4. Ai2d Preprocessing Examples#
1. Overview#
Based on the interfaces provided by the nncase_runtime module, the AIDemo part has performed secondary encapsulation on nncase_runtime.ai2d. The encapsulation file is in the /sdcard/libs/AI2D.py module. The provided interfaces can be found in: [Ai2d Module API Manual](../../api/aidemo/Ai2d Module API Manual.md). For the 5 preprocessing methods provided by Ai2d, this document provides examples, visualizing the results of preprocessing to help users better understand and use the Ai2d preprocessing process. The unencapsulated nncase_runtime.ai2d interfaces can be found in: nncase_usage.
2. resize Method#
The resize method is an operation widely used in image preprocessing. It is mainly used to change the size of an image. Whether it is to enlarge or reduce an image, this method can be used to achieve it. Here is the sample code for implementing the resize process using Ai2d.
from libs.AI2D import Ai2d
from libs.Utils import *
import nncase_runtime as nn
import ulab.numpy as np
import gc
import sys,os
# Add display mode selection, default is "hdmi", options include "hdmi", "lcd", "lt9611", "st7701", "hx8399".
# By default, "hdmi" is set to "lt9611" with a resolution of 1920x1080; "lcd" is set to "st7701" with a resolution of 800x480.
display_mode = "hdmi"
# Initialize PipeLine for image processing flow
pl = PipeLine(rgb888p_size=[512,512], display_mode=display_mode)
pl.create() # Create a PipeLine instance
my_ai2d=Ai2d(debug_mode=0) # Initialize an Ai2d instance
my_ai2d.set_ai2d_dtype(nn.ai2d_format.NCHW_FMT, nn.ai2d_format.NCHW_FMT, np.uint8, np.uint8)
# Configure the resize preprocessing method
my_ai2d.resize(nn.interp_method.tf_bilinear, nn.interp_mode.half_pixel)
# Build the preprocessing process
my_ai2d.build([1,3,512,512],[1,3,640,640])
with ScopedTiming("total",1):
img = pl.get_frame() # Get the current frame data
print(img.shape) # The shape of the original image is [3,512,512]
ai2d_output_tensor=my_ai2d.run(img) # Perform resize preprocessing
ai2d_output_np=ai2d_output_tensor.to_numpy() # Type conversion
print(ai2d_output_np.shape) # The shape after preprocessing is [1,3,640,640]
gc.collect() # Garbage collection
pl.destroy() # Destroy the PipeLine instance
3. crop Method#
The crop method is an operation used to extract (crop) the region of interest (ROI) from the original image. It can select a part of the image as a new image according to the specified coordinates and size. Here is the sample code for implementing the crop process using Ai2d.
import gc
import sys,os
import image
# Configure the crop preprocessing method
my_ai2d.crop(100,100,300,300)
my_ai2d.build([1,3,512,512],[1,3,200,200])
print(img.shape) # The shape of the original image is [1,3,512,512]
ai2d_output_tensor=my_ai2d.run(img) # Perform crop preprocessing, cropping the data within the range of 100~300px in both the H/W dimensions
print(ai2d_output_np.shape) # The shape after preprocessing is [1,3,200,200]
# Use transpose to process the output into np data arranged in HWC, and then create an Image instance in RGB888 format on the np data for display effects in the IDE
shape=ai2d_output_np.shape
ai2d_output_tmp = ai2d_output_np.reshape((shape[0] * shape[1], shape[2]*shape[3]))
ai2d_output_tmp_trans = ai2d_output_tmp.transpose()
ai2d_output_hwc=ai2d_output_tmp_trans.copy().reshape((shape[2],shape[3],shape[1]))
out_img=image.Image(200, 200, image.RGB888,alloc=image.ALLOC_REF,data=ai2d_output_hwc)
out_img.compress_for_ide()
4. pad Method#
The pad (padding) method is a technique for padding the edges of an image in the image preprocessing stage. It changes the size of the image by adding pixel values around the image (top, bottom, left, and right). These added pixel values can be customized. Here is the sample code for implementing the pad process using Ai2d.
