2.8 FPIOA Module API Manual#
1. Overview#
The FPIOA (Pin Multiplexer) module is primarily responsible for configuring the functions of physical pins (PAD). In an SoC, although multiple functions are available, due to the limited number of pins, multiple functions may share the same I/O pin. At this point, each pin can only activate one function at a time, so it is necessary to use IOMUX (i.e., FPIOA) to select the appropriate function.
2. API Introduction#
The FPIOA class is located in the machine module.
Example
from machine import FPIOA
# Instantiate an FPIOA object
fpioa = FPIOA()
# Print the configuration of all pins
fpioa.help()
# Print detailed configuration of a specified pin
fpioa.help(0)
# Print all available configuration pins for a specified function
fpioa.help(FPIOA.IIC0_SDA, func=True)
# Set Pin0 to GPIO0
fpioa.set_function(0, FPIOA.GPIO0)
# Set Pin2 to GPIO2, while configuring other parameters
fpioa.set_function(2, FPIOA.GPIO2, ie=1, oe=1, pu=0, pd=0, st=1, sl=0, ds=7)
# Get the pin currently used by the specified function
fpioa.get_pin_num(FPIOA.UART0_TXD)
# Get the current function of the specified pin
fpioa.get_pin_func(0)
Constructor#
fpioa = FPIOA()
set_function Method#
FPIOA.set_function(pin, func, ie=-1, oe=-1, pu=-1, pd=-1, st=-1, sl=-1, ds=-1)
Set the function of a pin.
pin: Pin number, range: [0, 63]func: Function numberie: Input enable, optional parameteroe: Output enable, optional parameterpu: Pull-up enable, optional parameterpd: Pull-down enable, optional parameterst: St enable, optional parameterds: Drive strength, optional parameter
More detail, See IO configuration instructions
get_pin_num Method#
fpioa.get_pin_num(func)
Get the pin currently used by the specified function.
Returns the pin number, or None if the corresponding function is not found.
get_pin_func Method#
fpioa.get_pin_func(pin)
Get the current function of the specified pin.
pin: Pin number
Returns the current function number of the pin.
help Method#
fpioa.help([number, func=False])
Print pin configuration help information.
number: Pin number or function number, optional parameterfunc: Whether to enable function number query, default isFalse
May be one of the following three:
Configuration information of all pins (if
numberis not set)Detailed configuration information of the specified pin (if
numberis set,funcis not set or set toFalse)All configurable pin numbers for the specified function (if
numberis set andfuncis set toTrue)
