K230 Multimedia Middleware API Reference#
This document is written for programmers developing with middleware, providing reference information for multimedia middleware, including APIs, header files, etc.
Target Audience#
  • Technical Support Engineers
Abbreviation Definitions#
Abbreviation
Document Version
Author
Date
V0.1
Software Department
2023.07.20
Initial version
The middleware’s position in the system is k230_sdk/src/common/cdk/user/middleware.
This document describes the relevant parts of the middleware, involving intercom protocol, mixing, MP4 format encapsulation and decapsulation, player, etc.
Function Description#
Visual Intercom RTSP Protocol#
Referencing the ONVIF RTSP extension, it implements a single-line video visual intercom protocol;
The RTSP server supports sending audio, video, and receiving backchannel audio mediaSubSessions.
The RTSP client supports receiving audio, video, and sending backchannel audio mediaSubSessions.
For related descriptions, see the visual intercom protocol chapter.
Player#
Implements MP4 file playback. Video supports H264, H265, and audio supports G711a/u.
Mixing#
Implements two-way G711a/u mixing.
MP4 Format Encapsulation and Decapsulation#
Implements encapsulation and decapsulation between audio-video and MP4 formats.
API Reference#
Visual Intercom RTSP Server#
KdRtspServer provides the following APIs:
KdRtspServer::Init#
Description:
RTSP server initialization.
Syntax:
int Init(Port port = 8554, IOnBackChannel *back_channel = nullptr);
Parameters:
Parameter Name
Input/Output
port
RTSP service port.
Input
back_channel
Callback pointer for audio data from the other end.
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Header file: rtsp_server.h
  • Library file:
Notes:
None.
None.
Related Topics:
None.
KdRtspServer::DeInit#
Description:
Deinitialization.
Syntax:
void DeInit();
Parameters:
None.
Return Value:
None.
Requirements:
  • Library file:
None.
KdRtspServer::CreateSession#
Description:
Create RTSP session.
Syntax:
int CreateSession(const std::string &session_name, const SessionAttr &session_attr);
Parameters:
Parameter Name
Input/Output
session_name
Stream URL.
Input
session_attr
Session configuration parameters.
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Library file:
Notes:
None.
None.
KdRtspServer::DestroySession#
Description:
Destroy RTSP session.
Syntax:
int DestroySession(const std::string &session_name);
Parameters:
Parameter Name
Input/Output
session_name
Stream URL.
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Library file:
Notes:
None.
None.
Related Topics:
None.
KdRtspServer::Start#
Description:
Start RTSP server service.
Syntax:
void Start();
Parameters:
None.
Return Value:
None.
Requirements:
  • Library file:
Notes:
None.
None.
Related Topics:
None.
KdRtspServer::Stop#
Description:
Stop RTSP server service.
Syntax:
void Stop();
Parameters:
None.
Return Value:
None.
Requirements:
  • Library file:
Notes:
None.
None.
KdRtspServer::SendVideoData#
Description:
Write video stream data.
Syntax:
int SendVideoData(const std::string &session_name, const uint8_t *data, size_t size, uint64_t timestamp);
Parameters:
Parameter Name
Input/Output
session_name
Stream URL
Input
Video stream address.
Input
size
Video stream size.
Input
timestamp
Stream timestamp (milliseconds).
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Library file:
None.
KdRtspServer::SendAudioData#
Description:
Write audio stream data.
Syntax:
int SendAudioData(const std::string &session_name, const uint8_t *data, size_t size, uint64_t timestamp);
Parameters:
Parameter Name
Input/Output
session_name
Stream URL
Input
Audio stream address.
Input
size
Audio stream size.
Input
timestamp
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Library file:
None.
Visual Intercom RTSP Client#
KdRtspClient module provides the following APIs:
  • Init: Initialization.
  • DeInit: Deinitialization.
  • Open: Open and run RTSP client connection.
  • Close: Close RTSP client connection.
  • SendAudioData: Write backchannel audio stream data.
KdRtspClient::Init#
Description:
Initialization.
