K230 Memory Analysis Guide#
Small Core Memory Usage Analysis#
Static Memory Usage in Linux Kernel#
size Tool#
The size tool can be used to check the sizes of text, data, and bss sections of the kernel image. The location of vmlinux is k230_sdk/output/k230_evb_defconfig/little/linux. Navigate to this directory and use the size tool to check vmlinux.
$ size -G vmlinux
      text       data        bss      total filename
   9550790    5033374     375793   14959957 vmlinux
ksize.py Script#
In the tools directory of the Linux source code, there is a script named ksize.py, which can parse the built-in.a files in the kernel directory and display the parsed content sorted by size.
Linux Kernel                          total |       text       data        bss
 vmlinux                            14959957 |   10010970    4573194     375793
 drivers/built-in.a                  4060898 |    3757793     257384      45721
fs/built-in.a                       3450902 |    2984349     439120      27433
net/built-in.a                      3103220 |    2635627     392278      75315
kernel/built-in.a                   2258370 |    1402705     668085     187580
mm/built-in.a                        581664 |     480740      94560       6364
lib/built-in.a                       494079 |     488689       3038       2352
block/built-in.a                     242212 |     219496      20060       2656
crypto/built-in.a                    165559 |     151371      14113         75
arch/riscv/built-in.a                117201 |      46516      43788      26897
ipc/built-in.a                        60699 |      57375       3296         28
security/built-in.a                   45740 |      43716       1944         80
init/built-in.a                       31148 |      20394      10617        137
certs/built-in.a                       1241 |       1217         16          8
usr/built-in.a                          520 |        520          0          0
 sum                                14613453 |   12290508    1948299     374646
delta                                346504 |   -2279538    2624895       1147
drivers                               total |       text       data        bss
 drivers/net/built-in.a               620309 |     589318      30918         73
drivers/usb/built-in.a               531811 |     500758      27947       3106
drivers/gpu/built-in.a               436282 |     426932       9262         88
drivers/media/built-in.a             305133 |     282425      12048      10660
drivers/mtd/built-in.a               287895 |     272626      12317       2952
drivers/tty/built-in.a               256154 |     225035      21385       9734
drivers/base/built-in.a              206309 |     191470      13710       1129
drivers/mmc/built-in.a               178193 |     168267       9882         44
drivers/scsi/built-in.a              150154 |     124680      24788        686
drivers/hid/built-in.a               106225 |      97793       8360         72
drivers/clk/built-in.a                90344 |      83123       7141         80
drivers/video/built-in.a              83938 |      76886       3240       3812
drivers/gpio/built-in.a               77888 |      74920       2920         48
drivers/i2c/built-in.a                73855 |      61913       8438       3504
drivers/input/built-in.a              71037 |      68181       2836         20
drivers/of/built-in.a                 64023 |      58745        602       4676
drivers/spi/built-in.a                56824 |      50320       6480         24
drivers/char/built-in.a               45568 |      34511      10265        792
drivers/dma/built-in.a                37291 |      35993       1062        236
drivers/firmware/built-in.a           36744 |      33437       2477        830
drivers/crypto/built-in.a             31999 |      27463       3292       1244
drivers/thermal/built-in.a            30926 |      27157       3752         17
drivers/dma-buf/built-in.a            29547 |      26747       2668        132
drivers/virtio/built-in.a             27405 |      25984       1413          8
drivers/iio/built-in.a                27146 |      26470        664         12
drivers/block/built-in.a              25557 |      24084       1393         80
drivers/power/built-in.a              22133 |      14605       6848        680
drivers/soc/built-in.a                19576 |      10632       8912         32
drivers/leds/built-in.a               14605 |      13945        636         24
drivers/pwm/built-in.a                13628 |      11708       1792        128
drivers/watchdog/built-in.a           13598 |      13067        501         30
drivers/ras/built-in.a                12633 |       8089       4528         16
drivers/nvmem/built-in.a              11866 |      10962        904          0
drivers/misc/built-in.a               10180 |       9916        264          0
drivers/perf/built-in.a                8979 |       7839        488        652
drivers/reset/built-in.a               8579 |       8095        484          0
drivers/phy/built-in.a                 7297 |       7138        151          8
drivers/irqchip/built-in.a             5992 |       5248        728         16
drivers/clocksource/built-in.a         3633 |       3229        400          4
drivers/canaan-hwtimer/built-in.a       3553 |       3273        224         56
drivers/mfd/built-in.a                 2350 |       2122        224          4
drivers/canaan-hardlock/built-in.a       1312 |       1096        208          8
