K230 RVV in action#
overview#
RVV (RISC-V Vector Extension) refers to the vector extension of the RISC-V instruction set architecture. RISC-V is an open source instruction set architecture with a simple design, high scalability, and a wide range of applications. RVV is an optional extension of RISC-V designed to support vector processing and parallel computing. RVV defines a new set of instructions for performing vector operations. These instructions allow multiple data elements to be processed simultaneously, increasing computational efficiency and throughput. Vector operations can be performed in a single instruction without the need to process each data element through loops or operations on a case-by-case basis. RVV supports different vector lengths, and different vector lengths can be selected according to the needs of the application. The vector length can be fixed or configurable. RVV also supports different data types, including integers, floats, and fixed-point numbers.
The introduction of RVVs provides processors with vector processing and parallel computing capabilities that can accelerate various applications such as image processing, signal processing, machine learning, scientific computing, and more. At the same time, the openness and scalability of RVVs also allow manufacturers and developers to customize and optimize according to their own needs. The K230 uses the Xuantie C908 dual-core processor, of which the large-core C908 comes with RVV1.0 expansion, and this article describes how to use the RVV function on the large-core rt-smart. and experience the practical effects of RVV acceleration.
Environment preparation#
Hardware environment#
Software environment#
k230_SDK
Use the RVV function#
Source code writing#
In order to experience the advantages of RVV acceleration in vector computing, we write a demo using image scaling as an application scenario. Create a folder in the SDK path below
Note that if you run make or make rt-smart under the k230_sdk, the changes may be overwritten, and readers can copy the finished source code to the following directory
source#
Create the C source code file scale.c in the scale directory
#include <stdio.h>
#include <stdlib.h>
#include <stddef.h>
#include <stdint.h>
#include <time.h>
#pragma pack(push, 1)
    unsigned short signature;
    unsigned int fileSize;
    unsigned short reserved1;
    unsigned short reserved2;
    unsigned int dataOffset;
} BitmapFileHeader;
    unsigned int headerSize;
    int width;
    int height;
    unsigned short planes;
    unsigned short bitsPerPixel;
    unsigned int compression;
    unsigned int imageSize;
    int xPixelsPerMeter;
    int yPixelsPerMeter;
    unsigned int colorsUsed;
    unsigned int colorsImportant;
} BitmapInfoHeader;
#pragma pack(pop)
    // Read input BMP file
    if (inputFile == NULL) {
        return;
    BitmapFileHeader fileHeader;
    BitmapInfoHeader infoHeader;
    fclose(inputFile);
    // Calculate the size of the scaled image
    // Creating Output BMP Files
    if (outputFile == NULL) {
        free(originalImageData);
        return;
    // Update BMP file header information
    clock_t start, finish;
    start = clock();
    // Scaling image data
    finish = clock();
    printf("scale cacl use time:%f ms\n",(double)(finish - start) / CLOCKS_PER_SEC);
    // Write scaled image data
    fclose(outputFile);
    free(scaledImageData);
int main()
    float scaleFactor = 0.5; //scaling factor
SCONS configuration file#
  • Create a SConscript file
from building import *
cwd = GetCurrentDir()
src = Glob('*.c')
CPPPATH = [cwd]
CPPDEFINES = [
    'HAVE_CCONFIG_H',
Return('group')
  • Create a SConstruct file
import sys
# add building.py path
compile#
Go to the directory src/big/rt-smart Run Script to source smart-env.sh riscv64 configure environment variables.
$ source smart-env.sh riscv64
Arch         => riscv64
CC           => gcc
EXEC_PATH    => /home/testUser/k230_sdk/src/big/rt-smart/../../../toolchain/riscv64-linux-musleabi_for_x86_64-pc-linux-gnu/bin
Go to the userapps/testcases/scaledirectory to run scons --releasethe compilation
$ cd userapps/testcases/scale
$ scons --release
scons: Building targets ...
CC build/scale/scal.o
LINK scale.elf
scons: done building targets.
Rename the compiled program
Edit the k230_sdk/src/big/rt-smart/tools/riscv64 .py file to remove the v extension for the compilation option.
index 16fc9b2..c045bf5 100644
--- a/tools/riscv64.py
+++ b/tools/riscv64.py
                 EXT_CFLAGS = ''
                 EXT_LFLAGS = ''
-            DEVICE = ' -mcmodel=medany -march=rv64imafdcv -mabi=lp64d'
+            DEVICE = ' -mcmodel=medany -march=rv64imafdc -mabi=lp64d'
             self.CFLAGS    = configuration.get('CFLAGS', DEVICE + ' -Werror -Wall' + EXT_CFLAGS)
             self.AFLAGS    = configuration.get('AFLAGS', ' -c' + DEVICE + ' -x assembler-with-cpp -D__ASSEMBLY__ -I.' + EXT_CFLAGS)
             LINK_SCRIPT    = configuration.get('LINK_SCRIPT', os.path.join(USR_ROOT, 'linker_scripts', 'riscv64', 'link.lds'))
Recompile the source code, and then copy all the compiled scale.elf and scale_with_rvv.elf to sharefs for running.
run#
Prepare a 24-bit bmp image, named input.bmp (which can be saved and generated with PC Paint software), put it in the same directory as the program, and then run the two programs through sharefs.
msh /sharefs>scale.elf
scale cacl use time:0.013952 ms
scale cacl use time:0.013960 ms
scale cacl use time:0.013941 ms
scale cacl use time:0.013936 ms
scale cacl use time:0.013945 ms
scale cacl use time:0.013957 ms
scale cacl use time:0.010139 ms
scale cacl use time:0.010133 ms
scale cacl use time:0.010135 ms
scale cacl use time:0.010144 ms
scale cacl use time:0.010142 ms
From the printing information, after using the V extension instruction, the calculation of the array is significantly faster, and if you increase the resolution of the image to 4K, you can see a more obvious contrast.
Decompile#
You can use the objdump tool to decompile in the source code directory to confirm whether the vector instruction is generated
$ riscv64-unknown-linux-musl-objdump scale_with_rvv.elf -S |grep 'vadd'
   200002c7e:03bf4dd7          vadd.vx v27,v27,t5
   200002c94:03834c57          vadd.vx v24,v24,t1
$ riscv64-unknown-linux-musl-objdump scale_with_rvv.elf -S |grep 'vmul'
   200002c98:97856c57           vmul.vx v24,v24,a0
