Media Module API Manual#
Attention
This module has undergone significant changes since firmware version V0.7. If you are using firmware before V0.7, please refer to the old version documentation.
The media module of the CanMV K230 platform is a software abstraction layer mainly used to encapsulate the media data link and media buffer operations of the CanMV K230 platform.
API Introduction#
The media module of the CanMV K230 platform provides a static class MediaManager, which contains the methods described in the following sections.
init#
Description After the user completes the configuration of the buffer, call the init method to initialize. This method must be executed last.
Syntax
Parameter Name
Input / Output
Return Values
deinit#
Description This method is used to destroy all requested buffers.
Syntax
Parameter Name
Input / Output
Return Values
_config#
Description Used to configure the media buffer.
Syntax
MediaManager._config(config)
Parameter Name
Input / Output
config
Media buffer config parameters
Input
Return Values
Success
Non-zero
Failure, the value is [error code]
Notes
This method is only for internal use when encapsulating this module interface by various media submodules (e.g., camera, video encoding, etc.) of the CanMV K230 platform. Upper-layer application developers do not need to pay attention to it.
Buffer Management#
get#
Description After _config is completed, the user can obtain the buffer through the MediaManager.Buffer.get method. This method must be called after init is executed.
Syntax
MediaManager.Buffer.get(size)
Parameter Name
Input / Output
size
Requested buffer size, not exceeding the size configured in _config
Input
Return Values
MediaManager.Buffer class
Success
Release Memory#
The user can manually release the obtained buffer.
Syntax
buffer.__del__()
Parameter Name
Input / Output
Return Values
Data Structure Description#
The media module of the CanMV K230 platform includes the following data definitions.
Media Module ID#
The currently defined media module IDs of the CanMV K230 platform. Users need to set the corresponding module ID when creating media links.
Definition
# CanMV K230 Media Module Definitions
AUDIO_IN_MOD_ID = K_ID_AI          # Audio input device module
AUDIO_OUT_MOD_ID = K_ID_AO         # Audio output device module
AUDIO_ENCODE_MOD_ID = K_ID_AENC    # Audio encoding device module
AUDIO_DECODE_MOD_ID = K_ID_ADEC    # Audio decoding device module
CAMERA_MOD_ID = K_ID_VI            # Camera device module
DISPLAY_MOD_ID = K_ID_VO           # Display device module
DMA_MOD_ID = K_ID_DMA              # DMA device module
DPU_MOD_ID = K_ID_DPU              # DPU device module
VIDEO_ENCODE_MOD_ID = K_ID_VENC    # Video encoding device module
VIDEO_DECODE_MOD_ID = K_ID_VDEC    # Video decoding device module
Media Device ID#
The currently defined media device IDs of the CanMV K230 platform. Users need to set the corresponding device ID when creating media links.
Definition
# Audio Device ID Definitions
# TODO
# Camera Device ID Definitions
CAM_DEV_ID_0 = VICAP_DEV_ID_0
CAM_DEV_ID_1 = VICAP_DEV_ID_1
CAM_DEV_ID_2 = VICAP_DEV_ID_2
# Display Device ID Definitions
# DMA Device ID Definitions
# TODO
# DPU Device ID Definitions
# TODO
# Video Encoding Device ID Definitions
# TODO
# Video Decoding Device ID Definitions
# TODO
Media Device Channel ID#
The currently defined media device channel IDs of the CanMV K230 platform. Users need to set the corresponding device channel ID when creating media links.
Definition
# Audio Channel ID Definitions
# TODO
# Camera Channel ID Definitions
CAM_CHN_ID_0 = VICAP_CHN_ID_0
CAM_CHN_ID_1 = VICAP_CHN_ID_1
CAM_CHN_ID_2 = VICAP_CHN_ID_2
# Display Channel ID Definitions
# DMA Channel ID Definitions
# TODO
# DPU Channel ID Definitions
# TODO
# Video Encoding Channel ID Definitions
# TODO
# Video Decoding Channel ID Definitions
# TODO
Related Data Types and Interfaces#
Example Program#
Example
config = k_vb_config()
config.max_pool_cnt = 1
if not ret:
    raise RuntimeError("Buffer configuration failed.")
print(buffer)
buffer.__del__()
