Timer Module API Manual#
The K230 integrates 6 Timer hardware modules internally, with a minimum timing period of 1 millisecond (ms).
API Introduction#
The Timer class is located in the machine module.
Example Code#
from machine import Timer
# Instantiate a software timer
tim = Timer(-1)
# Configure the timer in one-shot mode with a period of 100 milliseconds, callback function prints 1
tim.init(period=100, mode=Timer.ONE_SHOT, callback=lambda t: print(1))
# Configure the timer in periodic mode with a period of 1000 milliseconds, callback function prints 2
tim.init(period=1000, mode=Timer.PERIODIC, callback=lambda t: print(2))
# Deactivate the timer
tim.deinit()
Constructor#
timer = Timer(index, mode=Timer.PERIODIC, freq=-1, period=-1, callback=None)
  • index: Timer module number, range is [-1, 5], where -1 represents a software timer.
  • mode: Timer operating mode, can be one-shot or periodic (optional parameter).
  • freq: Timer operating frequency, supports floating-point numbers, unit is Hertz (Hz), this parameter has a higher priority than period (optional parameter).
  • period: Timer operating period, unit is milliseconds (ms) (optional parameter).
  • callback: Timeout callback function, must be set and should have one parameter.
init Method#
Timer.init(mode=Timer.PERIODIC, freq=-1, period=-1, callback=None)
Initialize timer parameters.
  • arg: Argument for the timeout callback function (optional parameter).
deinit Method#
Timer.deinit()
Release timer resources.
