K230 FAQ#
- K230 SDK Frequently Asked Questions (C)
- TF Boot Failed with Exit Code 13
- Bootrom Startup Error Codes
- SPI NOR and SPI NAND Flash Identification
- Perf Usage
- Running Vector Linux on the Big Core
- Big Core Serial Port ID
- Uboot Command Line
- How to Change Slow Boot to Fast Boot
- How to Modify the Size of the Last Partition in Linux
- How to Modify Bootargs
- How to View Bootargs
- How to Modify the Default Serial Port of the Small Core
- How to Completely Recompile the SDK
- Where is the List of Supported Sensors
- Can the Canmmv Board Use Pingtouge’s CKLink for JTAG Debugging
- How to Quickly Compile a Specific Package Under Buildroot
- How to Run Only the RTT System and Mount the SD Card on Canmv
- How to Quickly Verify Serial Port Transmission and Reception in Linux
- How to Quickly Modify Linux Configuration
- How to Switch the Auto-Start Program on the Big Core
- Can libxml2 Be Used?
- What Screens Are Supported?
- K230 nncase FAQ
- Error Installing whl Package
- Error Compiling Model
System.NotSupportedException: Not Supported *** op: XXX
System.IO.IOException: The configured user limit (128) on the number of inotify instances has been reached, or the per-process limit on the number of open file descriptors has been reached
RuntimeError: Failed to initialize hostfxr.
orRuntimeError: Failed to get hostfxr path.
The given key 'K230' was not present in the dictionary
- Errors During Inference
- Errors During Inference on K230 Development Board
- K230 AI Demo Frequently Asked Questions (C++)
- AI Cube Frequently Asked Questions
