3.9 RTSP Module API Manual#
1. Overview#
This document aims to provide a detailed introduction to the usage and functions of the K230_CanMV RTSP module API. The RTSP module is specifically designed for creating and managing RTSP servers, supporting the transmission and reception of video and audio data.
2. API Introduction#
The multimedia module provides the following RTSP interfaces:
  1. multimedia.rtspserver_create: Create an RTSP server.
  2. multimedia.rtspserver_destroy: Destroy an RTSP server.
  3. multimedia.rtspserver_init: Initialize an RTSP server.
  4. multimedia.rtspserver_deinit: Deinitialize an RTSP server.
  5. multimedia.rtspserver_createsession: Create an RTSP session.
  6. multimedia.rtspserver_destroysession: Destroy an RTSP session.
  7. multimedia.rtspserver_getrtspurl: Get the RTSP URL.
  8. multimedia.rtspserver_start: Start the RTSP server.
  9. multimedia.rtspserver_stop: Stop the RTSP server.
  10. multimedia.rtspserver_sendvideodata: Send video data to the RTSP server.
  11. multimedia.rtspserver_sendaudiodata: Send audio data to the RTSP server.
These interfaces can be used to create and manage RTSP servers, create and destroy RTSP sessions, send video and audio data to the server, and obtain the RTSP URL for streaming.
2.1 multimedia.rtspserver_create#
Description Used to create an RTSP server.
Syntax
rtspserver_create()
Creation successful
Non-0
Creation failed
2.2 multimedia.rtspserver_destroy#
Description Used to destroy an RTSP server.
Syntax
rtspserver_destroy()
Destruction successful
Non-0
Destruction failed
2.3 multimedia.rtspserver_init#
Description Initialize an RTSP server.
Syntax
rtspserver_init(port)
Parameter Name
Input / Output
port
RTSP server listening port
Input
Return Value None
Example
rtspserver_init(8554)
2.4 multimedia.rtspserver_deinit#
Description Deinitialize an RTSP server.
Syntax
rtspserver_deinit()
Return Value None
Example
rtspserver_deinit()
2.5 multimedia.rtspserver_createsession#
Description Create an RTSP session.
Syntax
rtspserver_createsession(session_name, video_type, enable_audio)
Parameter Name
Input / Output
session_name
Session name
Input
video_type
Video encoding type
Input
enable_audio
Whether to enable audio
Input
Return Value None
Example
rtspserver_createsession("session1", "h264", True)
2.6 multimedia.rtspserver_destroysession#
Description Destroy an RTSP session.
Syntax
rtspserver_destroysession(session_name)
  • session_name: Session name.
Return Value None
Example
rtspserver_destroysession("session1")
2.7 multimedia.rtspserver_getrtspurl#
Description Get the RTSP URL.
Syntax
rtspserver_getrtspurl()
Parameter Name
Input / Output
url
RTSP URL
Output
Example
url = rtspserver_getrtspurl()
print(url)
2.8 multimedia.rtspserver_start#
Description Start the RTSP server.
Syntax
rtspserver_start()
Return Value None
Example
rtspserver_start()
2.9 multimedia.rtspserver_stop#
Description Stop the RTSP server.
Syntax
rtspserver_stop()
Return Value None
Example
rtspserver_stop()
2.10 multimedia.rtspserver_sendvideodata#
Description Send video data to the RTSP server.
Syntax
rtspserver_sendvideodata(session_name, data, size, timestamp)
Parameter Name
Input / Output
session_name
Session name
Input
Video data
Input
size
Data size
Input
timestamp
Timestamp
Input
Return Value None
Example
rtspserver_sendvideodata("session1", video_data, video_size, video_timestamp)
2.11 multimedia.rtspserver_sendaudiodata#
Description Send audio data to the RTSP server.
