K230 SDK Frequently Asked Questions (C)#
TF Boot Failed with Exit Code 13#
Issue: TF card boot reports boot failed with exit code 13 error
Answer: The reasons are as follows: 1. File error in the boot medium. 2. Incorrect boot pin settings.
Special note on TF card boot pin settings: The TF card will only boot when the two boot pins are high (need to be switched to the silk screen positions 1 and 2, which is the opposite direction of ON).
Bootrom Startup Error Codes#
Issue: What is the meaning of the bootrom startup error codes?
When bootrom boot fails, it will print an error similar to boot failed with exit code 19. The last digit is the error reason. The common error meanings are as follows:
Value |
Meaning |
13 |
File error in the boot medium |
19 |
Boot medium initialization failed, such as no SD card inserted |
17 |
OTP requires a secure image, but the file in the medium is a non-secure image |
SPI NOR and SPI NAND Flash Identification#
Issue: How to know whether the EVB board is connected to SPI NOR or SPI NAND flash?
Answer: Method 1: The sub-board silkscreen is different, and the silkscreen will have NOR or NAND markings.
Method 2: The Linux startup log will print, for example, when connected to SPI NOR, it will print something similar to the following:
Perf Usage#
Issue: How to compile perf and what hardware events does it support?
Answer: You can use raw events for perf, such as perf stat -e r12. The compilation command for the perf tool is as follows:
cd src/little/linux/tools
# The target file is perf/perf, just copy this file to the board.
Special note: For versions before 1.1, make the following modifications:
# Add the following content to src/little/linux/arch/riscv/boot/dts/kendryte/k230_evb.dtsi
pmu_thead: pmu_thead {
interrupts = <17>;
# Add the following configurations to src/little/linux/arch/riscv/configs/k230_evb_defconfig
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_PERF_EVENTS=y
CONFIG_KUSER_HELPERS=y
CONFIG_DEBUG_INFO=y
CONFIG_FRAME_POINTER=y
bus-cycles [Hardware event]
cache-misses [Hardware event]
instructions [Hardware event]
ref-cycles [Hardware event]
[root@canaan ~ ]#
Running Vector Linux on the Big Core#
Issue: How to run Linux with vector support on the big core?
Answer: Please use the following command to compile:
# k230_canmv_only_linux_defconfig corresponds to the Linux image with vector support for the big core
Big Core Serial Port ID#
Issue: How to modify the serial port ID of the big core?
Answer: The configuration file CONFIG_RTT_CONSOLE_ID under configs represents the serial port ID of the big core. Modify it to the correct value.
Uboot Command Line#
How to compile a version that can enter the Uboot command line?
Answer: The configuration file CONFIG_QUICK_BOOT under configs represents quick boot. Modify it to CONFIG_QUICK_BOOT=n to generate a version that can enter the Uboot command line.
