K230 AI in Action - HHB Neural Network Model Deployment Tool#
Copyright 2023 Canaan Inc. ©
Trademark Notice#
Directory#
preface#
Briefly#
This document is the instruction document for the use of HHB on the k230 hardware platform, which guides users on how to compile the model on HHB to generate c code, and how to use the k230 cross-compilation toolchain to compile the program and run on the board.
Reader object#
Definition of acronyms#
abbreviation
description
HHB
Heterogeneous Honey Badger
SHL
Structure of Heterogeneous Library
Revision history#
Document version number
Modify the description
Author
date
First version of the document
Yang Zhang
2023/6/25
1. Overview#
To deploy and run the HHB program on k230 RTT, the following steps are required
  • Based on the HHB development environment, compile the model to generate C code
  • Compile C code using the K230 RTT cross-compilation toolchain
  • Run the executable program on the board
1.1 HHB#
HHB (Heterogeneous Honey Badger) is a set of neural network model deployment toolsets provided by T-Head for the Xuan Tie chip platform. It includes a series of tools required for deployment, such as compilation optimization, performance analysis, process debugging, and result simulation.
Functions and features of HHB:
  • Supports models in the corresponding formats of Caffe, TensorFlow, ONNX and TFLite
  • Data types such as 8/16-bit fixed-point and 16/32-bit floating-point are supported
  • Supports symmetric and asymmetric fixed-point quantization, and supports channel quantization
  • You can optimize the network structure of the model before deployment
  • Compile and generate binaries that can be executed on Wujian SoC platforms
  • Supports behavior simulation on the host
  • The multi-component toolset facilitates secondary development
  • Both the traditional Unix command line and Python interfaces are provided
HHB already supports many different business algorithms for speech and vision, and can import models from different training frameworks such as PyTorch and TensorFlow.
Based on the open-source project TVM, HHB adds rich command line options to provide command mode; presets multi-class quantization algorithms to adapt to the data types supported by different platforms; outputs C code that calls SHL according to the characteristics of different platforms, or directly outputs executable binaries.
HHB frame structure
For detailed instructions, please refer to HHB User Manual
1.2 SHL#
SHL is a set of neural network library APIs provided by T-HEAD for the Xuantie CPU platform. It abstracts interfaces to various common network layers and provides a series of optimized binary libraries.
Features of SHL:
  • Reference implementation for C code versions.
  • Provides an assembly optimization implementation of Xuantie series CPUs.
  • Supports symmetric and asymmetric quantization.
  • Supports data types such as 8-bit fixed point, 16-bit fixed point and 16-bit floating point.
  • Compatible with NCHW and NHWC formats.
  • Use HHB to implement automatic code invocation.
  • Cover different architectures such as CPU, NPU, etc.
  • Additional heterogeneous reference implementations.
SHL provides a completed interface declaration and a reference implementation of the interface, according to which each device provider can complete the optimization work of each interface.
For detailed instructions, please refer to SHL User Manual
2. HHB compilation model#
2.1 Environment Setup#
Precondition: The local PC has docker installed
  • Go to HHBand download the hhb-2.2.35 docker image
  • Unzip, load and then start docker image
    tar xzf hhb-2.2.35.docker.tar.gz
    cd hhb-2.2.35.docker/
    docker load < hhb.2.2.35.img.tar
    ./start_hhb.sh
2.2 Compiling the model#
At present, this version of Docker Image does not integrate C908 model compilation, here we can copy C906 and modify the relevant configuration.
run.sh relevant modifications
  • Modify the value of the --board parameter (from c906 to c908)
  • Add calibration set parameter ( -cd )
  • Add quantization parameter(--quantization-scheme)
The final content of run.sh is as follows
#!/bin/bash -x
hhb -S --model-file mobilenetv2-12.onnx  --data-scale 0.017 --data-mean "124 117 104" --board c908 --input-name "input" --output-name "output" --input-shape "1 3 224 224" --postprocess save_and_top5 --simulate-data persian_cat.jpg -cd persian_cat.jpg   --quantization-scheme "int8_asym_w_sym" --fuse-conv-relu
Note: Different models may have different compilation parameters, which will cause performance data differences. Users need to understand the meaning of each parameter of HHB (hhb -h) based on their own model or consult T-Head.