import gc
import sys,os
import image
pl = PipeLine(rgb888p_size=[512,512],display_mode=display_mode)
# Configure the pad preprocessing method
my_ai2d.pad(paddings=[0,0,0,0,15,15,30,30],pad_mode=0,pad_val=[114,114,114])
my_ai2d.build([1,3,512,512],[1,3,512+15+15,512+30+30])
ai2d_output_tensor=my_ai2d.run(img) # Perform pad preprocessing, padding 15px up and down in the H dimension and 30px left and right in the W dimension
print(ai2d_output_np.shape) # The shape after preprocessing is [1,3,542,572]
out_img=image.Image(512+30+30, 512+15+15, image.RGB888,alloc=image.ALLOC_REF,data=ai2d_output_hwc)
5. affine Method#
The affine (affine transformation) method is a technique used for geometric transformation of images in image preprocessing. It can implement various geometric transformation operations such as rotation, translation, and scaling of images, and can maintain the “straightness” of the image (i.e., a straight line remains a straight line after transformation) and “parallelism” (i.e., parallel lines remain parallel after transformation). Here is the sample code for implementing the affine process using Ai2d.
import gc
import sys,os
import image
# Add display mode, default is hdmi, options include hdmi/lcd/lt9611/st7701/hx8399. HDMI defaults to lt9611 with resolution 1920*1080; LCD defaults to st7701 with resolution 800*480
display_mode="hdmi"
# Initialize PipeLine for image processing pipeline
pl.create() # Create PipeLine instance
my_ai2d=Ai2d(debug_mode=0) # Initialize Ai2d instance
# Create an affine transformation matrix, scale by 0.5 in both dimensions, translate 50px in X and Y directions each
affine_matrix = [0.5,0,50,
0,0.5,50]
# Set the affine transform preprocessing
my_ai2d.affine(nn.interp_method.cv2_bilinear,0, 0, 127, 1,affine_matrix)
# Build preprocessing procedure
my_ai2d.build([1,3,512,512],[1,3,256,256])
os.exitpoint() # Check for exit signal
img = pl.get_frame() # Get current frame data
print(img.shape) # Original image shape is [1,3,512,512]
ai2d_output_tensor=my_ai2d.run(img) # Execute affine preprocessing, reduce H/W dimensions by 0.5 times, translate 50px in X/Y direction each
print(ai2d_output_np.shape) # Preprocessed shape is [1,3,256,256]
# Use transpose to process output as HWC arranged np data, then create RGB888 format Image instance on np data for display effect in IDE
out_img=image.Image(256, 256, image.RGB888,alloc=image.ALLOC_REF,data=ai2d_output_hwc)
pl.destroy() # Destroy PipeLine instance
6. shift Method#
The shift method is a bitwise right shift method used in data preprocessing, where each right shift halves the original data. Here is an example code demonstrating the use of Ai2d to implement the affine transformation process.
import gc
import sys,os
import image
background=np.ones((1,3,512,512),dtype=np.uint8)
data_input=np.ones((1,3,256,256),dtype=np.uint8)*240
background[:,:,0:256,0:256]=data_input.copy()
my_ai2d.set_ai2d_dtype(nn.ai2d_format.RAW16, nn.ai2d_format.NCHW_FMT, np.int16, np.uint8)
# Set shift preprocessing, right shift by 1 bit, value becomes half of original
my_ai2d.shift(1)
# Build preprocessing process
my_ai2d.build([1,3,256,256],[1,3,256,256])
print(data_input.shape) # Original shape is [1,3,256,256], all values are 240
ai2d_output_tensor=my_ai2d.run(data_input) # After shift operation, right shift by 1 bit, value becomes half (i.e., 120)
print(ai2d_output_np.shape) # Shape after preprocessing is [1,3,256,256], values changed from 240 to 120
background[:,:,256:,256:]=ai2d_output_np.copy()
# Use transpose to process output into HWC layout in numpy data, then create an RGB888 formatted Image instance for displaying the effect in IDE
shape=background.shape
background_tmp = background.reshape((shape[0] * shape[1], shape[2]*shape[3]))
background_trans = background_tmp.transpose()
background_hwc=background_trans.copy().reshape((shape[2],shape[3],shape[1]))
img=image.Image(512, 512, image.RGB888,alloc=image.ALLOC_REF,data=background_hwc)
