K230 DMA API Reference#
This document mainly introduces the design of the K230 GSDMA software, including the GSDMA driver framework and software implementation.
Intended Audience#
This document (this guide) is mainly for the following personnel:
  • Technical Support Engineers
Abbreviation Definitions#
Abbreviation
GDMA
Graphic Direct Memory Access
SDMA
System Direct Memory Access
Document Version
Modification Description
Author
Date
Initial version
Liu Suntao
2023/3/7
V1.1
Modified some descriptions of binding mode; added function interface description for frame number release.
Liu Suntao
2023/3/31
V1.2
Replaced the data structure of the image address; added frame number passthrough function.
Liu Suntao
2023/4/26
V1.3
Added configurable buffer functionality
Liu Suntao
2023/5/31
GSDMA: DMA stands for Direct Memory Access, which copies data from one address space to another, providing high-speed data transfer between memory and memory. GDMA stands for Graphic Direct Memory Access, responsible for copying images in memory to another memory area, and can also perform image rotation and mirroring functions. SDMA stands for System Direct Memory Access, responsible for copying data in memory to another memory area, which is the traditional DMA.
The software code provides the various functions of the GSDMA hardware in the form of APIs to users, helping them quickly achieve image transfer, rotation, mirroring, 2D functions, and data transfer functions. It also implements module status information statistics and other functions.
Function Description#
Abstract the DMA hardware as a device with eight channels, where channels 0 to 3 are GDMA channels, and channels 4 to 7 are SDMA channels.
GDMA#
Users can achieve image rotation and mirroring work through GDMA, and the main call flow is as follows:
  1. Configure DMA device attributes;
  2. Start the DMA device. After calling this function, the driver will automatically request VB space as the data buffer for the destination address;
  3. Configure GDMA channel attributes;
  4. Start the GDMA channel;
  5. Users request VB space in user mode as the data buffer for the source data, and call kd_mpi_dma_send_frame to send the source address of the data to GDMA;
  6. The driver will transfer the data from the source address to the data buffer of the destination address requested in step two;
  7. Users call kd_mpi_dma_get_frame to get the data address in the destination address.
SDMA#
Users can achieve data transfer work through SDMA, and the main call flow is as follows:
  3. Configure SDMA channel attributes;
  4. Start the SDMA channel;
  5. Users request VB space in user mode as the data buffer for the source data, and call kd_mpi_dma_send_frame to send the source address of the data to SDMA;
API Reference#
DMA Usage#
kd_mpi_dma_set_dev_attr#
Description:
Syntax:
Parameters:
Parameter Name
Input/Output
attr
Pointer to DMA device attribute structure.
Input
Return Value:
Success
Non-zero
Failure, see error codes for details
Chip Differences:
None.
Requirements:
  • Header file: mpi_dma_api.h
  • Library file: libdma.a
Notes:
Related Topics:
k_dma_dev_attr_t
kd_mpi_dma_get_dev_attr#
Description:
Get the configured DMA device attributes.
Syntax:
Parameters:
Parameter Name
Input/Output
attr
Input
Return Value:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
You need to configure DMA device attributes before you can get DMA device attributes.
Related Topics:
k_dma_dev_attr_t
kd_mpi_dma_start_dev#
Description:
Syntax:
k_s32 kd_mpi_dma_start_dev();
Parameters:
Parameter Name
Input/Output
Return Value:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
You need to configure DMA device attributes before you can call this function to start DMA.
Related Topics:
kd_mpi_dma_stop_dev#
Description:
Stop the DMA device.
Syntax:
kd_mpi_dma_stop_dev();
Parameters:
Parameter Name
Input/Output
Return Value:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
You can only call this function to stop the DMA device after starting the DMA device.
Related Topics:
kd_mpi_dma_set_chn_attr#
Description:
Configure DMA channel attributes.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
attr
DMA channel attributes, this parameter is a union, you can choose to configure GDMA channel attributes or SDMA channel attributes. Channels 0-3 are GDMA, channels 4-7 are SDMA
Input
Return Value:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
Related Topics:
k_dma_chn_attr_u
kd_mpi_dma_get_chn_attr#
Description:
Get the configured DMA channel attributes.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
attr
DMA channel attributes, this parameter is a union, you can choose to get GDMA channel attributes or SDMA channel attributes. Channels 0-3 are GDMA, channels 4-7 are SDMA
Output
Return Value:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
You need to configure DMA channel attributes before you can get DMA channel attributes.
