ltd. (hereinafter referred to as “the Company”) and its affiliates. All or part of the products, services, or features described in this document may not be within the scope of your purchase or use. Unless otherwise agreed in the contract, the Company does not provide any express or implied representations or warranties regarding the accuracy, reliability, completeness, merchantability, fitness for a particular purpose, and non-infringement of any statements, information, or content in this document. Unless otherwise agreed, this document is for reference only as a usage guide.
Trademark Statement#
All rights reserved © 2023 Beijing Canaan Creative Information Technology Co., Ltd. All rights reserved. No part of this document may be excerpted, copied, or disseminated in any form by any unit or individual without the written permission of the Company.
This document explains how to use a cross-compilation tool on a PC to compile a basic Hello World program and run it on a big core RT-Smart or a small core Linux.
Environment Preparation#
Hardware Environment#
K230-USIP-LP3-EVB-V1.0/K230-USIP-LP3-EVB-V1.1
Ubuntu PC 20.04
At least 2 Type-C USB cables
USB Type-C to Ethernet adapter (if using TFTP loading and NFS file system)
One Ethernet cable
SD card (if using SD card boot or if software needs to access the SD card)
Software Environment#
The k230_sdk provides toolchains located at the following paths.
Big core RT-Smart toolchain
Small core Linux toolchain
You can also download the toolchains from the following links:
Code Writing#
Create a C file named hello.c on Ubuntu and add the following code:
#include <stdio.h>
int main(void)
printf("hello world\n");
Place hello.c in the same directory level as k230_sdk.
canaan@develop:~/work$ ls
hello.c k230_sdk
Compiling an Executable for Small Core Linux#
Compiling an Executable for Big Core RT-Smart#
k230_sdk/toolchain/riscv64-linux-musleabi_for_x86_64-pc-linux-gnu/bin/riscv64-unknown-linux-musl-gcc -o hello.elf -mcmodel=medany -march=rv64imafdcv -mabi=lp64d -T k230_sdk/src/big/mpp/userapps/sample/linker_scripts/riscv64/link.lds -Lk230_sdk/src/big/rt-smart/userapps/sdk/rt-thread/lib -Wl,--whole-archive -lrtthread -Wl,--no-whole-archive -n --static hello.o -Lk230_sdk/src/big/rt-smart/userapps/sdk/lib/risc-v/rv64 -Lk230_sdk/src/big/rt-smart/userapps/sdk/rt-thread/lib/risc-v/rv64 -Wl,--start-group -lrtthread -Wl,--end-group
Running the Program#
Copy the compiled hello and hello.elf to the vfat partition of the SD card (you can see an accessible drive letter on the PC after burning the image to the SD card), or use other methods (refer to the SDK usage documentation) to copy the executables to the /sharefs directory of the small core.
After the development board starts, run the test program on the small core. Enter
rootto access the console after the small core starts.
Welcome to Buildroot
canaan login: root
[root@canaan ~ ]#cd /sharefs
hello world
Run the test program on the big core
msh /sharefs>hello.elf
hello world
Advanced Big Core Program Compilation#
When using musl-gcc to compile for the big core directly, the compilation parameters are quite extensive, which can be inconvenient and hard to understand for beginners. The current SDK provides two methods for compiling big core programs: SCons and Makefile. Here, we introduce the SCons compilation method. The Makefile compilation build is more complex and is not the official RT-Smart compilation method. Interested readers can refer to the Makefile structure in src/big/mpp/userapps/sample for compilation.
Create a folder named hello under k230_sdk/src/big/rt-smart/userapps.
mkdir hello
cd hello
Create the following three files:
hello.c
SConscript
from building import *
cwd = GetCurrentDir()
src = Glob('*.c')
CPPPATH = [cwd]
CPPDEFINES = [
'HAVE_CCONFIG_H',
Return('group')
SConstruct
import sys
# add building.py path
sys.path = sys.path + [os.path.join('..', '..', 'tools')]
BuildApplication('hello', 'SConscript', usr_root='../')
Then return to the k230_sdk/src/big/rt-smart/ directory and configure the environment variables.
Arch => riscv64
CC => gcc
EXEC_PATH => /home/canaan/k230_sdk/src/big/rt-smart/../../../toolchain/riscv64-linux-musleabi_for_x86_64-pc-linux-gnu/bin
Go to the k230_sdk/src/big/rt-smart/userapps directory and compile the program.
scons: Building targets ...
CC build/hello/hello.o
LINK hello.elf
scons: done building targets.
The compiled program is in the hello folder.
build cconfig.h hello.c hello.elf SConscript SConstruct
Afterwards, you can copy hello.elf to the small core Linux, and the big core RT-Smart can run the program via /sharefs.
