HTTPS Client Example Walkthrough#
Example Location#
Low-level Socket and TLS version:
Board firmware path:
/sdcard/examples/14-Socket/https_client.pySDK source path:
src/canmv/resources/examples/14-Socket/https_client.py
requests high-level interface version:
/sdcard/examples/14-Socket/https_client2.pySDK source path:
src/canmv/resources/examples/14-Socket/https_client2.py
Both examples access https://www.baidu.com and are used to compare the differences
between manually establishing a TLS connection and using a high-level HTTP client
library.
Preparation Before Running#
Both scripts use the same common network configuration. Modify the Wi-Fi credentials,
or change NETWORK_TYPE to "lan" or "default":
NETWORK_TYPE = "wifi_sta"
WLAN_DEVICE = "auto"
WIFI_SSID = "TEST"
WIFI_PASSWORD = "12345678"
NETWORK_TIMEOUT = 20
The board must be able to access the Internet and resolve DNS. In real applications, if certificate validity period verification is enabled in the TLS configuration, you should also make sure the device time is correct first.
Low-level TLS Version#
Resolve and Connect to the HTTPS Port#
addr = usocket.getaddrinfo("www.baidu.com", 443)[0][-1]
sock = usocket.socket()
sock.connect(addr)
HTTPS uses TCP port 443 by default. At this point, only the TCP connection has
been established; the encrypted channel has not yet been set up.
Wrap the TLS Socket#
ssl_sock = ussl.wrap_socket(sock, server_hostname="www.baidu.com")
server_hostname provides SNI during the TLS handshake. When multiple websites share
the same IP, the server relies on SNI to select the corresponding certificate and
site.
Send the HTTP Request and Read in a Loop#
ssl_sock.write(
b"GET / HTTP/1.1\r\nHost: www.baidu.com\r\nConnection: close\r\n\r\n"
data = ssl_sock.read()
if not data:
print(data.decode(), end="")
The request uses Connection: close, and the read loop ends when the server closes
the connection. Finally, ssl_sock.close() is called to release the TLS and TCP
resources.
requests high-level version#
response = requests.get("https://www.baidu.com")
print(response.text)
response.close()
requests.get() internally handles DNS, TCP, TLS and HTTP processing, suitable for ordinary business requests. After reading
the response, you should still explicitly call response.close() to promptly release the Socket and memory.
Running and Troubleshooting#
When learning for the first time, run
https_client2.pyfirst to confirm that the network and HTTPS basic environment are normal.Then run
https_client.pyto observe the raw HTTP status line, response headers, and body.For DNS errors, check the network, gateway, and DNS; for connection timeouts, check the default uplink and firewall.
When the TLS handshake fails, check the system time, target domain name, SNI, and the TLS algorithms supported by the firmware.