Related Topics:
k_dma_chn_attr_u
kd_mpi_dma_start_chn#
Description:
Start the DMA channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
Return Value:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
You can only start the DMA channel after configuring and starting the DMA device and configuring the DMA channel attributes.
Related Topics:
kd_mpi_dma_stop_chn#
Description:
Pause the DMA channel.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
Return Value:
Success
Non-zero
Chip Differences:
None.
Requirements:
Notes:
You can only call this function to stop the DMA channel after starting the DMA channel.
Related Topics:
kd_mpi_dma_send_frame#
Description:
Send data from user space to the destination address.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
df_info
Address information of the data to be sent
Input
millisec
Waiting time. When this parameter is set to -1, it is blocking; when set to 0, it is non-blocking; when set to a value greater than 0, it will wait for the corresponding time until the data is successfully sent. If it times out and still fails to send, it returns a failure.
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
k_video_frame_info
kd_mpi_dma_get_frame#
Description:
Get the data transferred by DMA.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
df_info
Address information for getting the data
Output
millisec
Waiting time. When this parameter is set to -1, it is blocking; when set to 0, it is non-blocking; when set to a value greater than 0, it will wait for the corresponding time until the data is successfully obtained. If it times out and still fails to send, it returns a failure.
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
Related Topics:
k_video_frame_info
kd_mpi_dma_release_frame#
Description:
Release the obtained DMA data.
Syntax:
Parameters:
Parameter Name
Input/Output
chn_num
Channel number
Input
df_info
Data to be released
Input
Return Value:
Success
Non-zero
Chip Differences:
Requirements:
Notes:
  • In the current design, the DMA output buffer is 3. If you obtain 3 frames of data without calling this function to release them, you cannot continue to input data. Therefore, users should release the data promptly after obtaining and using it.
Related Topics:
k_video_frame_info
Data Types#
Common Data Types#
DMA_MAX_DEV_NUMS#
Description:
Maximum number of DMA devices
Definition:
#define DMA_MAX_DEV_NUMS (1)
Notes:
DMA_MAX_CHN_NUMS#
Description:
Maximum number of DMA channels
Definition:
#define DMA_MAX_CHN_NUMS (8)
Notes:
k_dma_mode_e#
Description:
Defines the DMA working mode.
Definition:
    DMA_BIND,
    DMA_UNBIND,
} k_dma_mode_e;
Members:
Member Name
BIND
Binding mode
UNBIND
Non-binding mode
Notes:
k_dma_dev_attr_t#
Description:
Defines the DMA device attributes.
Definition:
    k_u8 burst_len;
    k_u8 outstanding;
    k_bool ckg_bypass;
} k_dma_dev_attr_t;
Members:
Member Name
burst_len
Configures the DMA burst length
outstanding
Configures the DMA outstanding
ckg_bypass
Configures the clock gate bypass
Notes:
k_dma_chn_attr_u#
Description:
Defines the DMA channel attributes.
Definition:
typedef union
    k_gdma_chn_attr_t gdma_attr;
    k_sdma_chn_attr_t sdma_attr;
} k_dma_chn_attr_u;
Members:
Member Name
gdma_attr
sdma_attr
Notes:
k_video_frame_info#
Description:
Defines the DMA data address.
Definition:
} k_video_frame_info;
Members:
Member Name
v_frame
Timestamp, valid in binding mode
pool_id
Pool ID of the data VB pool
mod_id
Module ID
Notes:
k_video_frame#
Description:
Defines the DMA data address. Uses the common data structure k_video_frame, only part of the members are used.
Definition:
    k_u64 phys_addr[3];
    k_u64 virt_addr[3];
    k_u32 time_ref;
    k_u64 pts;
} k_video_frame;
Members:
Member Name
phys_addr
Physical address of the image. If it is a single-channel image, only configure the first physical address; if it is a dual-channel image, configure the first two physical addresses; if it is a three-channel image, configure all three physical addresses.
virt_addr
Virtual address of the image. If it is a single-channel image, only configure the first virtual address; if it is a dual-channel image, configure the first two virtual addresses; if it is a three-channel image, configure all three virtual addresses.
time_ref
Frame number for passthrough, valid in binding mode
pts
Timestamp for passthrough, valid in binding mode
Notes:
GDMA Channel Data Types#
GDMA_MAX_CHN_NUMS#
Description:
Maximum number of GDMA channels
Definition:
#define GDMA_MAX_CHN_NUMS (4)
Notes:
k_gdma_rotation_e#
Description:
Defines the GDMA channel rotation angle.
