K230 RVV Practical Guide#
RVV (RISC-V Vector Extension) refers to the vector extension of the RISC-V instruction set architecture. RISC-V is an open-source instruction set architecture known for its simplicity, scalability, and wide range of applications. RVV, as an optional extension of RISC-V, aims to support vector processing and parallel computing. RVV defines a set of new instructions for executing vector operations. These instructions allow multiple data elements to be processed simultaneously, thereby improving computational efficiency and throughput. Vector operations can be executed in a single instruction without needing loops or individual operations for each data element. RVV supports different vector lengths, which can be fixed or configurable based on application requirements. It also supports various data types, including integers, floating-point numbers, and fixed-point numbers.
The introduction of RVV provides processors with vector processing and parallel computing capabilities, accelerating various applications such as image processing, signal processing, machine learning, and scientific computing. The openness and scalability of RVV also enable manufacturers and developers to customize and optimize according to their needs. The K230 uses the XuanTie C908 dual-core processor, with the larger core C908 featuring the RVV1.0 extension. This document describes how to use the RVV functionality on the larger core rt-smart and experience the performance acceleration brought by RVV.
Environment Preparation#
Hardware Environment#
Software Environment#
k230_SDK
Using RVV Functionality#
Source Code Writing#
To experience the advantages of RVV in vector computation, we will use image scaling as an application scenario and write a demo. Create a folder in the following path of the SDK:
Note that running make or make rt-smart in the k230_sdk directory may overwrite your changes. You can copy the completed source code to the following directory:
Source Code#
Create a C source file named scale.c in the scale directory:
#include <stdio.h>
#include <stdlib.h>
#include <stddef.h>
#include <stdint.h>
#include <time.h>
#pragma pack(push, 1)
    unsigned short signature;
    unsigned int fileSize;
    unsigned short reserved1;
    unsigned short reserved2;
    unsigned int dataOffset;
} BitmapFileHeader;
    unsigned int headerSize;
    int width;
    int height;
    unsigned short planes;
    unsigned short bitsPerPixel;
    unsigned int compression;
    unsigned int imageSize;
    int xPixelsPerMeter;
    int yPixelsPerMeter;
    unsigned int colorsUsed;
    unsigned int colorsImportant;
} BitmapInfoHeader;
#pragma pack(pop)
    // Read input BMP file
    if (inputFile == NULL) {
        return;
    BitmapFileHeader fileHeader;
    BitmapInfoHeader infoHeader;
    fclose(inputFile);
    // Calculate scaled image dimensions
    // Create output BMP file
    if (outputFile == NULL) {
        free(originalImageData);
        return;
    // Update BMP file header information
    clock_t start, finish;
    start = clock();
    // Scale image data
    finish = clock();
    printf("scale calc use time:%f ms\n", (double)(finish - start) / CLOCKS_PER_SEC);
    // Write the scaled image data
    fclose(outputFile);
    free(scaledImageData);
int main()
    float scaleFactor = 0.5; // Scaling factor
SCONS Configuration File#
  • Create SConscript file
from building import *
cwd = GetCurrentDir()
src = Glob('*.c')
CPPPATH = [cwd]
CPPDEFINES = [
    'HAVE_CCONFIG_H',
Return('group')
  • Create SConstruct file
import sys
# add building.py path
Compilation#
Enter the directory src/big/rt-smart and run the script source smart-env.sh riscv64 to configure the environment variables.
$ source smart-env.sh riscv64
Arch         => riscv64
CC           => gcc
EXEC_PATH    => /home/testUser/k230_sdk/src/big/rt-smart/../../../toolchain/riscv64-linux-musleabi_for_x86_64-pc-linux-gnu/bin
Enter the userapps/testcases/scale directory and run scons --release to compile.
$ cd userapps/testcases/scale
$ scons --release
scons: Building targets ...
CC build/scale/scale.o
LINK scale.elf
scons: done building targets.
Rename the compiled program
Edit the k230_sdk/src/big/rt-smart/tools/riscv64.py file to remove the v extension from the compilation options.
index 16fc9b2..c045bf5 100644
--- a/tools/riscv64.py
+++ b/tools/riscv64.py
                 EXT_CFLAGS = ''
                 EXT_LFLAGS = ''
-            DEVICE = ' -mcmodel=medany -march=rv64imafdcv -mabi=lp64d'
+            DEVICE = ' -mcmodel=medany -march=rv64imafdc -mabi=lp64d'
             self.CFLAGS    = configuration.get('CFLAGS', DEVICE + ' -Werror -Wall' + EXT_CFLAGS)
             self.AFLAGS    = configuration.get('AFLAGS', ' -c' + DEVICE + ' -x assembler-with-cpp -D__ASSEMBLY__ -I.' + EXT_CFLAGS)
             LINK_SCRIPT    = configuration.get('LINK_SCRIPT', os.path.join(USR_ROOT, 'linker_scripts', 'riscv64', 'link.lds'))
Recompile the source code, then copy both compiled scale.elf and scale_with_rvv.elf to the sharefs directory for execution.
Execution#
Prepare a 24-bit BMP image named input.bmp (you can use PC drawing software to save and generate it), place it in the same directory as the program, and then run these two programs on the large core through sharefs.
msh /sharefs>scale.elf
scale calc use time:0.013952 ms
scale calc use time:0.013960 ms
scale calc use time:0.013941 ms
scale calc use time:0.013936 ms
scale calc use time:0.013945 ms
scale calc use time:0.013957 ms
scale calc use time:0.010139 ms
scale calc use time:0.010133 ms
scale calc use time:0.010135 ms
scale calc use time:0.010144 ms
scale calc use time:0.010142 ms
From the printed information, it is evident that using the V extension instructions significantly speeds up array calculations. If the image resolution is increased to 4K, the contrast will be even more apparent.
Disassembly#
You can use the objdump tool in the source directory to disassemble and confirm whether vector instructions are generated.
$ riscv64-unknown-linux-musl-objdump scale_with_rvv.elf -S | grep 'vadd'
   200002c7e:03bf4dd7          vadd.vx v27,v27,t5
   200002c94:03834c57          vadd.vx v24,v24,t1
$ riscv64-unknown-linux-musl-objdump scale_with_rvv.elf -S | grep 'vmul'
   200002c98:97856c57          vmul.vx v24,v24,a0