Execute run.sh to start compiling
=== tensor info ===
shape: 1 3 224 224
data pointer: 0x2e0b40
=== tensor info ===
shape: 1 1000
data pointer: 0x325530
283: 16.053827
281: 14.920615
282: 12.559759
285: 12.182022
287: 11.520982
Finally, a hhb_out directory is generated, as follows
total 17940
drwxr-xr-x 2 root root    4096 Jun 21 09:03 ./
drwxr-xr-x 5 root root    4096 Jun 21 09:02 ../
-rw-r--r-- 1 root root  602112 Jun 21 09:03 input.0.bin
-rw-r--r-- 1 root root    4946 Jun 21 09:03 io.c
-rw-r--r-- 1 root root    1539 Jun 21 09:03 io.h
-rw-r--r-- 1 root root    7410 Jun 21 09:03 main.c
-rw-r--r-- 1 root root   81352 Jun 21 09:03 main.o
-rw-r--r-- 1 root root  112618 Jun 21 09:03 model.c
-rw-r--r-- 1 root root  791576 Jun 21 09:03 model.o
-rw-r--r-- 1 root root  602112 Jun 21 09:03 persian_cat.jpg.0.bin
-rw-r--r-- 1 root root    9534 Jun 21 09:03 persian_cat.jpg.0.bin_output0_1_1000.txt
-rw-r--r-- 1 root root   20086 Jun 21 09:03 process.c
-rw-r--r-- 1 root root    2040 Jun 21 09:03 process.h
Copy the hhb_out directory to /mnt, export to your PC host, which will be re-compiled by the k230 rtt toolchain in the future.
3. Demo#
3.1 Environment Setup#
Precondition: The user has compiled the docker image according to the k230_sdk documentation
start k230 docker image
cd /path/to/k230_sdk
3.2 Compile demo#
We provide a demo of HHB in the k230_sdk, and users only need to copy the C code compiled by HHB to compile the executable program running on the board.
Description of the relevant catalog
directory
remark
/path/to/k230_sdk/src/big/utils/examples/hhb
Users can modify CMakeLists .txt to add new demos
/path/to/k230_sdk/src/big/utils/lib/csi-nn2 and /path/to/k230_sdk/src/big/utils/lib/hhb-prebuilt-decode
Precompiled libraries that C code depends on (CSI-NN2/JPEG/PNG/Zlib, etc., compiled using the MUSL cross-compilation toolchain)
Prepare the use case
The mbv2_onnx_int8 directory is the c code generated by HHB earlier, and after the user modifies the model compilation parameters, it needs to be updated synchronously.
Users can also add demos and modify CMakeLists .txt according to their own model.
Start compiling
The final executable program generated is out/bin/mbv2_onnx_int8.elf
Transfer the files related to mbv2_onnx_int8 to the /sharefs directory of the little core linux
total 5560
-rw-r--r--    1 sshd     sshd       3554304 Jun 25  2023 hhb.bm
-rwxr-xr-x    1 sshd     sshd       1172680 Jun 25  2023 mbv2_onnx_int8.elf
-rw-r--r--    1 sshd     sshd        602112 Jun 25  2023 persian_cat.jpg.0.bin
3.3 Run demo#
  • Power on K230, execute the following command at serial port of the big core RTT
=== tensor info ===
shape: 1 3 224 224
data pointer: 0x300170060
=== tensor info ===
shape: 1 1000
data pointer: 0x300194c80
283: 15.581656
281: 14.731747
282: 12.559759
285: 11.709850
287: 11.143245
=== tensor info ===
shape: 1 3 224 224
=== tensor info ===
shape: 1 1000
283: 16.053827
281: 15.109484
282: 13.220798
287: 12.087587
285: 11.804284
