K230 Product Brief#
Purpose#
This document is intended to provide a general overview of the K230 platform and its features.
Intended Audience#
The main people to whom this document (this guide) applies:
  • Design and maintenance personnel for electronic products
  • Sales personnel for electronic products
  • Technical support personnel
Terms#
Revision history#
Version Number
Author
Revision Date
Revision Notes
Zhenming Huang
2023-6-10
Re-format to markdown document based on K230 Brief Datasheet_Complete_Apr_2023_v1
General Specifications#
CPU#
  • CPU 1: 64bit, RISC-V processor, 1.6GHz, supports RISC-V Vector Extension 1.0 specification, with floating-point units (FPUs), 128bits vector-process-unit, runs RTOS system
  • CPU 0: 64bit, RISC-V processor, 800MHz, supports RISC-V 64GCB instruction set, runs LINUX system
KPU#
  • Support INT8 and INT16
    • Resnet 50 ≥ 85fps @INT8
    • Mobilenet_v2 ≥ 670fps @INT8
    • YoloV5S ≥ 38fps @INT8
  • Support TVM / TensorFlow / Pytorch / ONNX
  • Support quantitative tool chain and profiling tools
D Engine#
  • 2D(GDMA) Engine:
    • OSD/CSC/X-Mirror/Y-Mirror/Rotation(90/180/270)
  • Independent AI 2D Engine:
DPU (Depth Computing Unit)#
  • Support multiple operators, including Img_check / LCN / SAD / Post_proc / Align / Disptodepth
Memory#
  • DRAM: DDR3L / LPDDR4 with 16/32bit, LPDDR3 with 32bit
  • DRAM frequency:
    • DDR3L@1600Mbps / LPDDR3@2133Mbps
    • LPDDR4@2667Mbps
  • Maximum capacity: 2GB
  • SIP mode: 128MB 16bit LPDDR4@3200Mbps
  • SRAM:2MB+2MB (default for KPU)
Video Input#
  • 3 x MIPI CSI
  • (1 x 4lane+1 x 2lane) or 3 x 2lane
ISP#
  • Total throughput:8MP@30fps
  • Image 3A / 2DNR / 3DNR / WDR / HDR
  • Local Tone Mapping
  • Sharpen / BLS / LSC / De-warping
  • RGB-IR 4x4 pattern
Video Output#
  • Resolution: 2MP@60fps
Video Codec#
  • Video encoding
    • H.264 Baseline / Main Profile / High Profile
    • H.265 Main Profile
    • JPEG / MJPEG
    • Maximum encoding performance:
      • 8MP@20fps
  • Video decoding
    • H.264 Baseline, Main Profile, High Profile
    • JPEG / MJPEG
    • Maximum decoding performance:
      • 8MP@40fps
D GPU#
  • Highly optimized Tessellation Engine, cooperates with the VGlite driver to provide vector graphics drawing functions
  • Support rotation, scaling, translation, and format conversion of the input image
  • The drawn picture can perform operations such as blending, compression, etc., with the picture in video memory
Audio#
  • 2 x DAC: 8-192Khz
  • 2 x ADC: 8-192Khz
  • Support ALC
  • Maximum 8 x PDM DMIC inputs
Peripherals#
  • Low-speed interface
    • 5 x UART / 5 x I2C / 6 x PWM
      • 64 x GPIO + 8 x PMU GPIO
  • High-speed interface
    • 2 x USB 2.0 OTG
    • 2 x SDxC: SD3.01, eMMC 5.0
    • 3 x SPI: 1 x OSPI + 2 x QSPI
  • WDT / RTC / Timer
Security#
  • PUF / OTP / TRNG
  • Support AES, SHA, RSA, SM2/3/4, ECC
PMU#
  • Ultra-low power consumption: in deep sleep mode, standby power consumption ≤ 20uW
  • Support RTC function in 32KHz
  • Support long and short press detection as system shutdown or wakeup signal
  • Support IO edge and level detection to generate interrupts
  • Support two output IOs to control PMIC and system reset
  • Support 512 bits system log when shutdown
Other Features#
  • Decompression module:
    • decompression bandwidth ≥ 400MB/s, GZIP format
  • 4096-point FFT / IFFT unit
  • Package:BGA, 0.65mm pitch
    • 13 x 13mm
    • 11 x 11mm (SIP 128MB 16bit LPDDR4)
Block Diagram#
Typical Applications#
  • 3D Face Lock Integrated Application Solution
  • Smart Dictionary Pen Application Solution