Syntax:
int Init(const RtspClientInitParam &param);
Parameters:
Parameter Name
Input/Output
param
RTSP client initialization parameters
Input
class IOnAudioData {
public:
    virtual ~IOnAudioData() {}
    virtual void OnAudioData(const uint8_t *data, size_t size, uint64_t timestamp) = 0;
class IOnVideoData {
public:
    enum VideoType {VideoTypeInvalid, VideoTypeH264, VideoTypeH265};
    virtual ~IOnVideoData() {}
    virtual void OnVideoType(VideoType type, uint8_t *extra_data, size_t extra_data_size) = 0;
    virtual void OnVideoData(const uint8_t *data, size_t size, uint64_t timestamp, bool keyframe) = 0;
class IRtspClientEvent {
public:
    virtual ~IRtspClientEvent() {}
    virtual void OnRtspClientEvent(int event) = 0; // event 0: shutdown
struct RtspClientInitParam {
    IOnVideoData *on_video_data{nullptr}; // Callback for video stream frames received from the server
    IOnAudioData *on_audio_data{nullptr}; // Callback for audio stream frames received from the server
    IRtspClientEvent *on_event{nullptr};  // RTSP client event callback
    bool enableBackchannel{false};        // Whether to enable audio backchannel
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Header file: rtsp_client.h
  • Library file:
Notes:
None.
None.
Related Topics:
None.
KdRtspClient::Deinit#
Description:
Deinitialization.
Syntax:
void DeInit();
Parameters:
None.
Return Value:
None.
Requirements:
  • Library file:
Notes:
None.
None.
Related Topics:
None.
KdRtspClient::Open#
Description:
Syntax:
int Open(const char *url);
Parameters:
Parameter Name
Input/Output
url
RTSP URL.
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Library file:
Notes:
None.
None.
Related Topics:
None.
KdRtspClient::Close#
Description:
Close RTSP client.
Syntax:
void Close();
Parameters:
None.
Return Value:
None.
Requirements:
  • Library file:
Notes:
None.
None.
Related Topics:
None.
KdRtspClient::SendAudioData#
Description:
Syntax:
int SendAudioData(const uint8_t *data, size_t size, uint64_t timestamp);
Parameters:
Parameter Name
Input/Output
Address of audio stream data
Input
size
Size of audio stream data
Input
timestamp
Timestamp of audio stream data (milliseconds)
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Library file:
Notes:
None.
None.
Related Topics:
None.
Player Encapsulation#
KdPlayer module provides the following APIs:
kd_player_init#
Description:
Player initialization.
Syntax:
k_s32 kd_player_init();
Parameters:
None.
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Header file: kplayer.h
  • Library file: libkplayer.a
Notes:
None.
None.
Related Topics:
None.
kd_player_deinit#
Description:
Deinitialization.
Syntax:
k_s32 kd_player_deinit();
Parameters:
None.
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
None.
None.
Related Topics:
None.
kd_player_setdatasource#
Description:
Set media playback file.
Syntax:
k_s32 kd_player_setdatasource(const k_char* filePath);
Parameters:
Parameter Name
Input/Output
filePath
Media file path
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
None.
None.
Related Topics:
None.
kd_player_regcallback#
Description:
Register player event callback.
Syntax:
k_s32 kd_player_regcallback(K_PLAYER_EVENT_FN pfnCallback, void* pData);
Parameters:
Parameter Name
Input/Output
pfnCallback
Callback function pointer
Input
pData
Callback data pointer
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
None.
None.
Related Topics:
None.
kd_player_start#
Description:
Start playback.
Syntax:
k_s32 kd_player_start();
Parameters:
None.
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
None.
None.
Related Topics:
None.
kd_player_stop#
Description:
Stop playback.
Syntax:
k_s32 kd_player_stop();
Parameters:
None.
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
None.
None.
Related Topics:
None.
Audio Mixing#
The mixing module provides the following APIs:
kd_mix_g711a_audio#
Description:
g711a mixing.
Syntax:
k_s32 kd_mix_g711a_audio(k_char *src_data1, k_char *src_data2, k_u32 data_len, k_char *dst_mix_data);
Parameters:
Parameter Name
Input/Output
src_data1
Source data 1
Input
src_data2
Source data 2
Input
data_len
Length of data
Input
dst_mix_data
Mixed result data
Output
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Header file: g711_mix_audio.h
  • Library file: libaudio_mix.a
Notes:
None.
