K230 FAQ#
Version Information#
Affiliated products
Version number
Release date
K230 SDK
V1.0.0
2023-9-4
FAQs#
Problem: TF card boot fails with exit code 13 error
Answer: The reasons are as follows: 1. The file error in the boot media. 2. The startup pin is set incorrectly.
TF card boot pin setting special instructions: The two start pin levels are high (need to dial to silkscreen 1 and 2, that is, the opposite direction of ON) to boot from the TF card.
BootROM boot error code#
Question: What does the bootrom boot error code mean?
When bootROM fails to boot, it will print an error similar to the following boot failed with exit code 19, the last number is the cause of the error, and the common error meaning is as follows
value
meaning
13
The boot media contains a file error
19
Boot media initialization failed, such as not inserting an SD card
17
The OTP requirement must be a secure image, but the files on the media are non-secure images
SPI NOR and SPI NAND Flash identify#
Question: How do I know if SPI NOR or SPI NAND Flash is connected to the EVB board?
Answer: Method 1: The daughter plate silk screen printing is different, the silk screen will have NOR or NAND logo.
Method 2: The Linux boot log will be printed, for example, when connecting to SPI Nor, it will be printed like the following
Perf Use#
Question: How is perf compiled and what hardware events are supported?
A: The reference image with PERF function is linked below https://kvftsfijpo.feishu.cn/file/LJjpbwxnzowI9RxvL0NcEK73nkf?from=from_copylink
When perf, you can use the RAW event, such as perf stat -e r12, and the perf tool compile command as follows
cd src/little/linux/tools
#The target file is perf/perf, please copy this file to the board.
Special note: Versions prior to 1.1 have the following modifications
#src/little/linux/arch/riscv/boot/dts/kendryte/k230_evb.dtsi add the following info:
pmu_thead: pmu_thead {
    interrupts = <17>;
#src/little/linux/arch/riscv/configs/k230_evb_defconfig  add the following configuration to the file
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_PERF_EVENTS=y
CONFIG_KUSER_HELPERS=y
CONFIG_DEBUG_INFO=y
CONFIG_FRAME_POINTER=y
[root@canaan ~ ]#
Big core run vector Linux#
Question: How does Big Core run Linux with Vector?
Answer: make CONF=k230_evb_only_linux_defconfig ; The compiled image, the big core runs Linux with vector by default.
Big core serial port ID#
Question: How to modify the serial port ID of the big core?
Answer: The configuration file below configs CONFIG_RTT_CONSOLE_ID stands for the big core serial port ID, modify it to the correct value.
uboot command line#
How to compile the version that can enter the uboot command line
Answer: The configuration file below configs CONFIG_QUICK_BOOT stands for fast, modify it to CONFIG_QUICK_BOOT=n to generate a command-line version that can be entered into uboot.
How to start slowly#
Answer: Enter the uboot command line and execute the following command:
Linux How to modify the last partition size#
Answer: You can use the parted tool to dynamically modify the size of the last partition, refer to the following command:
umount /sharefs/
parted   -l /dev/mmcblk1
mkfs.ext2 /dev/mmcblk1p4
mount /dev/mmcblk1p4 /sharefs
#please refer to below log:
Model: SD SD32G (sd/mmc)
Disk /dev/mmcblk1: 31.3GB
Partition Table: gpt
Disk Flags:
Disk Flags:
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
First data block=0
232 block groups
8176 inodes per group
Disk Flags:
[root@canaan ~ ]#df -h
[root@canaan ~ ]#
How to modify bootargs#
Answer: Method 1: Modify bootargs using env file. For example, you can add the following content to the board/common/env/default.env file:
Method 2: Enter the uboot command line and modify bootargs with reference to the following command.
How to view bootargs#
Answer: Method 1: Under linux, enter cat /proc/cmdline to view
[root@canaan ~ ]#
Method 2: Linux command line input dmesg | grep command view
[root@canaan
The default serial port modification of little core#
Answer: At present, the little core serial port in the SDK defaults to 0, if you need to modify it to other serial ports (such as serial port 2), please refer to the following to modify:
Modification 1: Refer to the following to modify the uboot device tree (e.g. arch/riscv/dts/k230_evb.dts):
aliases {
        uart2 = &serial2;
    chosen {
    serial2: serial@91402000 {
    clock-frequency = <50000000>;
    clock-names = "baudclk";
    reg-shift = <2>;
    reg-io-width = <4>;
    u-boot,dm-pre-reloc;
Modification 2: Refer to the following to modify the Linux device tree (e.g. arch/riscv/boot/dts/kendryte/k230_evb.dts)
aliases {
        serial2 = &uart2;
chosen {
        stdout-path = "serial2";
&uart2 {
    status = "okay";
Modification 3: Modify bootargs using env files (see 2.10).
How to completely reprogram the SDK#
Answer: After updating and modifying the SDK source code, or after modifying the SDK source code, it is recommended to enter the following command to completely reprogram the SDK.
make clean; make;
How to quickly compile one of the buildroot packages#
Answer:Reference the following command to quickly rebuild one of the buildroot packages
    #rebuild lvgl packege,
    cd output/k230_canmv_defconfig/little/buildroot-ext/; #Take k230 canmv defconfig as an example
    make  lvgl-dirclean;
    make  lvgl && make;
    cd -  #Switch to the sdk home directory;
    make build-image #Regenerate  image
For more information please refer to buildroot rebuild pkg.
Special note: The SDK does not support multi-process compilation, do not add multi-process compilation options like -j32.
