CanMV K230 Tutorial
Contents
CanMV K230 Tutorial#
Directory#
[toc]
preface#
Based on the CanMV-K230 development board, this article introduces the development process of the K230 SDK, nncase, and AI.
Get started quickly#
Overview of the development board#
The CanMV-K230 development board uses the latest generation of SoC chip K230 in the Canaan Kendryte® series AIoT chips. The chip adopts a new multi-heterogeneous unit accelerated computing architecture, integrates 2 RISC-V energy-efficient computing cores, built-in a new generation of KPU (Knowledge Process Unit) intelligent computing unit, has multi-precision AI computing power, widely supports common AI computing frameworks, and the utilization rate of some typical networks exceeds 70%.
The chip also has a variety of peripheral interfaces, as well as 2D, 2.5D and other scalar, vector, graphics and other special hardware acceleration units, which can accelerate the whole process of computing and acceleration of a variety of diverse computing tasks such as image, video, audio, and AI, and has many characteristics such as low latency, high performance, low power consumption, fast startup, and high security.
K230_block_diagram
CanMV-K230 adopts a single board design and rich expansion interfaces, which greatly exerts the advantages of K230’s high performance, and can be directly used in the development of various intelligent products to accelerate product landing.
CanMV-K230 default kit#
The CanMV-K230 board default kit contains the following items:
1 CanMV-K230 motherboard x 1
2 OV5647 camera x 1
3 Type-C data cable x 1
In addition, the user needs to prepare the following accessories:
1 TF card, used to flash firmware, boot system (required)
2 Display with HDMI interface and HDMI cable, the display must support 1080P30, otherwise it cannot be displayed
3 100M/1000M Ethernet cable, and wired router
Debugging instructions#
Serial port connection#
Use the Type-C cable to connect the CanMV-K230 to the position shown below, and connect the other end of the cable to the computer.
Serial port debugging#
Windows#
Install the driver
CanMV-K230 comes with USB to serial port chip CH342, driver download addresshttps://www.wch.cn/downloads/CH343SER_EXE.html.
Check the serial port number
Two serial ports are shown here, COM80 is the debugging serial port of small-core Linux, and COM81 is the debugging serial port of large-core rt-smart.
Configure serial port information
Open the tool Xshell (you can also use other serial port tools).
1 Port number: Select the port number displayed by Device Manager
2 Baud rate 115200
3 Data bit 8
4 Stop bit 1
5 Not Parity test
6 Not Flow control
linux#
The Linux serial port is displayed as follows:
  • /dev/ttyACM0Debug the serial port for small-core Linux
  • /dev/ttyACM1Debug the serial port for the large-core RT-SMART
You can use Linux minicom or other serial port tools for connection debugging, and the serial port configuration information is consistent with Windows.
Firmware acquisition and flashing#
Firmware acquisition#
CanMV-K230 firmware download address: https://kendryte-download.canaan-creative.com/developer/k230
Please download the gz archive starting with “k230_canmv” and extract the sysimage-sdcard.img file, which is the firmware of CanMV-K230.
Firmware flashing#
Flash the firmware to the TF card through the computer.
Burning under Linux#
Before inserting the TF card into the host, enter:
ls -l /dev/sd\*
View the current storage device.
After inserting the TF card into the host, enter again:
ls -l /dev/sd\*
Looking at the storage device at this time, the new addition is the TF card device node.
Assume that /dev/sdc is the TF card device node, run the following command to flash the TF card:
Flashing under Windows#
Windows can burn the SD card through the rufus tool (rufus tool download address http://rufus.ie/downloads/).
1)Insert the TF card into the PC, then launch the rufus tool, click the “select” button on the tool interface, and select the firmware to be programmed, as shown below. rufus-flash-from-file
2)Click the “Start” button to start flashing, the flashing process has a progress bar display, and Ready will be prompted after flashing rufus-flash rufus-sure rufus-warning rufus-finish
Start the system#
Insert the TF card with burned firmware into the CanMV-K230 TF card slot, connect the Type-C cable to the POWER port at the computer and the board end, the board will be powered on, and the system will start to start. CanMV-K230-poweron
If the red light in the red frame is on, it means that the board is powered up normally. View the serial port information at this time.
CanMV-K230-run
After the system starts, the face detection program is run by default, the camera is pointed at the face, and the face will be framed on the monitor.
CanMV-K230-aidemo
Linux + RT-smart dual system development#
This section describes how to use the K230 SDK for Linux and RT-smart system development. The K230 SDK includes the source code, toolchain and other related resources needed for development of heterogeneous systems based on Linux and RT-smart dual-core.
Development environment setup#
Compile the environment#
Host environment
description
Docker compilation environment
The SDK provides a docker file, which can generate docker images for compiling the SDK
Ubuntu 20.04.4 LTS (x86_64)
The SDK can be compiled in the ubuntu 20.04 environment
The K230 SDK needs to be compiled in the Linux environment, the SDK supports docker environment compilation, and the docker file() is released in the SDK development package,tools/docker/Dockerfile which can generate docker images. The specific dockerfile usage and compilation steps will be described in detail in the compilation section below.
The Docker image used by the SDK is based on ubuntu 20.04, if you do not use the docker compilation environment, you can refer to the content of dockerfile in the ubuntu 20.04 host environment, install the relevant HOST package and toolchain, and compile the SDK.
The K230 SDK has not been verified in the host environment of other Linux versions, and there is no guarantee that the SDK can be compiled in other environments.
SDK development kit acquisition#
The SDK is currently released simultaneously on GitHub and GitHub
Users can download the archive directly, download it at https://github.com/kendryte/k230_sdk/releases https://gitee.com/kendryte/k230_sdk/releases or
git clone https://gitee.com/kendryte/k230_sdk.git
Users can choose to use GitHub or GitHub according to their network conditions.
SDK compilation#
Compile the introduction#
The K230 SDK supports one-click compilation of large and little core operating systems and common components, and generates image files that can be programmed for deployment to the development board and start running. The username of the Linux system on the device is root without password;
Setp 1: Refer to the above to get the SDK development package
Step 3: Download toolchain
Step 4: Generate a docker image (required for the first compilation, skip this step after you have generated a docker image)
Step 5: Enter the docker environment,
Step 6: Run the following command in the Docker environment to compile the SDK
make CONF=k230_canmv_defconfig #编译CanMV-K230 board image
The SDK does not support multi-process compilation, do not add multi-process compilation parameters like -j32.
