CanMV-K230 Quick Start Guide#
CanMV-K230 Introduction#
The CanMV-K230 development board is based on the latest generation AIoT SoC K230 series chip from Canaan Technology’s Kendryte ® series AIoT chips. This chip adopts a brand new multi-heterogeneous unit accelerated computing architecture, integrating 2 RISC-V high-efficiency computing cores, with a built-in next-generation KPU (Knowledge Process Unit) intelligent computing unit, providing multi-precision AI computing power, and widely supporting common AI computing frameworks, with the utilization rate of some typical networks exceeding 70%.
This chip also supports rich peripheral interfaces and integrates multiple dedicated hardware acceleration units such as 2D and 2.5D, capable of accelerating various types of tasks including image, video, audio, and AI, with features such as low latency, high performance, low power consumption, and fast startup.
K230_block_diagram
Quick Start#
Get the Development Board#
Development Board
Introduction
CanMV-K230
CanMV-K230
Based on K230, with external 512MB LPDDR, larger memory
BPI-K230D-ZERO
Bpi-K230D-Zero
Based on K230D, with built-in 128MB LPDDR4, compact board size
Flash Firmware#
Users can download firmware from Github or Canaan Developer Community. After downloading the firmware for the corresponding development board, please refer to Firmware Download Guide to flash the firmware to the development board.
Install CanMV Extension#
CanMV-K230 recommends using the CanMV Visual Studio Code extension for development. Users can connect to the development board, run code, view running results, preview images, and manage device files in Visual Studio Code. For detailed usage, please refer to CanMV Extension Instructions
Run Demo#
The CanMV-K230 firmware comes with a large number of pre-installed Demo programs, allowing users to experience them without downloading from the network. You can run examples in the Examples view of the CanMV extension, or open the Python example files in the virtual USB drive in Visual Studio Code and run them.
Please refer to How to Run Demo Programs
Camera Image Preview#
Capture images using the camera and display them via HDMI output:
import time, os, sys
from media.sensor import *
from media.display import *
sensor = None
    print("camera_test")
    sensor = Sensor()
    # sensor reset
    sensor.reset()
    # set hmirror
    # sensor.set_hmirror(False)
    # sensor vflip
    # sensor.set_vflip(False)
    # set chn0 output size, 1920x1080
    # set chn0 output format
    # bind sensor chn0 to display layer video 1
    # use hdmi as display output
    # init media manager
    # sensor start run
    sensor.run()
    print("user stop: ", e)
    print(f"Exception {e}")
finally:
    # sensor stop run
        sensor.stop()
    # deinit display
    time.sleep_ms(100)
    # release media buffer
AI Demo#
This is a face detection demo
from libs.AI2D import Ai2d
import ujson
from time import *
import nncase_runtime as nn
import ulab.numpy as np
import utime
import image
import random
import gc
import sys
import aidemo
# 自定义人脸检测类,继承自 AIBase 基类
        self.rgb888p_size = [ALIGN_UP(rgb888p_size[0], 16), rgb888p_size[1]]  # sensor 给到 AI 的图像分辨率,并对宽度进行 16 的对齐
        self.display_size = [ALIGN_UP(display_size[0], 16), display_size[1]]  # 显示分辨率,并对宽度进行 16 的对齐
        self.ai2d = Ai2d(debug_mode)  # 实例化 Ai2d,用于实现模型预处理
        self.ai2d.set_ai2d_dtype(nn.ai2d_format.NCHW_FMT, nn.ai2d_format.NCHW_FMT, np.uint8, np.uint8)  # 设置 Ai2d 的输入输出格式和类型
    # 配置预处理操作,这里使用了 pad 和 resize, Ai2d 支持 crop/shift/pad/resize/affine,具体代码请打开 /sdcard/app/libs/AI2D.py 查看
        with ScopedTiming("set preprocess config", self.debug_mode > 0):  # 计时器,如果 debug_mode 大于 0 则开启
            ai2d_input_size = input_image_size if input_image_size else self.rgb888p_size  # 初始化 ai2d 预处理配置,默认为 sensor 给到 AI 的尺寸,可以通过设置 input_image_size 自行修改输入尺寸
            top, bottom, left, right = self.get_padding_param()  # 获取 padding 参数
    # 自定义当前任务的后处理, results 是模型输出 array 列表,这里使用了 aidemo 库的 face_det_post_process 接口
            if len(post_ret) == 0:
                return post_ret
                return post_ret[0]
    # 绘制检测结果到画面上
            if dets:
                pl.osd_img.clear()  # 清除 OSD 图像
                for det in dets:
                    # 将检测框的坐标转换为显示分辨率下的坐标
                pl.osd_img.clear()
    # 获取 padding 参数
    def get_padding_param(self):
        top = int(round(0))
        left = int(round(0))
    # 显示模式,默认 "hdmi", 可以选择 "hdmi" 和 "lcd"
    display_mode="hdmi"
    if display_mode=="hdmi":
        display_size=[1920,1080]
        display_size=[800,480]
    # 设置模型路径和其他参数
    # 其它参数
    confidence_threshold = 0.5
    nms_threshold = 0.2
    anchor_len = 4200
    det_dim = 4
    rgb888p_size = [1920, 1080]
    # 初始化 PipeLine,用于图像处理流程
    pl.create()  # 创建 PipeLine 实例
    # 初始化自定义人脸检测实例
            with ScopedTiming("total",1):
    finally:
        pl.destroy()                            # 销毁 PipeLine 实例
