Player Module API Manual#
This document provides a detailed introduction to the K230_CanMV Player module API, which is designed to support the playback of MP4 format files. This module can simultaneously play audio and video, with audio formats supporting G.711A/U and video formats supporting H.264/H.265 encoding.
API Introduction#
The module provides the Player class, which includes the following methods:
Constructor#
Constructs a Player object based on the specified display_type. Users need to create a Player object first to perform subsequent operations.
Syntax
player = Player(Display.VIRT, [display_to_ide])
Parameter Name
Input/Output
Notes
display_type
Type of display device
Input
display_to_ide
Whether to output to IDE virtual screen simultaneously
Input
Player object
Created Player instance
Example
player = Player(Display.VIRT)
player = Player(Display.ST7701)
player = Player(Display.LT9611)
Player.load#
Loads the specified file. The current version only supports MP4 format files.
Syntax
player = Player()
player.load("test.mp4")
Parameter Name
Input/Output
filename
File name
Input
Success
Non-zero
Failure
Note The current version only supports playing MP4 format files.
Player.start#
Starts playing audio and video content.
Syntax
player = Player()
player.start()
Success
Non-zero
Failure
Player.pause#
Pauses the current playback.
Syntax
player = Player()
player.pause()
Success
Non-zero
Failure
Player.resume#
Resumes playback.
Syntax
player = Player()
player.resume()
Success
Non-zero
Failure
Player.stop#
Stops playback.
Syntax
player = Player()
player.stop()
Success
Non-zero
Failure
Player.set_event_callback#
Sets the callback function for playback events.
Parameter Name
Input/Output
callback
Callback function name
Input
Syntax
def player_event(event, data):
    pass
player = Player()
player.set_event_callback(callback=player_event)
Success
Non-zero
Failure
Data Structure Description#
play_event_type#
Defines the types of playback events.
Members
Member Name
K_PLAYER_EVENT_EOF
Playback End
K_PLAYER_EVENT_PROGRESS
Playback Progress
Example Program#
Example 1#
from media.player import *
start_play = False
    global start_play
    if event == K_PLAYER_EVENT_EOF:
        start_play = False
def play_mp4_test(filename):
    global start_play
    # Use IDE as output display, supports any resolution; suitable for BPI development board
    # Use ST7701 LCD screen as output display, maximum resolution is 800x480
    # player = Player(Display.ST7701)
    # Use HDMI as output display
    # player = Player(Display.LT9611)
    player.load(filename)
    player.set_event_callback(player_event)
    player.start()
    start_play = True
    while start_play:
        time.sleep(0.1)
    player.stop()
    print("Playback finished")
play_mp4_test("/sdcard/examples/test.mp4")