Compile the output artifacts#
After the compilation is complete, you output/k230_canmv_defconfig/imagescan see the compilation output in the directory
imagesThe image files in the directory are described as follows:
sysimage-sdcard.img ————- is the boot image of the TF card;
sysimage-sdcard.img.gz ——— is the boot image compressed package of the TF card (gzip archive of sysimage-sdcard.img file), which needs to be decompressed first when burning.
At this point, the entire SDK is compiled, and the adult image sysimage-sdcard.img can be flashed to the TF card to boot the system.
example#
For basic hello world, please refer to K230_Practical_Basics_hello_world
In the case of Vicap_demo, the code is located at k230_sdk/src/big/mpp/userapps/sample/sample_vicap
VICAP Demo implements the camera data acquisition preview function by calling the MPI interface. The CanMV development board uses the OV5647 camera module by default, which supports up to three data streams for a single camera.
compile#
Execute make rt-smart-clean && make rt-smart && make build-image in the k230_sdk directory, compile the changes of the big core into the sd card image, and generate the image file sysimage-sdcard.img in the k230_sdk/output/k230_evb_defconfig/images/ directory
The corresponding program is located at k230_sdk/src/big/mpp/userapps/sample/elf/sample_vicap.elf
execute#
The big kernel end enters /sharefs/app and executes commands in this directory./sample_vicap to obtain command help information When you entersample_vicap the : command, print the following prompt:
Options:
The parameters are described as follows:
Parameter name
Optional parameter value
Parameter description
-Dev
0: vicap device 0 1: vicap device 1 2: vicap device 2.
Specify the currently used vicap device, and the system supports up to three vicap devices. By specifying the device number, the binding relationship between the sensor and different vicap devices is realized. For example: -dev 1 -sensor 0 binds the ov9732 1280x720 RGB image output to vicap device 1.
-mode
0: Online mode; 1: Offline mode
Specify the vicap device working mode, current before online mode and offline mode. For multiple sensor inputs, it must be specified as offline mode.
-sensor
23: OV5647 (CanMV development board only supports this sensor)
Specifies the type of sensor currently in use
-Chn
0: vicap device output channel 0 1: vicap device output channel 1 2: vicap device output channel 2.
Specify the output channel of the currently used vicap device, one vicap device supports up to three outputs, and only channel 0 supports RAW image format output
-ow
Specifies the output image width, which defaults to the input image width. The width needs to be 16 bytes aligned. If the default width exceeds the maximum width of the display output, the display output width is used as the final output width of the image If the output width is smaller than the input image width and the ox or oy parameters are not specified, the default is the scaled output
-oh
Specifies the output image height, which defaults to the input image height. If the default height exceeds the maximum height of the display output, the display output height is used as the final output height of the image If the output height is less than the input image height and the ox or oy parameter is not specified, the default is the scaled output
-ox
Specifies the horizontal start position of the image output, this parameter greater than 0 will perform the output cropping operation
-Limited liability company
Specifies the vertical start position of the image output, this parameter greater than 0 will perform the output cropping operation
-crop
0: Disable the cropping function 1: Enable the cropping function
When the output image size is smaller than the input image size, the output is not scaled by default, or clipped if the flag is specified
-ofmt
0:YUV format output 1:RGB format output 2:RAW format output
Specify the output image format, the default is YUV output.
-preview
0: Disable preview display 1: Enable preview display
Specifies the output image preview display function. The default is enabled. Currently, up to 2 output images can be previewed at the same time.
-rotation
0: Rotate 0 degrees 1: Rotate 90 degrees 2: Rotate 180 degrees 3: Rotate 270 degrees 4: Rotation is not supported
Specifies the rotation angle of the preview display window. By default, only the first output image window supports the rotation function.
Example 1:
Note: Bind the ov5647@1920x1080 RGB output to vicap device 0 and enable vicap device output channel 0 and channel 1, where channel 0 output size defaults to the input image size (1920x1080) and channel 1 output image size is 640x480
For the API used in this example, refer to
K230_VICAP_API Reference.md
K230_Video Output _API Reference.md
For other demos supported by the CanMV-K230 development board, please refer to the K230_SDK_CanMV_Board_Demo User Guide
For other SDK-related documents, please visit the K230 SDK documentation
Developed by nncase#
nncase is a neural network compiler for AI accelerators, which is used to generate model files, .kmodel, required for inference for Kendryte series chips and provide runtime lib.
This tutorial mainly includes the following:
  1. Use nncase to compile the model and generate kmodel.
  2. Inference kmodel on PCs and development boards.
Tips:
  1. This tutorial aims to familiarize users with the process of using nncase, and the input data of the model in this doc are random numbers. For details about the actual application scenario, see the subsequent chapter “AI Development”.
  2. The version of nncase in the official CanMV image may be outdated, if you need to use the latest nncase, you need to update the runtime library and recompile the CanMV image.
Model compilation and simulator inference#
Install the nncase toolchain#
The nncase toolchain includes both nncase and nncase-kpu plugin packages, both of which need to be installed correctly to compile the model files supported by CanMV-K230. Both nncase and nncase-kpu plugin packages are released on NNcase GitHub Release and depend on dotnet-7.0.
  • In Linux platform, nncase and nncase-kpu can be installed directly online by pip, and use apt to install dotnet in the Ubuntu environment.
    pip install --upgrade pip
    pip install nncase
    pip install nncase-kpu
    # nncase-2.x need dotnet-7
    sudo apt-get update
    Tips: If you use the official CanMV image, you need to check the version of SDK and nncase.
  • The Windows platform only supports nncase online installation, and you need to manually download nncase-kpu on NNcase GitHub Release and install it.
  • If you do not have an Ubuntu environment, you can use nncase docker (Ubuntu 20.04 + Python 3.8 + dotnet-7.0).
    cd /path/to/nncase_sdk
    Tips: Currently only support py3.6-3.10, if pip installation fails, please check the pip version corresponding to Python.
Environment configuration#
After using pip to install the packages, you need to add the installation path to the PATH environment variable.
Original model description#
Currently nncase supporte tflite, onnx format models, more formats support is ongoing.