drivers/pci/built-in.a                  164 |        164          0          0
 sum                                 4048635 |    3746366     256552      45717
delta                                 12263 |      11427        832          4
fs                                    total |       text       data        bss
 fs/nfs/built-in.a                    831393 |     586545     243616       1232
fs/*.o                               605562 |     543984      44914      16664
fs/ext4/built-in.a                   535651 |     439889      94598       1164
fs/ubifs/built-in.a                  233606 |     232778        704        124
fs/ntfs/built-in.a                   178875 |     175071       3724         80
fs/nls/built-in.a                    147032 |     146220        552        260
fs/proc/built-in.a                   103930 |     102710       1140         80
fs/jffs2/built-in.a                   89382 |      88050       1032        300
fs/hfsplus/built-in.a                 89010 |      66622      22372         16
fs/fuse/built-in.a                    83342 |      82094       1192         56
fs/jbd2/built-in.a                    79685 |      67144      12421        120
fs/fat/built-in.a                     62368 |      61689        627         52
fs/lockd/built-in.a                   56531 |      52860       1415       2256
fs/ext2/built-in.a                    51552 |      51288        256          8
fs/exfat/built-in.a                   50232 |      49891        293         48
fs/hfs/built-in.a                     44570 |      44342        220          8
fs/9p/built-in.a                      38537 |      37968        541         28
fs/iomap/built-in.a                   29506 |      23726       5556        224
fs/kernfs/built-in.a                  24668 |      20038        494       4136
fs/debugfs/built-in.a                 24646 |      24342        288         16
fs/configfs/built-in.a                23513 |      22733        752         28
fs/autofs/built-in.a                  21641 |      21433        208          0
fs/notify/built-in.a                  20350 |      18913        972        465
fs/sysfs/built-in.a                   11121 |      10825        276         20
fs/devpts/built-in.a                   4019 |       3383        628          8
fs/tracefs/built-in.a                  3327 |       3191        120         16
fs/exportfs/built-in.a                 2512 |       2488         24          0
fs/ramfs/built-in.a                    2379 |       2299         80          0
fs/nfs_common/built-in.a               1962 |       1833        105         24
 sum                                 3450902 |    2984349     439120      27433
delta                                     0 |          0          0          0
net                                   total |       text       data        bss
 net/wireless/built-in.a              537167 |     416358     118041       2768
net/mac80211/built-in.a              530597 |     448777      81720        100
net/core/built-in.a                  496384 |     441682      49334       5368
net/ipv4/built-in.a                  490329 |     455868      21793      12668
net/sunrpc/built-in.a                424309 |     301164      86725      36420
net/ipv6/built-in.a                  330602 |     305628      12017      12957
net/9p/built-in.a                     74446 |      59002      15140        304
net/ethtool/built-in.a                65232 |      64314        831         87
net/netlink/built-in.a                37972 |      36352       1584         36
net/unix/built-in.a                   31131 |      26138        876       4117
net/packet/built-in.a                 29875 |      29087        786          2
net/*.o                               26420 |      24930       1014        476
net/sched/built-in.a                  14230 |      12813       1417          0
net/bpf/built-in.a                     6775 |       6211        564          0
net/dns_resolver/built-in.a            4191 |       3835        344         12
net/ethernet/built-in.a                3560 |       3468         92          0
 sum                                 3103220 |    2635627     392278      75315
delta                                     0 |          0          0          0
kernel                                total |       text       data        bss
The `nm` command can be used to view the sizes of symbols in the kernel module. For example:
```shell
0000000000020000 b __log_buf
The output has three columns indicating size, symbol type, and symbol name. For symbol types:
  • b/B - Symbol is in the bss section
  • t/T - Symbol is in the text section
  • d/D - Symbol is in the data section
  • r/R - Symbol is in the rodata section
Dynamic Memory Usage Analysis in Linux#
free#
In the Linux user space command line, executing the free command provides the current memory usage of the system.
[root@canaan ~]# free
              total        used        free      shared  buff/cache   available
Mem:         106028       28260       39824          84       37944       57024
Swap:             0           0           0
  • total: Total memory available to the Linux kernel
  • used: Memory currently used by the system
  • free: Memory currently free in the system
  • shared: Shared memory
  • buff/cache: Physical memory used by buffers and cache
  • available: Physical memory available for applications
/proc/meminfo Node#
You can use cat /proc/meminfo to further observe the memory usage in Linux.