How to Change Slow Boot to Fast Boot#
Answer: Enter the Uboot command line and execute the following commands:
How to Modify the Size of the Last Partition in Linux#
Answer: You can dynamically modify the size of the last partition using the parted tool. Refer to the following commands:
umount /sharefs/
parted -l /dev/mmcblk1
mkfs.ext2 /dev/mmcblk1p4
mount /dev/mmcblk1p4 /sharefs
# Refer to the following operation log
Model: SD SD32G (sd/mmc)
Disk /dev/mmcblk1: 31.3GB
Partition Table: gpt
Disk Flags:
1 10.5MB 31.5MB 21.0MB rtt
2 31.5MB 83.9MB 52.4MB linux
Disk Flags:
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
First data block=0
232 block groups
8176 inodes per group
Disk Flags:
[root@canaan ~ ]#df -h
[root@canaan ~ ]#
How to Modify Bootargs#
Answer: Method 1: Modify the bootargs in the env file. For example, you can add the following content to the board/common/env/default.env file:
Method 2: Enter the Uboot command line and modify the bootargs using the following commands:
setenv bootargs "root=/dev/mmcblk1p3 loglevel=8 rw rootdelay=4 rootfstype=ext4 console=ttyS0,115200 earlycon=sbi"; saveenv; reset;
How to View Bootargs#
Answer: Method 1: In Linux, enter cat /proc/cmdline to view:
[root@canaan ~ ]#
Method 2: In the Linux command line, enter dmesg | grep command to view:
[root@canaan ~ ]
How to Modify the Default Serial Port of the Small Core#
Answer: Currently, the default serial port for the small core in the SDK is 0. If you need to change it to another serial port (e.g., serial port 2), please follow the steps below:
Modification 1: Modify the Uboot device tree (e.g., arch/riscv/dts/k230_evb.dts) as follows:
aliases {
uart2 = &serial2;
chosen {
serial2: serial@91402000 {
clock-frequency = <50000000>;
clock-names = "baudclk";
reg-shift = <2>;
reg-io-width = <4>;
u-boot,dm-pre-reloc;
Modification 2: Modify the Linux device tree (e.g., arch/riscv/boot/dts/kendryte/k230_evb.dts) as follows:
aliases {
serial2 = &uart2;
chosen {
stdout-path = "serial2";
&uart2 {
status = "okay";
Modification 3: Modify the bootargs in the env file (refer to section 2.10).
How to Completely Recompile the SDK#
Answer: After updating or modifying the SDK source code, it is recommended to enter the following commands to completely recompile the SDK:
make clean; make;
Where is the List of Supported Sensors#
Answer: Please refer to section 4.1 “Supported Sensor Types” in the K230_Camera_Sensor Adaptation Guide. Currently supported sensors include:
ov9732
ov9286
imx335
sc035
ov5647
sc201
Can the Canmmv Board Use Pingtouge’s CKLink for JTAG Debugging#
Answer: By default, it cannot (Uboot disables the JTAG function). You need to make the following modifications to use Pingtouge CKLink for JTAG debugging:
# Modify the gpio5 and gpio6 settings in src/little/uboot/arch/riscv/dts/k230_canmv.dts as follows:
After modification, you need to recompile the Uboot code.
How to Quickly Compile a Specific Package Under Buildroot#
Answer: Refer to the following commands to quickly recompile a specific package under Buildroot:
# Example command to recompile the lvgl package:
cd output/k230_canmv_defconfig/little/buildroot-ext/; # Using k230_canmv_defconfig as an example
make lvgl-dirclean;
make lvgl && make;
cd - # Switch back to the SDK main directory;
make build-image # Regenerate the image
For more information, search “buildroot how to rebuild packages” on Baidu.
How to Run Only the RTT System and Mount the SD Card on Canmv#
# k230_canmv_only_rtt_defconfig corresponds to an image that only runs the RTT system and mounts the SD card.
How to Quickly Verify Serial Port Transmission and Reception in Linux#
Answer: Refer to the following commands:
# Using serial port 2 as an example, modify the commands according to your actual situation:
stty -a -F /dev/ttyS2 # View serial port configuration;
stty -F /dev/ttyS2 115200 # Set the baud rate, default is 9600
echo 00000000000000000000000000000011111111111111 > /dev/ttyS2 # Send a string, the computer should receive the correct data
cat /dev/ttyS2 # Receive serial port data
How to Quickly Modify Linux Configuration#
Answer: 1). Modify the linux-savedefconfig target in the Makefile as follows (around line 382):