Tips:
  1. For TensorFlow models, pb format, please refer to the official documentation to convert them to the tflite model. Be careful not to set quantization options, just export the floating-point model. If quantize and dequantize operators exist in the model, they belong to quantization models and are currently not supported.
  2. For PyTorch models, pth format, you need to use torch.export.onnx to export the onnx model.
Description of compilation parameters#
Before compiling a model, you need to know the following key information:
  1. KPU uses fixed-point operations when making inferences. Therefore, when compiling the kmodel, you must configure quantization-related parameters that are used to convert the kmodel from floating point to fixed point. Details in nncase documentation PTQTensorOptions.
  2. nncase support for adding preprocessing operations in kmodel, which can reduce the preprocessing overhead when inference. The relevant parameters and schematics are found in nncase documentation CompileOptions.
Description of compilation script#
This Jupyter notebook describes in detail the process of compiling and infering kmodels using nncase. It contains the following information。
  • Parameter configuration: describes how to correctly configure compilation parameters in order to satisfy the demands of actual deployment.
  • Obtain model information: explain the method of obtaining key data such as network structure and layer information from the original model.
  • Set calibration dataset: explains how to prepare calibration dataset sample data, including single-input and multiple-input models, for quantifying the calibration process.
  • Set the inference data format: explains how to configure input data during inference to support different demand scenarios.
  • Configure multi-input model: describes how to correctly set the shape, data format and other information of each input when processing multi-input model.
  • PC simulator inference: explain how to use the simulator to infer on PC the kmodel, which is a key step to verify the compilation effect;
  • Compare inference results: verify the correctness of kmodels by comparing inference results with different frameworks (TensorFlow, PyTorch, etc.);
    The above steps systematically introduce the whole process of model compilation and inference, which is suitable for beginners to learn from scratch and can also be used as a reference guide for experienced users.
Sample code#
When you have read the full tutorial in the Jupyter notebook, you can modify the options based on the following sample code.
import nncase
import numpy as np
import onnx
import onnxsim
def get_cosine(vec1, vec2):
    result compare
    read model
        model_content = f.read()
    return model_content
    parse onnx model
    input_tensors = [
    # input
    inputs = []
        input_dict = {}
        input_dict['name'] = e.name
        inputs.append(input_dict)
    return onnx_model, inputs
    simplify model
        input_shapes = {}
        for input in inputs:
        print("[ onnx done ]")
        print("[ tflite skip ]")
    return model_file
    print("Load kmodel...")
    print("Set input data...")
    print("Run...")
    model_sim.run()
    print("Get output result...")
    all_result = []
        all_result.append(result)
    return all_result
    Compile kmodel.
    print("Simplify...")
    print("Set options...")
    # import_options
    # The code below, you need to modify to fit your model.
    # compile_options
    # preprocess args
        compile_options.std = [1,1,1]
    # quantize options
    # mix quantize options
    ptq_options.quant_scheme = ""
    print("Compiling...")
    # import
    compiler.use_ptq(ptq_options)
    # compile
    compiler.compile()
        f.write(kmodel)
    return kmodel_path
    # compile kmodel single input
    model_path = "./test.tflite"
    dump_path = "./tmp_tflite"
    # sample_count is 2
    # run kmodel(simulate)
        print(i.shape)
Notes#
When you encounter problems when compiling the model, you can find the error log in the FAQ to find a solution, you can also raise an issue according to the template in github or ask questions directly in nncase QQ communication group: 790699378.
At the same time, you are also welcome to propose your problems and solutions PR to nncase, contribute to the open source work.
Model inference based on the development board#
Currently CanMVsupports two sets of development APIs,C++ and , MicroPythonyou can choose according to your needs.
  • MicroPython with a low development threshold, users can directly write code similar to Python for application development;
  • C++ has a higher threshold, but it is more flexible and has better performance (the inference performance of the chip is not affected by language).
When inference on the board, we provide two modules to accelerate model inference
Next, we will explain how these two modules are used in the C++ code example and what needs to be noticed.
Taking face detection as an example, the directory structure and important functions of the code will be explained below, and the complete code example is shown in k230_sdk/src/big/nncase/examples/image_face_detect .
Directory structure#
In the example directory, the file structure related to model inference is as follows:
├── build_app.sh
├── CMakeLists.txt
├── image_face_detect
│   ├── anchors_320.cc
│   ├── CMakeLists.txt
│   ├── main.cc
│   ├── mobile_retinaface.cc
│   ├── mobile_retinaface.h
│   ├── model.cc
│   ├── model.h
│   ├── util.cc
│   └── util.h
└── README.md
  • build_app.sh: The script of compile that generates the executable image_face_detect.elf and output it to the out directory.
  • CMakeLists.txt: Set the libraries that need to be linked during compilation:opencv, mmz, nncase. Only need to modify add_subdirectory() in your project.
  • image_face_detect: Complete face detection demo, which includes AI2D, KPU and post-processing, etc.
AI2D configuration#
In mobile_retinaface.cc, the pad and resize of AI2D function were used. The code block of class MobileRetinaface constructor will be explained below, it contains the configuration of AI2D parameters.
  1. Set the AI2Doutput tensor
input_tensor(0) is to get the input tensor of KPU. This step is to set the input tensor of KPU to the output tensor of AI2D. Connect the two parts of the hardware without any other hardware control.
  1. Set AI2Dthe parameters
    int h_pad_before = h_pad / 2;
    int w_pad_before = w_pad / 2;
#if ENABLE_DEBUG
#endif
First, you need to set the basic parameters of AI2D, including input format, output format, input type, and output type.Then set the AI2D function parameters, only Pad and Resize function were used in face detection demo, but you still need to explicitly set the parameters of other functions, such as crop,shift and affine, only set the first parameter to false and the rest of the parameters conform to the syntax.
  1. Generate instructions of AI2D
First you need to create the ai2d_builder object. If it already exists, you need to use the reset function to update the parameters in it, and then call the function build_schedule() to complete the instruction generation.
At this point, the configuration of AI2D is over, let’s take a look at the related configuration of KPU.
KPU configuration#
The KPU related configuration is carried out in ‘model.cc’, mainly allocating the memory and settings of the input tensor in advance. Let’s look at the constructor of the class ‘Model’:
    // load kmodel
    // create kpu input tensors
  1. Read the model
interp_.load_model(ifs).expect("load_model failed");
First convert the file path to a stream, and then stream loading via load_model().