Definition:
} k_gdma_rotation_e;
Notes:
k_gdma_chn_attr_t
k_pixel_format_dma_e#
Description:
Defines the GDMA image format.
Definition:
    DMA_PIXEL_FORMAT_RGB_444 = 0,
    DMA_PIXEL_FORMAT_RGB_555,
    DMA_PIXEL_FORMAT_RGB_565,
    DMA_PIXEL_FORMAT_RGB_888,
    DMA_PIXEL_FORMAT_BGR_444,
    DMA_PIXEL_FORMAT_BGR_555,
    DMA_PIXEL_FORMAT_BGR_565,
    DMA_PIXEL_FORMAT_BGR_888,
    DMA_PIXEL_FORMAT_ARGB_1555,
    DMA_PIXEL_FORMAT_ARGB_4444,
    DMA_PIXEL_FORMAT_ARGB_8565,
    DMA_PIXEL_FORMAT_ARGB_8888,
    DMA_PIXEL_FORMAT_ABGR_1555,
    DMA_PIXEL_FORMAT_ABGR_4444,
    DMA_PIXEL_FORMAT_ABGR_8565,
    DMA_PIXEL_FORMAT_ABGR_8888,
    /* SVP data format */
} k_pixel_format_dma_e;
k_gdma_chn_attr_t#
Description:
Defines the GDMA channel attributes.
Definition:
    k_u8 buffer_num;
    k_gdma_rotation_e rotation;
    k_bool x_mirror;
    k_bool y_mirror;
    k_u16 width;
    k_u16 height;
    k_u16 src_stride[3];
    k_u16 dst_stride[3];
    k_dma_mode_e work_mode;
} k_gdma_chn_attr_t;
Members:
Member Name
buffer_num
Number of GDMA channel buffers, at least 1.
rotation
x_mirror
Whether the GDMA channel performs horizontal mirroring.
y_mirror
Whether the GDMA channel performs vertical mirroring.
GDMA channel width, in pixels.
GDMA channel height, in pixels.
src_stride
GDMA source data stride. If the image format is single-channel mode, configure src_stride[0] only; if it is dual-channel mode, configure src_stride[0] and src_stride[1]; if it is three-channel mode, configure src_stride[0], src_stride[1], and src_stride[2].
dst_stride
GDMA destination data stride. If the image format is single-channel mode, configure dst_stride[0] only; if it is dual-channel mode, configure dst_stride[0] and dst_stride[1]; if it is three-channel mode, configure dst_stride[0], dst_stride[1], and dst_stride[2].
work_mode
Work mode, can choose binding mode or non-binding mode.
pixel_format
Image format.
Notes:
SDMA Channel Data Types#
SDMA_MAX_CHN_NUMS#
Description:
Maximum number of SDMA channels
Definition:
#define SDMA_MAX_CHN_NUMS (4)
Notes:
k_sdma_data_mode_e#
Description:
Defines the data transfer mode of the SDMA channel.
Definition:
    DIMENSION1,
    DIMENSION2,
} k_sdma_data_mode_e;
Members:
Member Name
DIMENSION1
1D DMA transfer mode
DIMENSION2
2D DMA transfer mode
Notes:
k_sdma_chn_attr_t
k_sdma_chn_attr_t#
Description:
Defines the attributes of the SDMA channel.
Definition:
    k_u8 buffer_num;
    k_u32 line_size;
    k_u16 line_num;
    k_u16 line_space;
    k_sdma_data_mode_e data_mode;
} k_sdma_chn_attr_t;
Members:
Member Name
buffer_num
Number of SDMA channel buffers, at least 1.
line_size
For 1D mode, it is the total length of the transfer data; for 2D mode, it is the length of a single line of data.
line_num
For 1D mode, this member is invalid; for 2D mode, it is the number of lines to transfer.
line_space
For 1D mode, this member is invalid; for 2D mode, it is the space between lines.
data_mode
SDMA data transfer mode, includes 1D mode and 2D mode.
