K230 GUI in Action - LVGL Porting Tutorial#
Directory#
preface#
Reader object#
This document is intended primarily for:
  • Technical Support Engineer
Definition of acronyms#
abbreviation
illustrate
DRM
Direct Rendering Manager
KMS
Kernel Mode Setting
GUI
Graphical User Interface
Revision history#
Document version number
Modify the description
Author
date
Initial edition
Author
2023/06/25
K230 GUI in action#
LVGL is a popular free and open source embedded graphics library that can be used for graphical user interface (GUI) development of embedded systems.
Hardware environment#
  • K230-USIP-LP3-EVB-V1.1
  • LCD screen
The k230 uses DRM as a display driver, DRM (Direct Rendering Manager) is a subsystem in the Linux kernel that can support complex GPU operations such as hardware-accelerated graphics rendering compared to the outdated Framebuffer. lvgl can draw GUIs based on the interface provided by libdrm.
The lvgl component has been ported to the SDK, and a runnable demo has been compiled by default, which is /usr/bin/lvgl_demo_widgets.
LVGL source location#
The SDK already contains the ported LVGL at the path src/little/buildroot-ext/package/lvgl. during the buildroot compilation of the SDK, the source code will be placed in a directory output/k230_evb_defconfig/little/buildroot-ext/build/lvgl-v8.3.7 that contains the lvgl source code package pulled from GitHub and the ported files under the src path mentioned above. The directory structure is as follows:
├── lv_conf.h
├── lv_drivers
│   ├── display
│   │   ├── drm.c
│   │   └── drm.h
│   ├── indev
│   │   ├── AD_touch.c
│   │   ├── AD_touch.h
│   │   ├── evdev.c
│   │   ├── evdev.h
│   │   ├── keyboard.h
│   │   ├── libinput.c
│   │   ├── libinput_drv.h
│   │   ├── mouse.h
│   │   └── mousewheel.h
│   └── lv_drivers.mk
├── lv_drv_conf.h
├── main.c
├── Makefile
└── mouse_cursor_icon.c
lvgl DRM driver#
After the DRM driver in the Linux kernel is successfully loaded, the following device nodes will appear /dev/dri/card0.
Specific introduction to DRM driver source code#
LVGL’s DRM driver is located src/little/buildroot-ext/package/lvgl/port_src/lv_drivers/display/drm.c to operate on DRM, you need to open the file node first. The following functions are mainly used in the use of LVGL:
  • drm_init() DRM initialization.
  • drm_get_sizes() to get monitor resolution information.
  • drm_flush() displays the drawing callback interface.
DRM resources will be automatically obtained during the drm initialization process, including connect id, plane id, crtc id, etc., and will automatically match the corresponding supported plane according to the color format selected in the configuration file.
The DRM driver has double buffer enabled by default, but in the absence of hardware acceleration, the double buffer refresh rate is low, you can comment out the following code to refresh in single buffering, the display effect will be better:
 if (!drm_dev.cur_bufs[0])
 else
  drm_dev.cur_bufs[0] = fbuf;
Use of LVGL#
LVGL’s main program file is located at: src/little/buildroot-ext/package/lvgl/port_src/main.c
The main steps used by LVGL#
  1. LVGL initialization:
    lv_init();
  2. Display driver initialization:
    drm_init();
    lv_disp_drv_init(&disp_drv);
    disp_drv.hor_res    = lcd_w;
    disp_drv.ver_res    = lcd_h;
    disp_drv.screen_transp = 1;
  3. Touch Drive:
    evdev_init();
  4. Demo routine:
    lv_demo_widgets();
For more detailed usage of lvgl, please refer to the lvgl website https://lvgl.io, API documentation and examples: https://docs.lvgl.io/8.3/index.html
It is also possible to use LVGL’s drag-and-drop UI editor, SquareLine Studio, to simplify development: https://squareline.io
compile#
Perform default compilation all in the root directory of the SDK make.
Run lv_demo_widgets#
lvgl_demo_widgets
After executing the above command, the configuration interface will be displayed on the LCD screen, and the relevant configuration can be made through the touch screen, as follows:
Display content
Of course, lvgl application development can also be compiled as a standalone project instead of in the SDK, you can refer to the lvgl/lv_port_linux_frame_buffer project to replace the port files in the SDK, and then configure the K230 cross-compilation toolchain and the corresponding libdrm reference.