  1. Input tensor memory allocation
Here, an empty tensor is created based on the shape information and type information obtained from the model.
Q: Why is it empty tensor, instead of directly filling the data into it?
A: You can first take a look at AI2D what we did when setting the output tensor. Yeah, the empty tensor is to receive the output data of AI2D, so there is no need to set the data directly. However, if you do not use AI2D module, then here you need to set the input data, for example:
auto tensor = host_runtime_tensor::create( desc.datatype, shape, { (gsl::bytes*)vector.data(), (size_t)vector.size() }, true, hrt::pool_shared).expect(“cannot create input tensor”);
At this point, the relevant configuration of KPU is also completed, and then we will see how to execute these two parts of the module.
Start inference#
Inference is performed in the ai_proc function of main.cc, and the code that initiates inference is:
result is the output of the model, AI2D and KPU were called in run().
    preprocess(vaddr, paddr);
    kpu_run();
    postprocess();
    // ai2d input tensor
    // run ai2d
void Model::kpu_run()
The preprocess() function starts the inference of AI2D and the kpu_run() function starts the inference of KPU. Of course, before starting the inference, you need to set the physical address of input for AI2D. The input tensor of AI2D can get the data through input device directly.
Tips: The postprocess() function calls the post-processing part of the model, which varies from model to model and from version to version of the same model, before the full inference is done.
Make sure that the results of your post-processing C++ code are consistent with the results of your Python model post-processing!!
AI development#
AI development requires environment construction, data preparation, model training and testing, CANMV k230 image compilation and programming, C++ code compilation, network configuration and file transfer, and k230 device deployment. Take the vegetable classification scenario as an example. For the code, see: kendryte/K230_training_scripts.
Environment setup#
(1) Linux system;
(2) Install the graphics card driver;
(3) Install Anaconda to create a model training environment;
(4) Install Docker to create an SDK image compilation environment;
(5) Install dotnet SDK;
Data preparation#
The custom data set for the image classification task is organized in the following format:
dataset_frame
Note: Image categories must be organized strictly according to the above format.
Model training and testing#
Create a virtual environment#
Open the command terminal:
conda activate myenv
Install the Python library#
Install the Python library used for training according to the requriements .txt in the project, and wait for installation:
In the requriments .txt, the model transformation packages nncase and nncase-kpu, a neural network compiler designed for AI accelerators, are installed.
Configure training parameters#
The configuration file yaml/config.yaml in the given training script is set as follows:
dataset:
  root_folder: ../data/veg_cls # Classification dataset path
  split: true # Whether to re-execute the split, the first execution must be true
  train_ratio: 0.7 # Training set proportion
  val_ratio: 0.15 # Validation set proportion
  test_ratio: 0.15 # Test set proportion
train:
  device: cuda
  txt_path: ../gen # The training set, verification set, test set txt files, label name files, and calibration set files generated by the splitting process
  image_size: [ 224,224 ]
  mean: [ 0.485, 0.456, 0.406 ]
  std: [ 0.229, 0.224, 0.225 ]
  epochs: 10
  batchsize: 8
  learningrate: 0.001
  save_path: ../checkpoints # Model save path
inference:
  mode: image # Inference mode is divided into image and video; in image mode, a single picture and all pictures in the directory can be inferred, and video calls the camera to achieve inference.
  inference_model: best # best or last, call best.pth and last.pth under checkpoints respectively for reasoning.
  images_path: ../data/veg_cls/bocai # If the path is a image path, inference will be performed on a single picture; if the path is a directory, inference will be performed on all pictures in the directory.
deploy:
  chip: k230 # k230 or cpu
  ptq_option: 0 # Quantization type, 0 is uint8, 1, 2, 3, 4 are different forms of uint16
Model training#
Go to the project’s scripts directory and execute the training code:
python3 main.py
If the training is successful, you can find the trained last.pth, best.pth, best.onnx, and best.kmodel in the model_save_dir directory of the configuration file.
Model testing#
Set the Inference section in the configuration file, set the test configuration, execute the test code:
python3 inference.py
Prepare the file#
The files required for later deployment steps include:
(1)checkpoints/best.kmodel;
(2)gen/labels.txt;
(3) test .jpg of the picture to be tested;
CANMV K230 image compilation and burning#
Docker environment setup#
# Download docker compiled image
# You can use the following command to confirm whether the docker image is successfully pulled
# download sdk
# Download toolchain Linux and RT-Smart toolchain, buildroot package, AI package, etc.
make prepare_sourcecode
# Create a docker container, $(pwd):$(pwd) means that the current directory of the system is mapped to the same directory inside the docker container, and the toolchain directory under the system is mapped to the /opt/toolchain directory inside the docker container.
Image compilation#
# Compiling the image in the docker container takes a long time, please wait patiently for completion.
Image burning#
After the compilation is completed, you can find the compiled image file in the output/k230_canmv_defconfig/images directory:
 ├── big-core
 ├── little-core
 ├── sysimage-sdcard.img    # SDcard image
 └── sysimage-sdcard.img.gz
The CANMV K230 supports SDCard boot mode. To facilitate development, it is recommended that you prepare a TF card (Micro SD card).
Linux: If you use Linux to flash a TF card, you need to confirm the name of the SD card in the system /dev/sdx, and replace /dev/sdx in the following command
Windows: If you are using Windows burning, it is recommended to use rufus tool. Download the generated sysimage-sdcard.img locally and burn it using the burning tool rufus.
rufus-flash
After the burning is successful, a notification message will pop up. It is best to format the SD card before flashing.
Power on the development board#
Install MobaXterm to achieve serial communication, MobaXterm download address:https://mobaxterm.mobatek.net .
CanMV-K230_debug
Insert the flashed SD card into the open board card slot, HDMI output to display, 100 Gigabit network port to Ethernet, POWER to serial port and power supply.
After the system is powered on, there will betwo serial devices by default, which can be used to access small-core Linux and large-core RTSmart
The default user name of little core Linux is root, and the password is empty. The RTSmart system automatically launches an application and can exitq to the Command Prompt terminal by pressing the key.
C++ code compilation#
After completing the preparations for the above development board, we can use C++ to write our own code. Taking the image classification task as an example, the following example code for related image classification tasks is given and analyzed. Sample code reference: kendryte/K230_training_scripts.