None.
Related Topics:
None.
kd_mix_g711u_audio#
Description:
g711u mixing.
Syntax:
k_s32 kd_mix_g711u_audio(k_char *src_data1, k_char *src_data2, k_u32 data_len, k_char *dst_mix_data);
Parameters:
Parameter Name
Input/Output
src_data1
Source data 1
Input
src_data2
Source data 2
Input
data_len
Length of data
Input
dst_mix_data
Mixed result data
Output
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
None.
None.
Related Topics:
None.
The MP4 format encapsulation and decapsulation provide the following APIs:
kd_mp4_create#
Description:
Create MP4 instance.
Syntax:
int kd_mp4_create(KD_HANDLE *mp4_handle, k_mp4_config_s *mp4_cfg);
Parameters:
Parameter Name
Input/Output
mp4_handle
MP4 instance handle
Output
mp4_cfg
Configuration parameters
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
  • Header file: mp4_format.h
  • Library file: libmp4.a
Notes:
The configuration information in mp4_cfg can specify whether the created MP4 instance is a muxer or demuxer instance.
Refer to samples under mp4_muxer and mp4_demuxer.
Related Topics:
None.
kd_mp4_destroy#
Description:
Destroy MP4 instance.
Syntax:
int kd_mp4_destroy(KD_HANDLE mp4_handle);
Parameters:
Parameter Name
Input/Output
mp4_handle
MP4 instance handle
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
None.
Related Topics:
None.
kd_mp4_create_track#
Description:
Create track for MP4.
Syntax:
int kd_mp4_create_track(KD_HANDLE mp4_handle, KD_HANDLE *track_handle, k_mp4_track_info_s *mp4_track_info);
Parameters:
Parameter Name
Input/Output
mp4_handle
MP4 instance handle
Input
track_handle
Track handle
Output
mp4_track_info
Track configuration
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
  • This API is for muxer. Use when the created MP4 instance is a muxer instance.
  • Currently, each MP4 supports creating up to 3 tracks.
Refer to samples under mp4_muxer.
Related Topics:
None.
kd_mp4_destroy_tracks#
Description:
Destroy all tracks for MP4.
Syntax:
int kd_mp4_destroy_tracks(KD_HANDLE mp4_handle);
Parameters:
Parameter Name
Input/Output
mp4_handle
MP4 instance handle
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
  • Call this interface after creating the MP4 instance and tracks.
Related Topics:
None.
kd_mp4_write_frame#
Description:
Write frame data to MP4.
Syntax:
int kd_mp4_write_frame(KD_HANDLE mp4_handle, KD_HANDLE track_handle, k_mp4_frame_data_s *frame_data);
Parameters:
Parameter Name
Input/Output
mp4_handle
MP4 instance handle
Input
track_handle
Track handle
Input
frame_data
Frame data information
Input
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
Related Topics:
None.
kd_mp4_get_file_info#
Description:
Get MP4 file information.
Syntax:
int kd_mp4_get_file_info(KD_HANDLE mp4_handle, k_mp4_file_info_s *file_info);
Parameters:
Parameter Name
Input/Output
mp4_handle
MP4 instance handle
Input
file_info
Output
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
  • This API is for demuxer. Use when the created MP4 instance is a demuxer instance.
Refer to samples under mp4_demuxer.
Related Topics:
None.
kd_mp4_get_track_by_index#
Description:
Get track information by index.
Syntax:
int kd_mp4_get_track_by_index(KD_HANDLE mp4_handle, uint32_t index, k_mp4_track_info_s *mp4_track_info);
Parameters:
Parameter Name
Input/Output
mp4_handle
MP4 instance handle
Input
index
Index
Input
mp4_track_info
Track information
Output
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
Related Topics:
None.
kd_mp4_get_frame#
Description:
Get track stream information.
Syntax:
int kd_mp4_get_frame(KD_HANDLE mp4_handle, k_mp4_frame_data_s *frame_data);
Parameters:
Parameter Name
Input/Output
mp4_handle
MP4 instance handle
Input
frame_data
Stream information
Output
Return Value:
Success.
Non-0
Failure.
Requirements:
Notes:
Related Topics:
None.
