UDP Multicast Example Explanation#
Example Location#
Development board send/receive example:
  • Development board firmware path: /sdcard/examples/14-Socket/udp_multicast.py
  • SDK source path: src/canmv/resources/examples/14-Socket/udp_multicast.py
The companion scripts for the PC are also provided with the firmware, but they should run in the PC’s Python environment:
  • Sender firmware path: /sdcard/examples/14-Socket/udp_multicast_sender_pc.py
  • Sender source path: src/canmv/resources/examples/14-Socket/udp_multicast_sender_pc.py
  • Receiver firmware path: /sdcard/examples/14-Socket/udp_multicast_receiver_pc.py
  • Receiver source path: src/canmv/resources/examples/14-Socket/udp_multicast_receiver_pc.py
Multicast allows a single sender to deliver the same datagram to multiple receivers in the same multicast group. The development board script switches between sender and receiver modes via IS_SENDER, and the PC-side scripts serve as the other end for verification.
Parameter Configuration#
MULTICAST_GROUP = "239.255.0.1"
MULTICAST_PORT = 5007
IS_SENDER = False
NETWORK_TYPE = "wifi_sta"
WLAN_DEVICE = "auto"
WIFI_SSID = "TEST"
WIFI_PASSWORD = "12345678"
NETWORK_TIMEOUT = 20
The development board and the PC must be on the same LAN that supports multicast forwarding. If a switch, wireless router, or hotspot has client isolation, multicast filtering, or IGMP restrictions enabled, the data may not reach its destination.
Common Flow#
netif, ip = connect_network(...)
if IS_SENDER:
    multicast_sender(ip)
    multicast_receiver()
The script first obtains a valid IP, then selects the role based on IS_SENDER. The default value False means the development board acts as the receiver.
Development Board Sender Mode#
sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
ttl = struct.pack("b", 1)
sock.setsockopt(0, 33, ttl)
sock.sendto(message.encode(), (MULTICAST_GROUP, MULTICAST_PORT))
Here, the options 0 and 33 correspond to IPPROTO_IP and IP_MULTICAST_TTL respectively. TTL is set to 1, so that the data only propagates on the local network. The script sends once every 2 seconds, and includes the development board’s IP and an incrementing counter in the message.
Test steps:
  1. Run udp_multicast_receiver_pc.py on the PC.
  2. Change IS_SENDER in the development board script to True and run it.
  3. The PC side should continuously display multicast messages from the development board.
Development Board Receiver Mode#
sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
sock.bind(("0.0.0.0", MULTICAST_PORT))
mreq = struct.pack(
    "4s4s",
    inet_aton(MULTICAST_GROUP),
    inet_aton("0.0.0.0"),
sock.setsockopt(0, 35, mreq)
The receiver first listens on port 5007 across all interfaces, then joins 239.255.0.1 via a membership request. Option 35 corresponds to IP_ADD_MEMBERSHIP. After receiving data, the script prints the sender’s address and the decoded payload; data that cannot be decoded as UTF-8 will be flagged as binary content.
Test steps:
  1. Keep IS_SENDER = False in the development board script and run it.
  2. Run udp_multicast_sender_pc.py on the PC.
  3. The development board’s serial port should display Hello from PC multicast sender! once per second.
Troubleshooting Points#
  • Confirm that the multicast address and port on both ends match exactly.
  • Confirm that the system firewall allows UDP 5007.
  • On PCs with multiple network cards, confirm that the multicast traffic is sent out from the interface that can communicate with the development board.
  • When regular UDP unicast works but multicast has no data, focus on checking the access point’s client isolation, IGMP Snooping, and multicast filtering settings.