Code structure#
k230_code
├── cmake
│    ├── link.lds
│    ├── Riscv64.cmake
├── k230_deploy
│    ├── ai_base.cc # Model deployment base class
│    ├── ai_base.h # The model deployment base class encapsulates nncase loading, input settings, model inference, and output acquisition operations. For subsequent specific task development, you only need to focus on the pre-processing and post-processing of the model.
│    ├── classification.cc # classification code
│    ├── classification.h # Image classification task class definition, inherits AIBase, and is used to encapsulate the pre- and post-processing of model inference.
│    ├── main.cc # Main function, parameter analysis, initialization of Classification class examples, and implementation of the board function
│    ├── scoped_timing.hpp # tool of getting  running time
│    ├── utils.cc # tool class
│    ├── utils.h # The tool class encapsulates common functions for image preprocessing and image classification, including reading binary files, saving pictures, image processing, result drawing, etc. Users can enrich the file according to their own needs.
│    ├── vi_vo.h # Video input and output header files
│    ├── CMakeLists.txt # CMake script is used to build an executable file using C/C++ source files and linking to various libraries
├── build_app.sh # Compile the script and use the cross-compilation tool chain to compile the k230_deploy project
└── CMakeLists.txt # CMake script is used to build the nncase_sdk project project
Core code#
After you get the kmodel model, the specific AI board code includes: sensor&display initialization, kmodel loading, model input and output settings, image acquisition, input data loading, input data preprocessing, model inference, model output acquisition, output post-processing, OSD display Wait for steps. as the picture shows:
pipeline
The yellow box part in the figure provides sample code in Example 2 of the SDK compilation chapter. The following describes how to implement AI development for the red box part.
In the above process, kmodel loading, model input setting, model inference, and model output acquisition are common steps for all tasks. We have encapsulated this, and ai_base.h and ai_base.cc can be copied and used directly.
ai_base.h defines the AIBase base class and interfaces for common operations:
#ifndef AI_BASE_H
#define AI_BASE_H
#include <vector>
#include <string>
#include <fstream>
#include "scoped_timing.hpp"
using std::string;
using std::vector;
 * @brief AI base class, encapsulating nncase related operations
 * It mainly encapsulates the loading, setting input, running, and obtaining output operations of nncase. Subsequent development of the demo only needs to focus on the pre-processing and post-processing of the model.
class AIBase
public:
     * @brief AI base class constructor, loads kmodel, and initializes kmodel input and output
     * @param kmodel_file kmodel file path
     * @param debug_mode  0(no debug)、 1(print time)、2(print all)None
     * @return None
     * @return None
    ~AIBase();
     * @brief set kmodel input
     * @param buf input data pointer
     * @param size Input data size
     * @return None
     * @brief Get kmodel input tensor according to index
     * @param idx
     * @return None
     * @brief Set the input tensor of the model
     * @param idx
     * @param tensor
     * @brief Initialize kmodel output
     * @return None
    void set_output();
     * @brief inference kmodel
     * @return None
    void run();
     * @brief Get kmodel output and save the result in the corresponding class attribute
     * @return None
    void get_output();
protected:
    string model_name_;                    // model name
    int debug_mode_;
    vector<float *> p_outputs_;            // kmodel outputs the corresponding pointer list
    vector<vector<int>> output_shapes_;    //{{N,C,H,W},{N,C,H,W}...}} or {{N,C},{N,C}...}}
private:
     * @brief Initialize the kmodel input for the first time and obtain the input shape
     * @return None
    void set_input_init();
     * @brief Initialize kmodel output for the first time and obtain the output shape
     * @return None
    void set_output_init();
    vector<unsigned char> kmodel_vec_; // The entire kmodel data is obtained by reading the kmodel file, which is used to pass it to the kmodel interpreter to load kmodel.
    interpreter kmodel_interp_; // The kmodel interpreter is built from the kmodel file and is responsible for the loading, input and output of the model.
#endif
ai_base.cc is the specific implementation of all interfaces defined in ai_base.h.
The specific implementation of the interface defined by the AIBase class in ai_base.h
#include "ai_base.h"
#include <iostream>
#include <cassert>
#include "utils.h"
using std::cout;
using std::endl;
using namespace nncase;
/*AIBase constructor*/
    if (debug_mode > 1)
    std::ifstream ifs(kmodel_file, std::ios::binary);//read kmodel
    kmodel_interp_.load_model(ifs).expect("Invalid kmodel");//load kmodel
    set_input_init();
    set_output_init();
/*destructor*/
AIBase::~AIBase()
Initialize kmodel input for the first time
void AIBase::set_input_init()
    ScopedTiming st(model_name_ + " set_input init", debug_mode_);//get time
    int input_total_size = 0;
    each_input_size_by_byte_.push_back(0); // Fill in 0
        auto desc = kmodel_interp_.input_desc(i);//Input description with index i
        auto shape = kmodel_interp_.input_shape(i);//Input shape with index i
        auto tensor = host_runtime_tensor::create(desc.datatype, shape, hrt::pool_shared).expect("cannot create input tensor");//create a tensor
        kmodel_interp_.input_tensor(i, tensor).expect("cannot set input tensor");//Bind tensor to model input
        input_shapes_.push_back(in_shape);//Store input shape
        int dsize = shape[0] * shape[1] * shape[2] * shape[3];//Enter the total number of bytes
        if (debug_mode_ > 1)
        if (desc.datatype == 0x06)//The input data is of uint8 type
            input_total_size += dsize;
        else if (desc.datatype == 0x0B)//The input data is of float32 type
        else
Set the input data of the model and load the specific data input by the model. The difference between set_input_init and set_input_init is whether there is a data copy process.