[root@canaan ~]# cat /proc/meminfo
MemTotal:         106028 kB
MemFree:           39744 kB
MemAvailable:      56976 kB
Buffers:             356 kB
Cached:            10052 kB
SwapCached:            0 kB
Active:             5024 kB
Inactive:           7008 kB
Active(anon):         84 kB
Inactive(anon):     1624 kB
Active(file):       4940 kB
Inactive(file):     5384 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:             0 kB
SwapFree:              0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:          1660 kB
Mapped:             3520 kB
Shmem:                84 kB
KReclaimable:      27600 kB
Slab:              39244 kB
SReclaimable:      27600 kB
SUnreclaim:        11644 kB
KernelStack:         912 kB
PageTables:          240 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:       53012 kB
Committed_AS:      14572 kB
VmallocTotal:   67108863 kB
VmallocUsed:        2440 kB
VmallocChunk:          0 kB
Percpu:              136 kB
  • MemTotal, MemFree, Buffers, Cached, SwapCached: Refer to the explanation of free
  • MemAvailable: Calculated using MemFree, Active(file), Inactive(file), SReclaimable, and the low watermark in /proc/zoneinfo based on a specific algorithm. It’s an estimate, not precise, and is used to evaluate the memory available for application use.
  • Active/Inactive: Active indicates recently used memory with low priority for reclamation; Inactive indicates less recently used memory with high priority for reclamation.
  • AnonPages: Anonymous pages
  • Mapped: Size of mapped devices or files, such as shared memory, dynamic libraries, and files mapped with mmap.
  • slab/SReclaimable/SUnreclaim: Memory used by the kernel slab, including reclaimable and non-reclaimable parts.
  • KernelStack: Size of the kernel stack
  • PageTables: Size of the page tables (used to translate virtual addresses to physical addresses). This memory increases as more memory is allocated.
  • CommitLimit/Committed_AS: Overcommit threshold/already requested memory size (not allocated). Overcommit is a Linux memory allocation strategy to run more and larger programs by responding “yes” to most memory allocation requests, resulting in total requested memory exceeding total physical memory.
  • VmallocTotal/VmallocUsed/VmallocChunk: Size of the vmalloc area/size used in the vmalloc area/largest available contiguous block in the vmalloc area.
Large Core Memory Usage Analysis#
The memory of the large core mainly includes the following:
  • Static memory usage of the rt-smart kernel image
  • rt-smart heap memory, mainly used by the rt-smart kernel
  • rt-smart page memory, mainly used by user-space malloc
  • MMZ memory used by multimedia, dedicated to multimedia devices
Static Analysis#
Using the size Tool#
The size tool can be used to check the sizes of text, data, and bss sections of the rt-smart image. The rtthread.elf is located at k230_sdk/output/k230_evb_defconfig/big/rt-smart$.
$ size -G rtthread.elf
   3052420      26852     612126    3691398 rtthread.elf
Dynamic Analysis#
Heap Memory#
Use the free command to check the heap memory usage of rt-smart, in bytes.
msh /> free
memheap               pool size  max used size available size
heap                 33554432   1111520       33141096
  • pool size: Total size of the heap’s physical memory
  • max used size: Maximum historical usage of physical memory
  • available size: Currently available physical memory
Page Memory#
Use list_page to check page memory.
msh /> list_page
level 10 [0x03400000]
level 12 [0x06000000]
level 13 [0x04000000]
level 14
level 15
level 16
level 17
level 18
level 19
level 20
level 21
level 22
level 23
level 24
level 25
level 26
level 27
level 28
level 29
level 30
level 31
level 32
level 33
level 34
level 35
level 36
level 37
level 38
level 39
level 40
level 41
level 42
level 43
level 44
level 45
level 46
level 47
level 48
level 49
level 50
level 51
free pages is 00004e95
used pages is 0000000d
max used pages is 00000992
  • free pages: Number of currently available pages
  • used pages: Number of currently used pages
  • max used pages: Maximum historical usage of pages
Multimedia Dedicated Memory#
You can check using the /proc/ filesystem.
msh /> cat /proc/media-mem
+---ZONE: PHYS(0x10000000, 0x1FAFFFFF), GFP=0, nBYTES=257024KB,    NAME="anonymous"
---MMZ_USE_INFO:
This concludes the translation.