linux-savedefconfig:
cd $(LINUX_SRC_PATH); \
cp $(LINUX_BUILD_DIR)/defconfig arch/riscv/configs/$(LINUX_KERNEL_DEFCONFIG);\
cd -
2). Modify and save the Linux configuration:
make linux-menuconfig # Modify Linux configuration
make linux-savedefconfig # Save Linux configuration
How to Switch the Auto-Start Program on the Big Core#
Answer: If the auto-start program is in the /bin directory, modify it as follows:
// Modify the src/big/rt-smart/init.sh file to the program you need to auto-start, for example:
If the auto-start program is in the shared file system, you need to modify two places. Refer to the following modification methods:
Modification 1: Modify the src/big/rt-smart/init.sh file
// Modify the src/big/rt-smart/init.sh file to something like the following:
cd /sdcard/app/onboard
./sample_vo.elf
/sharefs/onboard/xxxx.sh
Modification 2: Add a wait for the shared file system action (applicable to SDK version 1.5 and later)
// Modify around line 34 in the src/big/rt-smart/kernel/bsp/maix3/applications/main.c file as follows:
struct stat stat_buf;
while(stat("/sharefs/onboard",&stat_buf));// Please modify to the correct file according to the actual situation
msh_exec("/bin/init.sh", 13); // The script to auto-start, please modify to the correct file according to the actual situation
Modification 2: Add a wait for the shared file system action (applicable to SDK version 1.4 and earlier)
// Modify around line 456 in the src/big/rt-smart/kernel/rt-thread/components/finsh/shell.c file as follows:
if(shell_thread_first_run) {
if(0 == stat("/sharefs/onboard",&stat_buf)){ // Please modify to the correct file according to the actual situation
continue;
Can libxml2 Be Used?#
Answer: Yes, it can. Refer to the following method to enable BR2_PACKAGE_LIBXML2 in Buildroot.
Enabling libxml2 Method 1: If the SDK has already been compiled
# Method to use libxml2 (using k230_canmv_defconfig as an example), execute the following commands in the SDK main directory:
# Target packages --> Libraries --> JSON/XML --> libxml2
# Enable the libxml2 library and save the configuration;
make -C output/k230_canmv_defconfig/little/buildroot-ext/ savedefconfig # Save the configuration
make -C output/k230_canmv_defconfig/little/buildroot-ext/ # Compile Buildroot
make build-image
Enabling libxml2 Method 2: If the SDK has not been compiled
# Method to use libxml2 (using k230_canmv_defconfig as an example) execute the following commands in the SDK main directory:
libxml2 usage example:
// Save the following code as io.c, see the compilation method below
#include <libxml/parser.h>
int main(void)
xmlNodePtr n;
xmlDocPtr doc;
xmlChar *xmlbuff;
int buffersize;
* Create the document. */
xmlDocSetRootElement(doc, n);
* for demonstration purposes. */
* Free associated memory.
xmlFree(xmlbuff);
xmlFreeDoc(doc);
return (0);
#else
#include <stdio.h>
int main(void)
fprintf(stderr,
return (0);
// Compilation method
/* Assuming the SDK main directory is SDK=/home/wangjianxin/k230_sdk
all:
${gcc} io.c --sysroot=${BD}/host/riscv64-buildroot-linux-gnu/sysroot -I=${sysroot}/usr/include/libxml2 -lxml2
#endif
Special Note: The SDK does not support multi-process compilation, so do not add multi-process compilation options like -j32.
What Screens Are Supported?#
Answer: For porting new screens, please refer to the K230_LCD Adaptation Guide. Currently, the supported screens are:
Brand |
Model |
Driver Model |
Resolution |
Frame Rate |
Remarks |
JinZhaoHui |
FPC55MH907C |
HX8399 |
1080x1920 |
30 |
DaXianWeiYe |
D350T1013V1 |
ST7701 |
480x800 |
60 |
DongDaXianKong |
TC045IVFS-V40 |
ST7701 |
480x854 |
30 |
LongXun |
LT9611 |
1920x1080 |
30/50/60 |
HDMI |
When porting existing drivers, pay attention to the reset, backlight pins, and I2C used in the driver. These are defined in the k230_sdk/src/big/mpp/include/comm/k_board_config_comm.h file. These definitions may vary between different boards and are distinguished by board macros. For example:
// display gpio
#define DISPLAY_LCD_RST_GPIO 20
#define DISPLAY_LCD_BACKLIGHT_EN 25
// display gpio
#define DISPLAY_LCD_RST_GPIO 22
The reset pins for the Canmv-K230-V1.0 and V2.0 boards are different. Please modify the corresponding pin numbers during porting.