    //Check whether the input data size matches the model required size
    //get time
        //Get the input description and shape of the model
        //create tensor
        //Map input tensor to writable area
        auto mapped_buf = std::move(hrt::map(tensor, map_access_::map_write).unwrap());
        //Copy data to tensor buffer
        //Unmap
        if (!ret.is_ok())
            std::abort();
        //Bind the tensor to the input of the model
Get the input tensor of the model according to the index
Set the input tensor of the model according to the index
    //get time
    int output_total_size = 0;
        //Get output description and shape
        vector<int> out_shape;
        int dsize = 1;
            dsize *= shape[j];
                cout << shape[j] << ",";
            cout << endl;
        //Get the total size of data
        else
        //create tensor
        //Bind the tensor to the output of the model
Set the output of the kmodel
void AIBase::set_output()
    //The loop binds the output tensor to the output of the kmodel
Call kmodel_interp_.run() to implement model inference
void AIBase::run()
Obtain the output of the kmodel and prepare for subsequent post-processing
void AIBase::get_output()
    //p_outputs_ pointer to store the output of the kmodel, there can be multiple outputs
    p_outputs_.clear();
        //get output tensor
        //Map the output tensor into host memory
        //Convert mapped data to float pointer
        p_outputs_.push_back(p_out);
The pre-processing and post-processing of different task scenarios are different. For example, softmax is used to calculate the category probability for classification, and nms is required for target detection. Therefore, you can define your task scenario class to inherit the AIBase class and perform pre-processing and post-processing for the task. Code is encapsulated. Take image classification as an example:
The Classification class in classification.h inherits from the AIBase class, implements the class definition of the image classification task, and mainly defines the pre-processing, inference, and post-processing interfaces of the image classification model. Initialize the ai2d builder to implement image preprocessing. Some variables for image classification tasks are also defined, such as classification thresholds, category names, number of categories, etc.
#ifndef _CLASSIFICATION_H
#define _CLASSIFICATION_H
#include "utils.h"
 * @brief classification task
 * It mainly encapsulates the process from preprocessing, running to post-processing to give results for each frame of picture.
    public:
    * @brief Classification constructor, loads kmodel, and initializes kmodel input and output classification thresholds
    * @param kmodel_path kmodel path
    * @param image_path image path
    * @param labels the list of labels
    * @param cls_thresh classification threshold
    * @return None
    * @param isp_shape   isp shape(chw)
    * @param vaddr       isp virtual address
    * @param paddr       isp physical address
    * @return None
    * @return None
    ~Classification();
    * @brief image preprocessing
    * @param ori_img image
    * @return None
    * @brief video preprocessing(ai2d for isp)
    * @return None
    void pre_process();
    * @brief kmodel inference
    * @return None
    void inference();
    * @brief postprocessing
    * @param results the result of classification
    * @return None
    private:
    * @brief exp
    float fast_exp(float x);
    * @brief sigmoid
    float sigmoid(float x);
    runtime_tensor ai2d_in_tensor_;              // ai2d input tensor
    runtime_tensor ai2d_out_tensor_;             // ai2d output tensor
    uintptr_t vaddr_;                            // isp virtual address
    FrameCHWSize isp_shape_;                     // isp shape
    float cls_thresh;      //classification threshold
    vector<string> labels; //Names of categories
    int num_class;         //Number of categories
    float* output;
#endif
Implement the above interface in classification.cc:
#include "classification.h"
Constructor for image
    cls_thresh=cls_thresh_;
    labels=labels_;
    num_class = labels.size();
Constructor for video
    labels=labels_;
    vaddr_ = vaddr;
    isp_shape_ = isp_shape;
destructor
preprocessing for image inference
    //get time
    std::vector<uint8_t> chw_vec;
    //bgr to rgb,hwc to chw
    //resize
preprocessing for video inference
inference function
    this->run();
    this->get_output();
exp
    union {
        uint32_t i;
        float f;
    } v{};
    return v.f;
sigmoid
postprocessing function
    //p_outputs_ stores a float type pointer, pointing to the output
    output = p_outputs_[0];
    cls_res b;
    //If it is multiple categories
    if(num_class > 2){
        float sum = 0.0;
            sum += exp(output[i]);
        b.score = cls_thresh;
        int max_index;
        //softmax
            b.label = labels[max_index];
            b.score = output[max_index];
            results.push_back(b);
    else// Two categories
        if (pre > cls_thresh)
            b.label = labels[0];
            b.score = pre;
        else{
            b.label = labels[1];
            b.score = 1 - pre;
In the preprocessing part of the above code, some utility functions are used, which we encapsulate in utils.h:
#ifndef UTILS_H
#define UTILS_H
#include <algorithm>
#include <vector>
#include <iostream>
#include <fstream>
#include <opencv2/core.hpp>
#include <string>
#include <string.h>
#include <cmath>
#include <stdio.h>
#include <stdlib.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <unistd.h>
#include <stdint.h>
#include <random>
using namespace std;
using namespace cv;
using cv::Mat;
using std::cout;
using std::endl;
using std::ifstream;
using std::vector;
#define STAGE_NUM 3
#define STRIDE_NUM 3
#define LABELS_NUM 1
 * @brief Classification result structure
typedef struct cls_res
    float score;//score
    string label;//result
}cls_res;
 * @brief Frame shape structure
typedef struct FrameSize
    size_t width;  // width
    size_t height; // height
} FrameSize;
typedef struct FrameCHWSize
    size_t channel;
    size_t height;
    size_t width;
} FrameCHWSize;
 * @brief AI tools
 * Encapsulates commonly used functions in AI, including binary file reading, file saving, image preprocessing and other operations
class Utils
public:
     * @brief resize image
     * @param frame_size      width and height
     * @return                image of processing
     * @brief bgr to rgb,hwc to chw
     * @param chw_vec          data
     * @return None
    // resize
     * @brief resize
     * @param ori_shape        image (chw)
     * @param ai2d_out_tensor  ai2d output
     * @return None
     * @brief resize
     * @param builder          ai2d builder
     * @param ai2d_in_tensor   ai2d input
     * @return None
     * @brief Plot the results of a classification task onto an image
     * @param frame
     * @param results
     * @return None
     * @brief Draw the results of the classification task into the OSD of the screen
     * @param frame
     * @param results
     * @param osd_frame_size        width and height of osd
     * @param sensor_frame_size     width and height of sensor
     * @return None
#endif
You can add other tool functions if needed. The following is the utils.cc file to complete the implementation of the tool class interface:
#include <iostream>
#include "utils.h"
using std::ofstream;
using std::vector;
    cv::Mat cropped_img;
    return cropped_img;
    // for bgr format
    for (auto i = 2; i > -1; i--)
    // build ai2d_in_tensor
    // run ai2d
    builder.build_schedule();
    // run ai2d
    builder->build_schedule();
    if (fontsize > 2)
        fontsize = 2;
In order to facilitate debugging, we have encapsulated the timing class ScopedTiming in scoped_timing.hpp to count the time consumption during the life cycle of this class instance.