Syntax
rtspserver_sendaudiodata(session_name, data, size, timestamp)
Parameter Name
Input / Output
session_name
Session name
Input
Audio data
Input
size
Data size
Input
timestamp
Timestamp
Input
Return Value None
Example
rtspserver_sendaudiodata("session1", audio_data, audio_size, audio_timestamp)
3. Example Program#
# Example: Demonstrates how to send video and audio data to network streaming via RTSP server.
# Note: Running this example requires an SD card.
# You can start the RTSP server for video and audio streaming.
from media.vencoder import *
from media.sensor import *
import time, os
import _thread
import multimedia as mm
from time import *
class RtspServer:
    def __init__(self, session_name="test", port=8554, video_type=mm.multi_media_type.media_h264, enable_audio=False):
        self.session_name = session_name  # Session name
        self.video_type = video_type      # Video encoding type (H264/H265)
        self.enable_audio = enable_audio  # Whether to enable audio
        self.port = port                  # RTSP server port number
        self.rtspserver = mm.rtsp_server()  # Instantiate RTSP server
        self.venc_chn = VENC_CHN_ID_0     # Video encoding channel
        self.start_stream = False         # Whether to start streaming thread
        self.runthread_over = False       # Whether streaming thread has ended
    def start(self):
        # Initialize streaming
        self._init_stream()
        self.rtspserver.rtspserver_init(self.port)
        # Create session
        self.rtspserver.rtspserver_createsession(self.session_name, self.video_type, self.enable_audio)
        # Start RTSP server
        self.rtspserver.rtspserver_start()
        self._start_stream()
        # Start streaming thread
        self.start_stream = True
        _thread.start_new_thread(self._do_rtsp_stream, ())
    def stop(self):
        if not self.start_stream:
            return
        # Wait for streaming thread to exit
        while not self.runthread_over:
            sleep(0.1)
        # Stop streaming
        self._stop_stream()
        self.rtspserver.rtspserver_stop()
        self.rtspserver.rtspserver_deinit()
    def get_rtsp_url(self):
        return self.rtspserver.rtspserver_getrtspurl(self.session_name)
    def _init_stream(self):
        width = 1280
        height = 720
        width = ALIGN_UP(width, 16)
        # Initialize sensor
        self.sensor = Sensor()
        self.sensor.reset()
        self.sensor.set_framesize(width=width, height=height, alignment=12)
        self.sensor.set_pixformat(Sensor.YUV420SP)
        # Instantiate video encoder
        self.encoder = Encoder()
        self.encoder.SetOutBufs(self.venc_chn, 8, width, height)
        # Bind camera and venc
        self.link = MediaManager.link(self.sensor.bind_info()['src'], (VIDEO_ENCODE_MOD_ID, VENC_DEV_ID, self.venc_chn))
        # Initialize media manager
        # Create encoder
        chnAttr = ChnAttrStr(self.encoder.PAYLOAD_TYPE_H264, self.encoder.H264_PROFILE_MAIN, width, height)
        self.encoder.Create(self.venc_chn, chnAttr)
    def _start_stream(self):
        # Start encoding
        self.encoder.Start(self.venc_chn)
        # Start camera
        self.sensor.run()
    def _stop_stream(self):
        # Stop camera
        self.sensor.stop()
        # Unbind camera and venc
        del self.link
        # Stop encoding
        self.encoder.Stop(self.venc_chn)
        self.encoder.Destroy(self.venc_chn)
        # Clean buffer
    def _do_rtsp_stream(self):
            streamData = StreamData()
            while self.start_stream:
                # Get a frame of stream
                self.encoder.GetStream(self.venc_chn, streamData)
                # Streaming
                    stream_data = bytes(uctypes.bytearray_at(streamData.data[pack_idx], streamData.data_size[pack_idx]))
                    self.rtspserver.rtspserver_sendvideodata(self.session_name, stream_data, streamData.data_size[pack_idx], 1000)
                    #print("stream size: ", streamData.data_size[pack_idx], "stream type: ", streamData.stream_type[pack_idx])
                # Release a frame of stream
                self.encoder.ReleaseStream(self.venc_chn, streamData)
            print(f"Exception {e}")
        finally:
            self.runthread_over = True
            # Stop rtsp server
            self.stop()
    # Create rtsp server object
    rtspserver = RtspServer()
    # Start rtsp server
    rtspserver.start()
    # Print rtsp url
    print("rtsp server start:", rtspserver.get_rtsp_url())
    # Stream for 60s
    sleep(60)
    # Stop rtsp server
    rtspserver.stop()
    print("done")