work_mode
Notes:
k_dma_chn_attr_u
Error Codes#
DMA Error Codes#
Table 41
Error Code
Macro Definition
0xa00148001
K_ERR_DMA_INVALID_DEVID
Invalid device ID
0xa00148002
K_ERR_DMA_INVALID_CHNID
Invalid channel ID
0xa00148003
K_ERR_DMA_ILLEGAL_PARAM
Illegal parameter
0xa00148004
K_ERR_DMA_EXIST
DMA device already exists
0xa00148005
K_ERR_DMA_UNEXIST
DMA device does not exist
0xa00148006
K_ERR_DMA_NULL_PTR
Null pointer error
0xa00148007
K_ERR_DMA_NOT_CONFIG
DMA not configured
0xa00148008
K_ERR_DMA_NOT_SUPPORT
Unsupported function
0xa00148009
K_ERR_DMA_NOT_PERM
Operation not permitted
0xa0014800c
K_ERR_DMA_NOMEM
Memory allocation failed, e.g., insufficient system memory
0xa0014800d
K_ERR_DMA_NOBUF
Insufficient buffer
0xa0014800e
K_ERR_DMA_BUF_EMPTY
Buffer is empty
0xa0014800f
K_ERR_DMA_BUF_FULL
Buffer is full
0xa00148010
K_ERR_DMA_NOTREADY
Device not ready
0xa00148011
K_ERR_DMA_BADADDR
Invalid address
0xa00148012
K_ERR_DMA_BUSY
DMA is busy
Debug Information#
Debug information uses the proc file system, which can reflect the current system running status in real-time. The recorded information can be used for problem localization and analysis.
File Directory:
/proc/
File List:
File Name
umap/dma
Records the current usage of the DMA module
System Binding#
System Binding Debug Information#
Debug Information:
msh />cat /proc/umap/dma
0 0 0 0
-------------------------------dma chn 0~3 attr info-------------------------------
0 0 false false 0 0 BIND
1 0 false false 0 0 BIND
2 0 false false 0 0 BIND
3 0 false false 0 0 BIND
-------------------------------dma chn 4~7 attr info-------------------------------
4 0 0 0 1 DIMENSION BIND
5 0 0 0 1 DIMENSION BIND
6 0 0 0 1 DIMENSION BIND
7 0 0 0 1 DIMENSION BIND
Debug Information Analysis:
Records the current usage of the DMA module.
Device Parameter Description:
Parameter
Description:
DevId
Device ID
burst_len
DMA burst length
outstanding
DMA outstanding
GDMA Channel Parameter Description:
Parameter
Description:
ChnId
Channel ID
rotation
Rotation degree
x_mirror
Whether horizontal mirroring is applied
y_mirror
Whether vertical mirroring is applied
Image width in pixels
Image height in pixels
work_mode
Work mode
SDMA Channel Parameter Description:
Parameter
Description:
ChnId
Channel ID
line_size
line_num
line_space
data_mode
work_mode
Demo Description#
Non-binding Mode Demo#
The non-binding mode demo is located at /bin/sample_dma.elf. After executing /bin/sample_dma.elf, it starts running in a loop. Press ‘e’ + Enter to stop running.
The demo mainly implements the following functions:
  • Use channel 0 to transfer an image with a resolution of 1920x1080, 8-bit, YUV400 single channel, and output it after GDMA rotates it by 90 degrees.
  • Use channel 1 to transfer an image with a resolution of 1280x720, 8-bit, YUV420 dual channel, and output it after GDMA rotates it by 180 degrees.
  • Use channel 2 to transfer an image with a resolution of 1280x720, 10-bit, YUV420 triple channel, and output it after GDMA performs horizontal and vertical mirroring.
  • Use channel 4 to transfer data using SDMA in 1D mode.
  • Use channel 5 to transfer data using SDMA in 2D mode.
Binding Mode Demo#
The binding mode demo is located at /bin/sample_dma_bind.elf. After executing /bin/sample_dma_bind.elf, it starts running in a loop. Press ‘e’ + Enter to stop running.
  • Use the VVI module as the front-end bound simulated input for GSDMA to test the binding function.
  • Two channels respectively input images with a resolution of 640x320, 8-bit, YUV400 single channel, and output them after GDMA rotates them by 90 degrees and 180 degrees respectively.