#include <chrono>
#include <string>
#include <iostream>
 * @brief Timing class
 * Statistics of the time spent during the life cycle of this type of instance
class ScopedTiming
public:
     * @brief ScopedTiming Constructor, initializes the timing object name and starts timing
     * @param info Timing object name
     * @return None
        if (enable_profile)
     * @brief ScopedTiming destructs, ends timing, and prints the time taken
     * @return None
     ~ScopedTiming()
        if (enable_profile)
private:
    int enable_profile;                            // Whether to count time
    std::string m_info;                            // Timing object name
    std::chrono::steady_clock::time_point m_start; // Timing start time
    std::chrono::steady_clock::time_point m_stop;  // Timing end time
main.cc is the main code that implements board-end reasoning. It mainly implements parsing incoming parameters, printing instructions, and realizing reasoning in two different branches. If the second parameter entered is the inference image path, the image_proc function is called for image inference; if None is passed in, the video_proc function is called for video stream inference.
  • Static graph inference code
    int ori_w = ori_img.cols;
    int ori_h = ori_img.rows;
    //Create task class instance
    //preprocessing
    cls.pre_process(ori_img);
    //inference
    cls.inference();
    vector<cls_res> results;
    //postprocessing
    cls.post_process(results);
The above code is the static image inference code part in main.cc. It first initializes the cv::Mat object ori_img from the image path, then initializes the Classification instance cls, calls the cls preprocessing function pre_process, the reasoning function reference, the post-processing function post_process, and finally calls draw_cls_res in utils.h draws the result on the picture and saves it as result_cls.jpg. If you need to modify the pre- and post-processing parts, you can modify them in Classification.cc. If you want to add other tool methods, you can define them in utils and implement them in utils.cc.
  • For the video stream inference code, please refer to the example 2 part of the SDK compilation chapter. The core code for AI development is:
results.clear();
cls.pre_process();
cls.inference();
For ease of use, we have encapsulated the video stream processing part. You can refer to the sample code: kendryte/K230_training_scripts.The vi_vo.h file in k230_code in tree/main/end2end_cls_doc)> and the specific implementation in main.cc.
  • k230_code/k230_deploy/CMakeLists.txt description
This is the CMakeLists script in the k230_code/k230_deploy directory .txt set the compiled C++ file and the generated elf executable name, as follows:
set(bin main.elf)
include_directories(${PROJECT_SOURCE_DIR}):#Add the project's root directory to the header file search path.
include_directories(${nncase_sdk_root}/riscv64/rvvlib/include):#Add the header file directory of the nncase RISC-V vector library.
include_directories(${k230_sdk}/src/big/mpp/userapps/api/):#Add the user application API header file directory in the k230 SDK.
include_directories(${k230_sdk}/src/big/mpp/include):#Add the general header file directory of k230 SDK.
include_directories(${k230_sdk}/src/big/mpp/include/comm):#Add a directory of communication-related header files.
include_directories(${k230_sdk}/src/big/mpp/userapps/sample/sample_vo):#Added sample VO (video output) application header files directory.
link_directories(${nncase_sdk_root}/riscv64/rvvlib/): #Add linker search path pointing to the directory of the nncase RISC-V vector library.
add_executable(${bin} ${src}): #Create an executable file taking as input the list of source files set previously.
target_link_libraries(${bin} ...):#Set the libraries that the executable needs to link to. Various libraries are listed in the list, including nncase-related libraries, k230 SDK libraries, and some other libraries.
target_link_libraries(${bin} opencv_imgproc opencv_imgcodecs opencv_core zlib libjpeg-turbo libopenjp2 libpng libtiff libwebp csi_cv): #Link some OpenCV related libraries and some other libraries into the executable.
install(TARGETS ${bin} DESTINATION bin): #Install the generated executable file into the specified target path (bin directory).
  • k230_code/CMakeLists.txt description
project(nncase_sdk C CXX)
# set opencv
# set mmz
# set nncase
add_subdirectory(k230_deploy)
This is the CMakeLists .txt script in the k230_code directory. The script focuses on the following parts:
set(nncase_sdk_root "${PROJECT_SOURCE_DIR}/../../nncase/"):#Set nncase directory
set(k230_sdk ${nncase_sdk_root}/../../../):#The directory where k230_sdk is located is currently obtained from the third-level parent directory of the nncase directory.
set(CMAKE_EXE_LINKER_FLAGS "-T ${PROJECT_SOURCE_DIR}/cmake/link.lds --static"):#Set the link script path and place the link script under k230_code/cmake
add_subdirectory(k230_deploy): #Add the subdirectory of the project to be compiled. If you want to compile your own project, you can replace this line
  • k230_code/build_app.sh description
#!/bin/bash
set -x
# set cross build toolchain
clear
rm -rf out
mkdir out
pushd out
make -j && make install
popd
# The generated main.elf can be found in the k230_bin folder under the k230_code directory.
k230_bin=`pwd`/k230_bin
rm -rf ${k230_bin}
mkdir -p ${k230_bin}
fi
Code compilation#
Copy the k230_code folder in the project to src/big/nncase in the k230_sdk directory, execute the compilation script, and compile the C++ code into the main.elf executable.
# Execute in the k230_SDK root directory
chmod +x build_app.sh
./build_app.sh
Prepare the ELF file#
Network configuration and file transfer#
There are two ways to copy the files to be used to the board. One is the TFTP transfer method and the other is the SCP transfer method.
TFTP file transfer#
  • Windows system PC network configuration
Control Panel - > Network and Sharing Center - > Change Adapter Settings - > Ethernet Network Card - > Right-click Properties - > Selected (TCP/IPv4) - > Properties
Configure the IP address, mask, gateway, and DNS server address:
net_config_0
  • Development board network configuration
Go to the little core command line and execute:
# Check if there is eth0
ifconfig
# Configure the development board IP and be in the same network segment as the PC
ifconfig eth0 192.168.1.22
ifconfig
  • Tool: TFTPD64
Install the TFTP communication tool, download address: https://bitbucket.org/phjounin/tftpd64/downloads/
Start TFTPD64 and configure the directory and service NIC for files to be transferred
net_config_1
  • ShareFs instructions
cd /
ls
# The sharefs directory is a directory shared by both large and small cores, so files copied from the small core to the sharefs directory are also visible to the large core.
  • File transfer
# The following code is executed on the small core serial port
# Transfer the files in the directory where the tftpd64 configuration file is stored on the PC to the current directory of the development board
# Transfer the files in the current directory of the development board to the directory where the tftpd64 configuration file is stored.
SCP file transfer#
In the Linux system, the PC is normally connected to the network, and the development board can be connected to other network ports under the gateway where the PC is located through the network cable, and file transfer can be realized through the scp command.
Power on the development board, enter the COM interface of large and small cores, and execute the scp transmission command on the little core:
# Copy files from PC to development board
scp username@IP:file_path_PC file_path_board
#copy folder from PC to development board
scp -r username@IP:folder_path_PC folder_path_board
# Copy files from development board to PC
scp file_path_board username@IP:file_path_PC
# Copy folder from development board to PC
scp -r folder_path_board username@IP:folder_path_PC
K230 side deployment#
Board-side deployment process#
Follow the file transfer process configured in the previous section, enter /sharefs on the little core interface on MobaXterm, and create a test folder:
cd /sharefs
mkdir test_cls
cd test_cls
Copy the prepared files in the model training and testing section and the elf files prepared in the C++ code compilation section to the development board.
test_cls
 ├──best.kmodel
 ├──labels.txt
 ├──main.elf
Enter the /sharefs/test_cls directory at the big core COM port,
To perform static graph inference, execute the following code (note: the code needs to be executed under the big core, and the file copy needs to be completed under the little core):
# "Instructions for passing parameters during model inference:"
# "Options:"
# "  kmodel_path     Kmodel path\n"
# "  image_path      image path/None\n"
# "  labels_txt      Category label file path\n"
# "  debug_mode      0(no debug)、1(print time)、2(print all information)\n"
To perform camera video stream inference, execute the following code:
Effect of deployment on the board#
Static graph reasoning diagram:
image_inference
Video streaming inference diagram:
video_inference
Frequently Asked Questions (FAQs)#
Problem: TF card boot fails with exit code 13 error
Answer: The reasons are as follows: 1. The file error in the boot media. 2. The startup pin is set incorrectly.
Bootrom boot error code#
Question: What does the bootrom boot error code mean?
When bootROM fails to boot, it will print an error similar to the following boot failed with exit code 19, the last number is the cause of the error, and the common error meaning is as follows
value
meaning
13
The boot media contains a file error
19
Boot media initialization failed, such as not inserting an SD card
17
The OTP requirement must be a secure image, but the files on the media are non-secure images
perf use#
Question: How is perf compiled and what hardware events are supported?
A: The reference image with PERF function is linked below https://kvftsfijpo.feishu.cn/file/LJjpbwxnzowI9RxvL0NcEK73nkf?from=from_copylink
When perf, you can use the RAW event, such as perf stat -e r12, and the perf tool compile command as follows
cd src/little/linux/tools
#copy perf/perf file to board
Special note: Versions prior to 1.1 have the following modifications
#src/little/linux/arch/riscv/boot/dts/kendryte/k230_evb.dtsi add
pmu_thead: pmu_thead {
    interrupts = <17>;
#src/little/linux/arch/riscv/configs/k230_evb_defconfig  add
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_PERF_EVENTS=y
CONFIG_KUSER_HELPERS=y
CONFIG_DEBUG_INFO=y
CONFIG_FRAME_POINTER=y
[root@canaan ~ ]#
Big Core runs Vector Linux#
Question: How does Big Core run Linux with Vector?
Answer: make CONF=k230_evb_only_linux_defconfig ; The compiled image, the big core runs Linux with vector by default.
Big core serial port ID#
Question: How to modify the serial port ID of the big core?
Answer: The configuration file below configs CONFIG_RTT_CONSOLE_ID stands for the big core serial port ID, modify it to the correct value.
uboot command line#
How to compile the version that can enter the uboot command line
Answer: The configuration file below configs CONFIG_QUICK_BOOT stands for fast, modify it to CONFIG_QUICK_BOOT=n to generate a command-line version that can be entered into uboot.
How to start slowly and start faster#
Answer: Enter the uboot command line and execute the following command:
How Linux modifies the last partition size#
Answer: You can use the parted tool to dynamically modify the size of the last partition, refer to the following command:
umount /sharefs/
parted   -l /dev/mmcblk1
mkfs.ext2 /dev/mmcblk1p4
mount /dev/mmcblk1p4 /sharefs
#reference log
Model: SD SD32G (sd/mmc)
Disk /dev/mmcblk1: 31.3GB
Partition Table: gpt
Disk Flags:
Disk Flags:
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
First data block=0
232 block groups
8176 inodes per group
Disk Flags:
[root@canaan ~ ]#df -h
[root@canaan ~ ]#
How to modify bootargs#
Answer: Method 1: Modify bootargs using env file. For example, you can add the following content to the board/common/env/default.env file:
Method 2: Enter the uboot command line and modify bootargs with reference to the following command.
How to view bootargs#
Answer: Method 1: Under linux, enter cat /proc/cmdline to view
[root@canaan ~ ]#
Method 2: Linux command line input dmesg | grep command view
[root@canaan
The little core is modified by default serial port#
Answer: At present, the little core serial port in the SDK defaults to 0, if you need to modify it to other serial ports (such as serial port 2), please refer to the following to modify:
Modification 1: Refer to the following to modify the uboot device tree (e.g. arch/riscv/dts/k230_evb.dts):
aliases {
        uart2 = &serial2;
    chosen {
    serial2: serial@91402000 {
    clock-frequency = <50000000>;
    clock-names = "baudclk";
    reg-shift = <2>;
    reg-io-width = <4>;
    u-boot,dm-pre-reloc;
Modification 2: Refer to the following to modify the Linux device tree (e.g. arch/riscv/boot/dts/kendryte/k230_evb.dts)
aliases {
        serial2 = &uart2;
chosen {
        stdout-path = "serial2";
&uart2 {
    status = "okay";
Modification 3: Modify bootargs using env files (see 2.10).
How to completely recompile the SDK#
Answer: After updating and modifying the SDK source code, or after modifying the SDK source code, it is recommended to enter the following command to completely recompile the SDK.
make clean; make;
Special note: The SDK does not support multi-process compilation, do not add multi-process compilation options like -j32.
